Question about Sony 540W Mini Hi-Fi Shelf System
Sony - 540W Mini says protected - Sony 540W Mini Hi-Fi Shelf System
    Genius:
  • Sony Master
  • 1,054 Answers
Amp ic is shorted and needs to be replaced
Posted on May 20, 2014
Hello.. I have Sony MHCEX500 MINI HIFI Component system. There is a problem of PUSH POWER PROTECT. How can I fix it..????
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
Apr 12, 2016 | Sony Audio Players & Recorders
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Sony stereo protect mode
If "PROTECT" appears on the display: Immediately unplug the power cord, and check if anything blocking the ventilation holes on the back of the system after "PROTECT" disappears. After you have checked the ventilation holes and found to be all right, reconnect the power cord, and turn on the system. If the issue persists, contact your nearest Sony dealer.
The above is from the manual at http://www.docs.sony.com/release/MHCEC909IP.pdf
May 24, 2013 | Sony Mhcec909ip Mhc-ec909ip Mini Hi-fi...
"Protect" Blinking on Sony Stereo
may i see a diagram showing where the ic goes?
Nov 03, 2012 | Sony Mhcec909ip Mhc-ec909ip Mini Hi-fi...
Protect push power
audio amplifier IC fried need to be replaced
Jun 01, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
DISK WRITE PROTECTED AND FILES CHANGED
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Oct 06, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Pushed power protect
speaker protection turned on.it can be happend because of bad power amlifire section.can you remoove the powe ramp board with large heatsink.its very easy to repair.and i can help.
nuwan
Jan 09, 2009 | Sony Multi-System Mini Hifi Systems / DVD...
Erasing an MD after "TR Protect" has been set.
I figured it out!! Initialize! Connect your MZ-N505 to a PC with the USB port. You'll need a USB A to mini B cable.Using the SonicStage software from Sony Support. You can then click the Transfer tab at the top of the screen. Select NetMD. All the current tracks on the disc should appear in the right hand window. At the bottom right of that window click Device/Media info. A dialog should pop up allowing you to Initalize (erase) the disc. Whew! I also bought a bunch of used Mini Discs that I wanted to record over. I ran into the same "TRProtect" message. Now I can use all these discs! Hope this helps. Have fun.
Dec 19, 2008 | Sony Net MD Walkman MZ-N505
Push protect problem/ sony MHC-VX33
push power protect is error signal shows problem in power amplifier board, mostly power amp out
IC STK402-100S found deceptive.
contact nearest Sony service center for proper repair.
Sep 29, 2008 | Sony MDS-JB940 Mini Disc Player
Sony 540W Mini Hi-Fi Shelf System Logo
73 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
