Question about Vehicle Parts & Accessories
1996 mercedes lock cylinder housing removal
Need information on how to remove steering whell lock section from housing
  • Adrian Jaramillo
    Adrian Jaramillo May 17, 2014
    I am concern with key tumbler hold housing, steering wheel lock sectionof housing, if it can be removed from housing, and also how to remove housing from vehicle.
  • outsidedabox May 21, 2014
    Hi Adrian, what is the model of you car.. is it a C-Class W202 or E-Class W210 model. If you can supply the Vin or chassis number.. starts with WDB.. and 14 digits after that. The steering lock is held in with pin, depending on model.. to remove key tumbler you need a special tool (which can be easily made in a w/shop) but still need the key to turn tumbler to position 2 to insert tools to remove the tumbler. Than remove the cover shroud that is over the tumbler. Than the steering lock can be removed, if you cannot remove the tumbler, the steering lock will have to be cut out in place.
    Filmmaker:
    Uploaded 5 video answers.
  • 36 Answers
Watch this video it shows the process
Posted on Dec 10, 2014
  • 4 Answers
Posted on May 21, 2014
I need to change out the ignition on my 94 explorer cause my friend im buyin it lost the key so do you know how to get it out without the key?
You need to turn key to ON position and stick pin or paper clip in hole on side to release it so you can pull it out.
Section 11-04B: Steering Column, Ranger/Explorer 1994 Ranger and Explorer Vehicles Workshop Manual
REMOVAL AND INSTALLATION Ignition Switch Lock Cylinder (Without Key) NOTE: The following procedure applies to vehicles where the lock cylinder is inoperative and the lock cylinder cannot be rotated due to a lost or broken ignition key and the key number not known or the lock cylinder cap is damaged and/or broken to the extent that the lock cylinder cannot be rotated.
Removal
  1. Disconnect the battery ground cable . For tilt columns, tilt to the full up position. Remove the steering wheel , steering column locking lever (3B661) , and steering column trim shrouds as described in this section. NOTE: When drilling out the retaining pin, take care not to damage the cast housing.
  1. Punch the lock cylinder retaining pin with a ***** punch (1/8 inch maximum outside diameter). Using a 3.17mm (1/8-inch) diameter drill, drill out the retaining pin going no deeper than 12.7mm (1/2 inch).
  1. Place a chisel at the base of the ignition lock cylinder cap. Using a hammer, strike the chisel with sharp blows to break the cap away from the lock cylinder.
  1. Using a 9.8mm (3/8-inch) diameter drill, drill down the middle of the ignition lock key slot approximately 45mm (1-3/4 inch) until the ignition lock key slot breaks loose from the steering column cover casting. Remove the ignition lock key slot and the drill shavings from the base of the cover cast housing.
  1. Remove the lock cylinder drive gear, bearing retainer and actuator from the casting as described in this section. Thoroughly clean the components in an acceptable cleaning solution. Carefully inspect all components for any damage resulting from the drill operation. If any of the components show signs of damage, they must be replaced. Clean the casting with compressed air to remove any drill shavings or foreign particles and carefully inspect it for damage. If the casting is damaged, replace it with a new one.
Installation
  1. Lubricate the lock cylinder with grease.
  1. Reinstall the lock cylinder drive gear, bearing retainer and actuator. Lubricate with grease before installing.
  1. Turn the lock cylinder to the ON position and depress the lock cylinder housing retaining pin.
  1. Insert the lock cylinder into the lock cylinder housing making sure that the tab at the end of the cylinder aligns with the slot in the steering gear (3504) .
  1. Turn the key to the OFF position. This action will permit the retaining pin to extend into the lock cylinder housing hole.
  1. Using the ignition key, rotate the ignition switch lock cylinder to make sure to correct mechanical operation in all positions.
  1. Connect ignition key warning switch terminal and wire .
  1. Install the upper and lower steering column shrouds as described in this section.
  1. Install the steering wheel as described in this section. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
  1. Connect the battery ground cable .
  1. Check for proper start in PARK or NEUTRAL. Also check to make certain that the start circuit cannot be actuated in the DRIVE and REVERSE positions
Apr 06, 2011 | Ford Explorer Cars & Trucks
Need to replace ignition cylinder. no keys
This is not an easy repair due to anit theft requirements. need to chisel off bolts.
