Question about Kenmore Refrigerators
Managemylife SxS model 106.56536400. I cannot get the cantilever shelf, part number 2211581 and the snack-pan, part number 2188655 to slide together. What am I not doing right I wonder? I am generally a pretty handy guy but this one has me baffled.
  • Kenmore Master
  • 842 Answers
The First one is available as of today at Marcone.com in Fresno, the second one would need to be ordered but no longer comes with white trim from the same company. These parts are still available. Good Luck
Posted on Jun 06, 2014
LG LFC21760ST Beeping Constantly again. Last time it cost me a fortune to replace the computer board. Isn't there a cheaper way to stop the sound?
I would suggest starting with the easiest troubleshooting tip first. Try unplugging it for 10 minutes and plugging it back in. Most (modern) appliances will reset to factory defaults when they are unplugged for a few minutes.
May 29, 2014 | LG LFC23760SB Three Door French Door...
LG LFC23760SB Refrigerator doesn't have power. The outlet is ok. Didn't have a power surge.
i think there is problem with your compressor unit. You need some maintanance or service of your refrigerator at regular period.
Jan 03, 2014 | LG LFC23760SB Three Door French Door...
Where can I find a wooden automatic gate?
A wooden driveway gate needs to be supplemented with a steel frame to last since they will be opened much more frequently than an ordinary wood gate. The slide type gates will need the structural strength to resist the pulling of the chain. A swing gate, will be cantilevered since a wheel at the opposite end will trigger the obstruction reversing mechanism in the gate operator. This cantilevering over the long width of a driveway requires steel in the structure both to prevent sagging and to keep the gate looking good over time. Gaps and misalignment will occur naturally as the wood shrinks and expands in weather. The steel frame helps to hold everything together tightly.
We make our gates using wood cladding over a steel frame. If you like check out our link at the bottom for more information. Here are some projects we have completed.
http://aaagate.com/wood-iron-gates
Jan 31, 2013 | Home Fencing
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
I have a 1950'S GE range and can't locate the Model number This range has 4 burners, the oven has chrome on the inside of the oven door. there are slide out compartments under the oven and on the left side...
I believe the model number is inside the drawer to the left of the oven near the top on a metal plate. it wont say model number as it was a catalog number. it will say cat. no
Nov 07, 2009 | GE Kitchen Ranges
Tenants have broken every door shelf rack
For the GE refridgerator, the model GTS22 is an incomplete model number. That is actually the series number. Your actual model should be followed by 5-7 more letters, as in GTS22FBPBRWW. The full model number denotes dates, dimension, color, etc. You can find the full model number in one of two places:
A) Upper front left corner of the food compartment
B) Left side of the crisper pan on the food liner (with storage drawer open).
Once you find the correct model number, it is important to decide exactly which parts you need. Each door shelf comes in 3 pieces. You have two end caps (left and right) and then the front piece. For the bottom shelf, the end caps are different than the caps for the top and middle shelf. Also, do you need the dairy door and the butter dish? A schematic drawing can be most helpful.
When you know which parts you need, you can go online to www.partstore.com or call toll-free 866-925-PART (7278).
Apr 07, 2009 | GE GTS22 21.8 Cu. Ft. Top-Freezer...
Whirlpool snack pan track broken
You are absolutely correct...
IF AVAILABLE... (few OLD refrigerator parts are)
refrigerator parts are usually sold as functional parts.
I have seen ... and I am sure if you look long enough...
ONE DAY you will find some business that is able to
inventory EVERY REFRIGERATOR part ever made...
Stock, list, sell & ship... and still make a profit.
As for me... I would be THANKFUL to find
my parts. l have spent weeks trying to get an intelligent
RESPONSE ... out of "1st Source Servall"
Customer Service Representative...
It was more important for "Nancy" to argue with me about part numbers... (their cost $172.. (I think: never got answer)).
I finally caved... ripped out the motor... and looked it up on eBay
$22 USD ... and 3 days later the MARVEL 6RFI is working
fine again... 2.3W 1300 RPM 115V condenser fan.
I am just saying SEARSPARTSDIRECT was(in my opinion)
the worst... "1st Source Servall" just pushed them off of that pedestal.
I recommend eBay... If you have more TIME than MONEY.
ELSE... buy that assembly (and be very happy to get it).
Carnac the Magnificent
Apr 26, 2017 | Whirlpool GC5SHEXNS Side by Side...
ISO refrigerator door handle
Your original repairman must have looked up a similar model without the snack door. The handle of couse would have also been listed, but this is difficult since A. You do not give your model number and B. (maybe not as bad) we don't know what model number he used when he ordered your door(s). Please list the complete model number of your refrig. (from sticker inside fresh food compartment) and I'll try to help.
Aug 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Cleaning Glass shelves mold.
the shelves can be removed not taken apart. sorry they're glued together, just use a bristle brush and some bleach. no problem.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
22 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
