Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung HCN473WX I just finished replacing the IC's on my HCN473WX.......IT WORKS!!!!!! I don't have a lot of soldering experience, yet things went well. I have one issue....there are slight vertical lines in the picture (although very minor). I'd say the picture quality is about 90%. I cleaned tv with compressed air, the connections, double checked everything that I did - all looks good. From what I have read, I need to replace the capacitors on the convergence board - but that is only a guess. Is this the issue? If so, what is the part number? Thanks for all of your help up to this point!!!
    President:
  • 4,402 Answers
You may need to do convergence to align the colors up.
the only thing other than the ic that need to be replaced are resisters and if the resisters are bad you would not be able to move one of the colors, and blow out the ic you just installed.
Posted on Jan 28, 2008
What is the cause of samsung 20A5 cut tv only horizontal line appear
Vertical sweep problem. Vertical scan output section circuit should be checked. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window, to get gathered some pages which has the details of practical experiences to the author of that site. Check the voltage at vertical scan output IC. It comes from one among the LOT winding, after rectification. Check all the solder terminals at the LOT for any loose solder contacts. This is a common fault to most of the Samsung CRT TVs.
Oct 04, 2015 | Samsung Televison & Video
Help not sure
This maybe the problem why it is repeating. They didn't change all return resistors. they are different sizes all are probably smaller than 100 ohms. You will need the exact size and there are caps that maybe bad and maybe fuses also
Nov 25, 2007 | Samsung HCN473W 47" Rear Projection...
The sound on my toshiba theater view wont work i checked both the speakers and they are fine. Is this a simple fix?
hi,
If speakers are ok then the sound output ic of your tv is faulty. If you have basic knowledge in electronics then you can replace the ic. You can find the ic by following the wires from the speakers. It will end near the sound out put ic. The ic will be fitted on an aluminum heat sink. Note that number of that ic and get a new one from the nearest electronic spare part shop.For replacing the ic you need some tools like screwdriver de-soldering pump soldering iron, solder etc. All these thing will get from the spare part shop, if you don't have the same.Be sure to open the tv only after half an hour after dismantling the power because electrolytic capacitors inside it will store the power for some time.
ok
Jun 09, 2011 | Toshiba 50A50 50" Rear Projection...
My nokia 1600 phones problems Insert SIM
1st, try to clean pin of simcard, you cau use eraser, or maybe simcard ic problem. If you set drop it before, by using soldering iron, Solder with a lot at the end of the soldering iron tip, place on the surface of the ic, the process must be done carefully. never press the soldering tip, leave a lot of Solder is the press. but remember, you need to apply some sim Solder flux in the IC. If the problem is still not finished, then you need to change sim ic new.
Jul 27, 2010 | Nokia 1600 Cellular Phone
My 1600 is insert sim card problemi changed the charger connector.but no resp
Jun 27, 2010 | Nokia 1600 Cellular Phone
Hitachi Model 43FDX11D Will not Converge properly
its the ICs that go out on them just minor soldering and takes about an hour from start to finish. If you would like I can post a link where you can order replacements and they include free step by step instructions so you can do the repair yourself.
Apr 02, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Samsung HCN473WX/xaa
The tv shuts on and off by itself and the timer light flashes while doing so. I unpluged it for a couple of days and plugged it back in. The tv worked for about 5 hours and then it started shutting on and off again by itself.
Nov 26, 2007 | Televison & Video
Samsung hcm4215w Convergence board problem
Use PANASONIC STK's.They are expensive,but they hold up!Safe,durable repairs require OEM or BETTER quality replacement parts.
Sep 27, 2007 | Samsung HCM4215W 42" Rear Projection...
Red Gun screwy!!
You have a typical convergence problem here that happens on just about every tube type projection TV set ever made. There are two STK IC's that will need to be changed. Best thing to do, if you have any soldering experience on printed circuit boards, would be to get the service manual, locate the convergence amp IC's order the correct parts and not any replacement IC's that cost less the 20 bucks, and change the IC's. If you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Jun 30, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Red Convergence
Yes the IC's and possibly the fusable resistors went out on the convergence board of your TV set. If you have soldering experience and some pratical electronic's experience I would say go into the set find the Two stand-up STK###_### IC's and replace them. Bur if you have no experience, leave This repair for the pro's. They should replace both IC's at once and should cost somewhere arounf $250.00 to $375.00 to repai.. Good Luck
Jul 19, 2006 | Toshiba 55H70 55" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
150 people viewed this question
Jerry Greenberg
Jerry Greenberg