Section 11-04: Steering Column 1997 Probe Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 05/17/2000
Ignition Switch Lock Cylinder Removal
  1. Remove the steering wheel (3600). Refer to the procedure in this section.
  1. Remove the four lower steering column shroud screws.
  1. Separate the upper and lower steering column shrouds.
  1. Remove the ignition switch lock cylinder illumination miniature bulb from the lower steering column shroud.
  1. Remove the upper and lower steering column shrouds.
  1. Remove the multi-function switch (13K359). Refer to Section 11-05 for the removal and installation procedure.
  1. If equipped, remove the ignition/shifter interlock cable screw.
  1. Disconnect the ignition/shifter interlock cable (3F719) from ignition switch lock cylinder (11582).
  1. Use a chisel to remove the two ignition switch lock cylinder bolts.
  1. Remove the ignition switch lock cylinder from the steering column.
  1. Disconnect the ignition key reminder switch electrical connector.
  1. If necessary, remove the ignition key reminder switch.
Installation
NOTE: Use new ignition switch lock cylinder bolts. Tighten the bolts until the bolt heads break off. Check for proper ignition switch (11572) operation.
To install, reverse the removal procedure.
Mar 25, 2011 | 1997 Ford Probe
Husband lost key to car and I need to know how I can remove the ignition so it can be replaced
Cirrus, Stratus, Sebring Convertible and Breeze CAUTION
The Supplemental Inflatable Restraint (SIR) system must be disarmed before working around the steering column. Failure to do so may cause accidental deployment of the air bags, resulting in unnecessary SIR system repairs and/or personal injury.
  1. Disarm the air bag system, as described in Scetion 6.
  2. Remove the upper steering column shroud.
  3. Pull down the lower steering column shroud enough to access the lock cylinder retaining tab.
  4. Turn the ignition key to the RUN position.
  5. Insert a small prying tool into the tab access hole and depress the tab. Fig. 1: Depress the retaining tab and remove the lock cylinder 90908g36.gif
  6. Pull the ignition lock cylinder from the steering column. To install:
  7. With the ignition key in the lock cylinder, turn the key to the RUN position. Depress the lock cylinder retaining tab. Fig. 2: The shaft at the end of the ignition lock cylinder lines up to the socket at the end of the lock cylinder housing 90908g37.gif
  8. The shaft at the end of the ignition lock cylinder lines up to the socket at the end of the lock cylinder housing. The socket must be in the RUN position for the socket and lock cylinder to line up.
  9. Line up the lock cylinder to the grooves in the lock cylinder housing. Insert the ignition lock cylinder into the housing until the retaining tab sticks through the opening in the housing.
  10. Lightly pull on the ignition lock to make sure it has engaged the retaining tab.
  11. Turn the key to the OFF position. Remove the ignition key.
  12. Install the steering column covers.
  13. Arm the air bag system, as described in Section 6.
Sebring Coupe and Avenger NOTE: For information on removing/installing the Ignition Lock Cylinder, refer to the Ignition Switch removal and installation procedure, earlier in this section. prev.gif next.gif
Aug 17, 2010 | 1996 Dodge Avenger
Ignition
the actuator inside the sterring column that the lock cylinder turns is boken, this is a very complex job and is not for the home tech without a factory service manual.
Apr 21, 2010 | 1996 Ford Taurus
Car still running after take key out . cheked barrel thats ok don't know if it's relay problem
I think you have a bad ignition switch, not the ignition lock cylinder. they are 2 different things.
Section 11-05: Steering Column Switches 1996 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION Ignition Switch Removal
  1. Disconnect battery ground cable (14301).
  1. Remove lower instrument panel steering column cover (04459).
  1. Rotate ignition switch lock cylinder (11582) to the RUN position.
  1. Disconnect the ignition switch electrical connector.
  1. Remove the two screws retaining ignition switch (11572).
  1. Disengage the ignition switch from the actuator.
Installation
  1. NOTE: A new replacement ignition switch assembly will be set in the RUN position as received.
    Adjust the ignition switch by sliding the carrier to the ignition switch RUN position.
  1. Make sure that the ignition switch lock cylinder is in the RUN position. The RUN position is achieved by rotating the ignition switch lock cylinder approximately 90 degrees from the LOCK position.
