Question about Microwave Ovens
Ihoe do I remove the panel to a GE undercounted mount Mircro?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
Do you have the model # ?. that would give me more info.
Posted on Jun 10, 2014
Replace a fuse on GE Profile model jvm1871SH02
Unplug microwave or shut off house breaker. Remove grill or cover that goes across the top of door and control panel.Remove screw that holds control panel on and lift up on control panel. It will tilt downward and has 2 tabs at the bottom that go into slots. It can be lifted out of those slots.The fuse should be seen at the top area in the microwave behind where the control panel was mounted. Fuse is usually small 1/4 round type fuse like old type car fuses that were glass but the micro fuse will be either a white of gray ceramic fuse not glass. Some are 15 amp some are 20 amp. Usually stamped on end of fuse.
Mar 01, 2015 | GE Microwave Ovens
How to find fuses on my GE Spacemaker XL microwave model# JVM1340 WW
First thing is make sure you unplug the power cord. Turn the microwave around and remove the screws that hold the cover on. Remove the cover and look for where the power cord goes through the back of the unit. Follow the black wire coming from the power cord and that will take you to where the fuse is located. It might be on a small circuit board or mounted in a fuse holder or it might have an inline holder. Make sure that you replace the fuse with the same amperage fuse as you take out. You will find the amp rating stamped into one of the collars on the fuse. Good luck!
Feb 27, 2015 | GE Microwave Ovens
How can I remove a GE Spacemaker Microwave JVM62
Some older microwaves slid off the mounting plate. Try pulling it forward and see if it slides off. Some of them had screws that screwed into the back plate. Remove the grill panel and see if there are screws on each side.
Aug 25, 2014 | GE Your Spacemaker Microwave Oven Model...
PANEL LIGHT REPLACEMENT
Please remove the top cover to find the lamp mounted which can be replaced.
Click on: Bulb
Jan 24, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker (JVM1631). The door latching mechanism has failed and will not stay closed causing the the microwave to not function. Do you have any troubleshooting suggestions?
Hi, normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the manual) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order GE parts is Tritronics.
Jan 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Dooor wont open
If this is an undercounter unit remove it from the mounts. Remove the case and look at the rear of the display/control area. You should be able to see the door latch. If not remove the electronics in that section of the unit. When you can see the latch you should be able to get the door open. If the unit is not working (latch wise) you will need to get a new one. Try www.repairclinic.com they have parts for everything at a good price. Getting the door lock out will require a little thinking on your part but you should be able to accomplish it.
Dec 08, 2010 | Whirlpool MT4155SP Microwave Oven
I need a couple of bulbs for my undercounter Spacemaker GE Profile XL1800- do you have a reference or part number
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Be sure to unplug the oven before removing or installing bulbs, or the circuit board may be damaged. We repair these all the time for that.
Let me know if I can help further.
Aug 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
I'm trying to remove a Hotpoint RVM58003. I removed four long bolts from the top but it does not move. Any help on what I need to do to remove it? Dan
The Hotpoint RVM58003 (circa 1984) cannot be lifted off a hanger after the four top screws are removed because it doesn't have a separate pre-installed hanger like newer units do. The rear mounting screw holes are part of the outer frame of the unit, which requires removal of the Microwave sub-assembly of the Hotpoint RVM58003 to expose the outer metal frame and the array of pre-drilled rear mounting holes before the rear mounting screw(s) can be accessed and removed. Based on my recent experience removing a Hotpoint RVM58003 Microwave Hood from 1984 it appears the unit was originally installed this way too. Please note that this is a very involved process. Basic steps are: 1) Unplug AC power to the unit, or turn off the circuit breaker. 2) Remove the top plastic grill over the door and control panel (2 screws). 3) Next to the grill screws remove the larger left/right screws holding the Microwave sub-assembly in. 4) Drop down the hinged light bulb/air filter cover panel (mine had 7 screws). 5) Remove the small metal cover plate on the right under the control panel. This exposes the Microwave sub-assembly electrical connector. 6) Disconnect the Microwave sub- assembly connector. 7) Carefully pull the Microwave sub-assembly out of the frame and set aside. You may need to fish the power cord through the cabinet or unscrew the power cord terminals. NOTE: this is best done with a helper because this sub-assembly is about 25-30 pounds. 8) Once the sub-assembly is out the rear plate is exposed and the rear mounting screws can be removed. I found that the GE/Hotpoint Owner's Manual does not have installation instructions. Neither does the GE web site, they only have the Owner's Manual. For more specific help and instructions I suggest calling The GE Answer Center at 800-626-2000 or hiring a professional installer experienced with this older style Microwave Hood.
Jan 23, 2009 | Hotpoint JE740WY/GY Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
