Question about Fastcorp 820 Vacuum Ice Cream Frozen Vending Machine Merchandiser
Machine takes money then digital display flashes/ blinks then doesn't work. When you open the door quarters drop out, $1 to $3. Have to pull button out a bottom to remove flashing display.
I have a Panasonic Vera and when I tried to turn it on manually the power button keeps flashing red and doesn't turn on? Please help
How many times do this power button flashes at one time switch ON? These flashes are fault indications, otherwise called as blinking codes. Check the site linked below to get an idea of these blinking codes. Blinking codes to many brand TVs are given.
If you wish to get more details, check the site linked below. Pull up older posts there. Check the site with patience, as it has over 2400 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.
May 02, 2013 | Televison & Video
Can´t open the rear tail gate/door. Have tried the emergency opening option (holding down the 2 lock buttons in the car) but that didn´t work either. When pressing the rear door "handle" to open...
If you squeese the handle put your head near the badge you should hear one micro switch operating the window and a noise like well hard to explain but its a solenoid operating the rear latch after the window drops, you can get the inside panel off bit hard with door locked; at bottom of door panel is four philips screws take them out and then the panel pulls from the bottom up,cut round water shredder and you can operate latch manually to get it open then check to see if micro switch in handle is working its not a rear wiper fault or window fault as they work, the relay for the rear door latch and the rear window are behind the offside rear quarter panel 3 connectors for rear door electrics, the relays are up by the seat at top,its not normally a relay issue either rear door latch solenoid or micro switch in back handle but rule out the handle as window works.
Disconect battery and wait 5 min and try again it worked on mine.
Hope helps.
Oct 15, 2010 | Land Rover Discovery Cars & Trucks
F21 Error code flashing
Plug off the wall first. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
To manually unlock the door lock system, perform the following steps.
1. Unplug the power cord from the outlet.
2. Remove the lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a teardrop shaped tab. Gently pull the tab down approximately quarter inch, or until a click is heard.
5. The door may now be manually opened.
Apr 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Pulled the handle to early to open the 7kg front loader washing machine and broke the handle. Cant open the door now and wet clothes are the washer. What can i do to fix this up?
To manually unlock the door lock system:
2. Remove the front lower kick panel.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened
Or pull out your dispenser tray, along the rear edge you will find a cord, pull this like above. Depends on your model.
Try these sites for spares:
RepairClinic.com espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 02, 2009 | Samsung WF337AA Front Load Washer
I cannot open the door of my washing machine. Is there some sort of emergency button to automatically open the door? it's been jammed for 3 weeks now. Please help!
Apr 01, 2009 | Bosch Washing Machines
Garage door goes a quarter way up.
If the wall station is flashing the lock button is on Push and hold the lock button for 2 sec. and release. The light should be solid(not flashing) For you door opening part of the way: If you have a Chraftsman/Liftmaster:
 1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
    1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
    2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
  B. If the door runs fine then check the up and  down force on your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing  the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
C. If this does not solve your problem the top bushing could be going out of your operator. Open the case and see if a lot of black filings are on the top of the big gear. If so the gear assy. will have to be replaced part # 41C4220A
Dec 09, 2008 | liftmaster Electrical Supplies
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Feb 07, 2008 | Kitchen Ranges
Taking photo's requiring the flash.
the flash housing unit is stucked!!  Try to do this: use around 3 inches sticky tapes like scotch tape or masking tape, stick the 1/3 part on the flash housing unit , now set the release button while pulling the tape upward, do not apply too much force, you are trying to help the housing to go upward not to detached it, ha ha..( the sticky tape is safe to use, dont worry). It always work but in case it does not work from your unit try this dangerous one, using small metal and pressing the release button try to open the door ( yes, like opening the stucked door!), its dangerous that yo might detached the housing from the unit, so be carefull. [:0)
Oct 12, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Fastcorp 820 Vacuum Ice Cream Frozen Vending Machine Merchandiser Logo
22 people viewed this question
Top Fastcorp Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Fastcorp Retail Supply Expert? Answer questions, earn points and help others