  1. Install the ignition switch pin into the actuator. It may be necessary to move the ignition switch slightly back and forth to align the ignition switch mounting holes with the lock cylinder housing threaded holes.
  1. Install retaining screws. Tighten to 5.6-7.9 Nm (50-69 lb-in).
  1. Connect electrical connector to ignition switch.
  1. Connect battery ground cable. Check ignition switch for proper function, including START and ACC positions. Also, make certain that the column is in the LOCK position.
  1. Install lower instrument panel steering column cover with screws.
Nov 21, 2009 | 1996 Ford Taurus
My key will start the car but it wont turn the car off i have to unplulg the distributor to kill theh car. Also the ignition switch in the car rotates all the way around but it has always done that it just...
the ignition switch is an electrical part. The lock cylinder is whre the key goes and it activates the ignition switch. If you pulled the lock cylinder out, you could operate the car with a screwdriver.
Either you have damaged the ignition switch where the lock cylinder goes into it, or the lock cylinder is damaged where it fits into the ignition switch.
this is 96 taurus, don't have 92 sorry
Installation
DESCRIPTION AND OPERATION Ignition Switch The ignition switch (11572), which is mounted on the steering actuator housing (3F723), operates in the following manner:
  • The ignition switch is cycled through rotation of the ignition switch lock cylinder (11582) through a pin which is part of the ignition switch.
  • The ignition switch lock cylinder also controls the mechanism which provides a positive lock for the transaxle linkage and the steering system.
  • The locking mechanism is located in the steering column housing.
The ignition switch lock cylinder positions are:
  • ACC
  • LOCK
  • OFF
  • RUN
  • START
The key can be removed from the ignition switch lock cylinder with the column-shift transaxle only when the shift lever is in PARK position and the key is in LOCK position.
  • The ACC position operates while the steering and transaxle remain locked.
  • The engine shuts off when the key is turned to the OFF position without locking the steering or transaxle.
Blade Type
The ignition switch has blade-type terminals that engage with one multiple connector. The multiple connector is secured to the ignition switch by an integral connector fastener.
May 05, 2009 | 1992 Mercury Sable
I want to pull it
what year?
1999 electrcial ign switch. Lock cylinder is different
211-05: Steering Column Switches 1999 Town Car Workshop Manual
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Position the LH instrument panel insulator aside.
    1. Remove the pin-type retainers.
    1. Position the insulator.
  1. Remove the LH instrument panel insulator.
    1. Disconnect the courtesy lamp.
    1. Remove the insulator.
  1. Remove the lower instrument panel steering column opening cover.
    • Remove the screws.
    • Unhook the parking brake release handle and position aside.
    • Remove the cover.
  1. Remove the five bolts to remove the instrument panel steering column opening cover reinforcement.
    1. Loosen the bolt.
    1. Disconnect the electrical connector.
  1. NOTE: The ignition key should be in the OFF position.
    Remove the ignition switch.
    1. Remove the bolts.
    1. Remove the switch.
SECTION 211-04: Steering Column 1999 Town Car Workshop Manual
REMOVAL AND INSTALLATION Ignition Switch Lock Cylinder —Functional Lock Cylinder Removal
  1. Disconnect the battery ground cable; for additional information, refer to Section 414-01 .
  1. Remove the ignition switch lock cylinder (11582).
    1. Insert the ignition key and turn to the RUN position.
    1. Press the ignition switch lock cylinder release pin while pulling out the ignition switch lock cylinder.
Apr 25, 2009 | Lincoln Town Car Cars & Trucks
Remove ignition tumbler
lock cylinder removal
Section 11-04: Steering Column 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Ignition Switch Lock Cylinder Removal
  1. stf~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE ELECTRICAL CIRCUIT NECESSARY FOR DRIVER SIDE AIR BAG MODULE DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY. TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE BATTERY GROUND CABLE MUST BE DISCONNECTED PRIOR TO SERVICING OR REPLACING ANY DRIVER SIDE AIR BAG MODULE SYSTEM COMPONENTS.
  1. Remove the multi-function switch (13K359). Refer to Section 11-05 for the removal procedure.
  1. Remove the ignition/shifter interlock cable mounting bracket bolt and position the ignition/shifter interlock cable mounting bracket and the ignition/shifter interlock cable (3F719) aside.
