Question about Bissell 1631 PowerSteamer ProHeat Canister Vacuum
How do you hook up to the faust
Try to start using the machine and im having a hard time hooking it up to the faust
  • 36 Answers
This is an old machine. It comes with all the adaptors to hook the 1/4" water line to the faucet. You need to remove the arator from the faucet to hook it up and use the adaptors to match your faucet.
Posted on Jun 05, 2014
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
I have needles snapping and bobbin tangle
Try to repair in this order.
1) Your machine likely needs oil. Especially put a few drops of oil on the outside edge of your bobbin holder.
2) Try replacing your needle if you have some spares. If you are using a decorative thread (metalized) use a needle with a teflon lining on the eye (called metallic thread needle).
3) Try buying a better quality thread. Do not use generic thread in a sewing machine (i.e. "made in cheap country" with no brand name)
Please rate me..
May 04, 2011 | Vacuums
Only every 10 or so stitches holds. Probably a tension problem, but I don't have a manual and I've tried every setting and nothing seems to work.
A sewing machine should catch and tie the threads at any thread tension. If it's not tying and you're sure it's threaded correctly then it's out of time.
Timing a sewing machine is not difficult, but the point where you adjust the timing is often not obvious. I don't know what kind of machine you have so I can't tell you just where to set the timing, but you'll find the point in the lower section of the machine, there will generally be a screw or two that, being loosened, will allow the lower section of the machine (where the bobbin is) to turn while the upper section stays still.
You want to watch the needle and the tying mechanism: as the needle starts to come up the top thread becomes slack and the hook on the shuttle carrier (the piece that either turns back and forth or goes round and round, down below) catches the slack top thread and pulls it around the shuttle. If the hook is too early in its motion it can't catch the top thread, if it's late then the top thread is gone before the shuttle can catch it.
Timing the machine is simply a matter of determining if the hook is early in trying to catch the top thread or late. Turn the machine by the handwheel, watch the interaction of the needle and hook, adjust the timing if necessary and try it again.
If you don't see where to time the machine the next best thing is to take it to someone who knows, pay them, and watch where they're making the adjustment.
Good luck with it,
lp
Jan 19, 2011 | Vacuums
My Kenmore sewing machine timing has gotten off. I am sewing a big upholstery project and it starting bunching thread from the bobbin. The thread is so heavy that I had to put some pressure just to get...
Hello
Disassemble your bobbin case which is realy quite easy, clean thoroughly with a brush and air, paying particular attention to any rust that may have formed, and any thread that may have weazeled it's way into small but very incremental areas of your case.
Make sure your needle is not in backwards.The rounded side should be on the outside
. If threading is correct and your tension is properly adjusted , then check the hook for scratches. If you have ever hit the hook with a needle, it will be scarred and will catch the thread every time the upper thread passes around the bobbin case. the hook is the sharp point on the shuttle that holds the bobbin case. If it is scratched, polish it smooth with VERY fine sand paper
Make sure that your thread arm that rises and falls, constantly having tension running through it and that it is in fact staying in place.
Alternate between the metal and plastic bobbins - sometimes the plastic bobbins tend to chip
Dec 04, 2010 | Kenmore Vacuums
Attachment hose collapses when using wand
The thoe or the wand is clogged. Remove the hose at the machine end, reverse it and turn the machine on. This should **** the blockage out, the way it got in. If you hear the motor straining, it's still clogged. I've already taped a small hook, like a screen door hook onto a broomstixk and fished into the blockage to remove it. Be carefol. If you puncture the hose by pulling too hard, the hose will be ruined. Tahe your time and look for something unecpected, like a toothpick or a LEGO piece. They and vacuum cleaner friendly.
May 25, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Jan 05, 2009 | Vacuums
Floor Attachment
Try this,
With the floor nozzle off the machine spin the belt lifter around until the red arrows match. If you look at the side that attaches to the vacuum you should be able to see the belt up on the hook. If is not on the hook offf the machine you will never get the belt on. Once the belt is on the hook attach the floor nozzle to the front of the machine. At this point you need to spin the belt lifter back to where the green arrows match. Oh and another suggestion make sure your hieght adjuster the pedals with arrows are all the way up. Hopefully that helps you out.
Jul 04, 2008 | Kirby Generation 3 Bagged Upright Vacuum
My Hoover Steam Vac for my rugs works fine, but I don't have any suction when I try to use the hose and attachment for my upholstery. I went over the instructions dozens of times but still no suction.
Which type of hose do you have? One has a duct attached to it that fits into a slot in front of the recovery tak, make sure it is seated all of the way down. The other hooks direct to the machine, is it cracked where it hooks up? You can tell by lowering the handle and inspecting it. If it is, then you will have to replace it.
May 15, 2008 | Vacuums
I can't get the new belt on my kirby
I can't get the new belt on my Kirby
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The Kirby Vacuum has a removable head and bottom plate and the belt is hooked on by a hook inside of the Kirby head of the vacuum. You need to slide the belt onto the Kirby brushroll to the center and the dial in front of the Kirby vacuum does rotate to the right – so @ this time you would dial the belt clockwise and the inside hook will pickup the inside belt and continue turning the dial / hook until it stops – look inside to see if the belt in on the fan shaft – if it is then install the bottom plate back on the vacuum and then install the head back on the Kirby or if it is newer the head is already on the motor assm.
Plug in the vacuum and if the belt stays on and the brushroll is tuning you have done it right – if not reverse the situation, unplug the vacuum and start over with the procedure. The hook will dial the belt onto the fan pulley if done correctly. Example: try to turn the dial on the front of the vacuum to see hoe it works and the way the dial will turn so that the procedure will be easier. The dial does turn hard when dialing the belt onto the pulley.
http://kirby.com Contact Us by Phone
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
Apr 16, 2008 | Vacuums
Bissell 1631 PowerSteamer ProHeat Canister Vacuum Logo
134 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
