Question about Husqvarna 22" High Wheel Trimmer With 190Cc Brigg & Stratton Engine - HVL HU625HWT
I have a wheeled trimmer with broken belt?
How do I fix it step by step?
    Problem Solver:
  • 7 Answers
Pretty simple, take bolts out that hold front gaurd on move it out of the way ther are two small pulleys that the belt passes through, take the 2 nits off that hold the pulleys on. Remember which pulley goes where as they are different. Put the new belt on, makin sure the v side of belt goes into v shaped pulley grooze and flat side of belt goes on flat pulley
Posted on Jun 22, 2014
How to change drive belt on craftsman weed eater on wheels
Hello, this is the best way to do this. Go straight to you tube....in the search area type in those key words, a video will help you 10x better than writing it down. Visualization is key
Sep 26, 2015 | Craftsman Garden
How do I fix a wheeled trimmer with broken belt?
there should be a black plastic cover over front top this should come off with only a few small screws 6mm size i think they are you should be able to see belt then it's only a matter of fishing new belt inside and over the motor end then hold clutch/tensioner Off back side of belt (use the handle bar) and loop belt over front pulley let go of tensioner (handle) replace cover and screws and you should be good to go
May 17, 2014 | Husqvarna 22" High Wheel Trimmer with...
Change drive belt
Setting the belt tension on the 707-708-717 machines with the old rubber "Continental" belts:
1. Make sure that the hand-wheel spins freely on the main-shaft bushing stub when the release knob is loosened.
2. Assuming that you are using the original 441mm "Continental" rubber v-belts, the setting is made by means of loosening a 5mm Allen socket cap screw at the base of the step pulley support.
_____________
NOTE: The hand-wheel, stepped pulley, and motor pulley v-grooves must be clean. This is to say, that they cannot have any particulate or threads wrapped around the grooves.
4. The pulley will be automatically pre-tensioned to a 7 o'clock position by means of a spring to maintain the stepped pulley position. By pulling the belt toward this 7 o'clock position, the pulley tension can be adjusted and then tightened by means of the fixing screw.
_____________
5. It is important to know that both the upper and lower belt tensions can be independently adjusted so as to allow the hand-wheel to spin freely for bobbin winding without having the hand-wheel drive the machine. This is done by adjusting the step pulley support + or - radially, near the 7 o'clock position.
If the hand-wheel drives the machine with the upper belt loosened, then either the belt is too tight or the hand-wheel bushing and main-shaft stub need cleaning and lubrication.
Note: Lubrication was once the standard factory procedure with a class 68 oil, but experience dictates a dry lubrication with graphite. Silicone lubes are not recommended.
6. Do not over-tighten the 5mm Allen fixing screw as the 5mm threaded frame boss can be broken off.
Adjusting with the original Polyurethane v-belts on models 807-801-810-817-811 machines:
1. Follow the same procedure as mentioned but allow the step pulley's positioning spring provide the belt tension. Nothing more is required here.
NOTE: Sometimes these belts and pulleys get oily thus allowing much slippage. A simple cleaning of the belts and pulleys with mineral spirits can solve this problem.
After-market belts:
NOTE: One can find after market belts that serves to drive these machines but not without some problems as they are usually wider belts and don't fit the pulleys well. In this case some adjustment will be necessary.
SewTechnical Home
Mar 28, 2014 | Bernina Sewing Machines
Ryobi trimmer c430 the timing belt keeps coming off the camgear what can I do?
My timing belt kept coming off also, even with a new belt. I cut a disc of aluminum 1/8 thick slightly larger than the wheel and belt appr 1/8 all the way around. I fastened the disc to the wheel with 6/32 screws and nuts and it works great. No problems with belt coming off 3 months later. Email me bkarudy@yahoo for pics.
Sep 26, 2012 | Garden
Beko Tumble Dryier - Model DRVS 73 W the Belt 9PHW 1967 has broken. Is there a step by step guide on how to fit the replacement belt.
Very easy on all tumble dryers.
UNPLUG FROM POWER FIRST!
This is simply a case of:
Take the top off the machine (Usually a couple of screws holding the lid on at the back).
Or - Rempove the inspection panel from the back
Drop the new belt over the drive motor spindle
On some machines you may need to thread the belt around a tensioning wheel
Now take the belt and place it on the side main wheel that drives the drum and simply spin the drum wheel with your hand, guiding the new belt into place as you spin the wheel.
It should simply stretch a little and work its way onto the wheel as it is hand turned.
Note, once it is on, take a look at the drive motor and make sure that the belt is sitting in the same place as the old one. Most of these motors have a slotted spindle and you can see from the clean and shiny surface where on the spindle the belt used to sit. If it is a little out of place, once again just take hold of the belt and pull it toward you or push it away as you spin the main drum wheel in order to move it into the correct slot.
Jun 23, 2011 | Dryers
My Grass Hog trimmer was working fine then all of a sudden it stopped cutting. The string no longer spins around. I just hear a werrrrring sound. I just bought it last summer.
I can tell you what is is, the belt came off inside. Mine is doing the same thing, I took the case off and looked inside, the belt had come off the metal wheel. I put it back on but it keeps coming off. Im thinking theres a piece I must have lost that helps hold it on. Thats what Im looking for now. If you can get the belt back on and to stay on then it will work again.
Aug 20, 2010 | Black & Decker 14" Grass Hog Xp...
Drive belt broken is it worth replacing it? Other parts OK
the cost of the replacement belt is cheaper than a new trimmer so has to be worth changing
Jul 06, 2010 | Black & Decker 14" Grass Hog Xp...
Front drive wheels won't engage
Is it possible that the belt has either broken or come off the pulleys? Next step would be to remove the cover and see if there is something preventing engagement or if you see any broken parts. May even be as simple as lubricating the cable/levers.
Apr 10, 2010 | Toro Lawn Mower With Toro Power Tools
I have an Ariens 624 series snow blower and every time I use the snowblower the snow spits out of the chute. How do I get the snow to BLOW out of the chute far? I've tried tightening the cord for the...
Looks to me like your second stage is not working. If the auger is turning fine, look and see if the secondary thrower is turning. Probably a shear bold on one or the other is broken. Easy fix, but do not put your hands in there when the machine is running!
Jan 09, 2010 | Garden
My grasshog gh600 wont feed the line anymore. i replaced the cap, spring and purchased a pre-spooled line to see if that was the problem. it wasn't. please assist
check out a white plastic lever at the back of the spool line. if its broken then replace it. cost of the parts around $4.00 or so. this parts controls the auto feed of the spool
thanx
Jun 24, 2008 | Black & Decker String Trimmer Cordless 12"...
Husqvarna 22" High Wheel Trimmer With 190Cc Brigg & Stratton Engine - HVL HU625HWT Logo
76 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