  1. Remove the four steering column upper mounting bracket bolts and lower the steering column (3C529).
  1. Use a hammer and chisel to make a groove in the head of each of the two ignition switch lock cylinder bracket bolts.
  1. Remove the two ignition switch lock cylinder bracket bolts with a screwdriver and discard the bolts.
  1. Remove the ignition switch lock cylinder and the ignition switch lock cylinder bracket.
Installation
  1. Position the ignition switch lock cylinder and bracket and install two new bolts, tightening them only enough to hold the ignition switch lock cylinder in position.
  1. With the key in the ignition, verify the operation of the ignition switch lock cylinder. If necessary, reposition the ignition switch lock cylinder until it operates properly.
  1. Tighten the ignition switch lock cylinder bracket bolts until the bolt heads break off.
  1. Position the steering column and install the four steering column upper mounting bracket bolts. Tighten the steering column upper mounting bracket bolts to 9-14 Nm (80-124 lb-in).
  1. On vehicles equipped with tilt column, remove the upper mounting bracket retaining pin.
  1. Position the ignition/shifter interlock cable mounting bracket and install the bolt. Tighten the ignition/shifter interlock cable mounting bracket bolt to 4-6 Nm (35-53 lb-in).
  1. Connect the ignition switch electrical connector.
  1. Install the multi-function switch. Refer to Section 11-05 for the installation procedure.
  1. Install the steering wheel. Refer to the procedure in this section.
  1. Inspect the shift interlock system. Refer to Section 07-05 for the procedure.
Apr 07, 2009 | 1995 Mercury Tracer
96 ford windstar ignition probs
the ignition switch is the electrical part behind the lock cylinder where the key goes in.
Lock Cylinder Functional
Removal
  1. The following procedure applies to vehicles that have a functional ignition switch lock cylinder (11582) and keys. If the key numbers are known, the correct key can be made. Disconnect the battery ground cable (14301). For additional information, refer to Section 14-01 .
  1. Turn the ignition switch lock cylinder to the RUN position.
  1. Place a 3.17-mm (1/8-inch) diameter wire pin or small drift punch in the hole in the steering column shroud under the ignition switch lock cylinder. Depress the retaining pin while pulling out on the ignition switch lock cylinder to remove it from the housing of the steering column.
Installation
  1. Install the ignition switch lock cylinder by turning it to the RUN position and depressing the retaining pin. Insert the ignition switch lock cylinder into the steering column housing. Make sure the ignition switch lock cylinder is fully seated and aligned in the interlocking washer before turning the key to the OFF position. This will permit the retaining pin of the ignition switch lock cylinder to extend into the hole of the steering column.
  1. Using the key, rotate the ignition switch lock cylinder to make sure of correct mechanical operation in all positions.
  1. Connect the battery ground cable.
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove the upper steering column shroud (3530) by removing the four or five self-tapping screws. Remove key release lever (3F527) (if equipped).
  1. Remove lower steering column shroud.
Item Part Number Description 1 11572 Ignition Switch 2 — Ignition Switch Lock Cylinder Housing 3 — Slot in Lock/Column Assembly A — (Part of 11572) Pin B — Alignment Mark
Installation
  1. Adjust the ignition switch by sliding the carrier to the ignition switch RUN position.
  1. Check to make sure that the ignition switch lock cylinder is in the RUN position. The RUN position is achieved by rotating the ignition switch lock cylinder approximately 90 degrees from the LOCK position.
  1. Install the ignition switch into the actuator. It may be necessary to move the ignition switch slightly back and forth to align the ignition switch mounting holes with the lock cylinder housing threaded holes.
  1. Connect battery ground cable. Refer to Section 14-01 .
  1. Check ignition switch for proper function, including START and ACC positions. Also, make certain that the column is in the LOCK position.
  1. Install upper steering column shroud.
  1. Install the lower steering column shroud and key release lever (if equipped).
Feb 27, 2009 | 1996 Ford Windstar
Hyundai accent 1996 steering lock removal
try tunring the key and the whell at the same time it should release the lock.
Aug 05, 2008 | 1996 Hyundai Accent
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
