Question about Refrigerators
RESTART INGLIS REFRIDGERATOR
HOW DO I RESTART AFTER A POWERSURGE MODEL IBT85001
  • 171 Answers
Unplug and plug in in 5 minutes. it takes time to start
Posted on May 31, 2014
I have 87 class motorhome with a ford 460 4bbl crab , we can drive it 5 min or 5 hrs but it will shurt off like if if u trun the key off,it will restart by trun the key off then restart it and it will go...
How old is the fuel pump?
Have you driven with a pressure gauge
tied to a wiper or taped to the windshield,
to watch fuel pressure when it quites
Sep 20, 2011 | 1987 Ford F 350
My 18 year old top freezer Inglis refridgerator has started to clunk. This noise began a couple of months ago. The clunk is fairly loud ( heard over the TV) and happens once every couple of hours. The...
The clunking is because the compressor has a broken mount and it clunks when it shuts off... this will eventually cause bigger problems, but probably you will need to replace the compressor to fix it...even so just check that a bolt did not come loose and that it may be a simple fix...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 06, 2010 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Need a batery for latop 3200
http://outerlimitstechnology.com/PowerSurger.aspx
At bottom you will see your Model number..comes with 2yr warranty
Feb 04, 2010 | Averatec 3200 Notebook
Wii will not power back up after sudden power loss any way to reset
This could be bad, also could be good.
1. Check your power outlet and make sure if you have a powersurge protector, that it hadnt tripped. If it is tripped, there is in most cases a button on the side of the powersurge protector for a reset.
2. In the case that this was not on a powersurge protector, try moving the Wii to another outlet and try it from there. If that doesnt work, buy a new power cable. If the new Cable doesnt work, the Wii is most likely Fried and will not be able to be operational again.
DrakeTech
Dec 24, 2009 | Nintendo Wii Console
When I push the power button nothing happens, no lights, no fan, no anything.
Hello
Thank you for using FixYa. Try these solutions
  • remove ram, and restart. any beeps?
  • Remove HDD and restart, any beeps or messages?
  • Has the unit had a powersurge?
  • Can you check to see if there voltage coming out of the power supply unit?
  • Make sure the DC jack on the laptop is firm - if broken they tend to be loose.
Hope this of some help
Thanks
Richard
Nov 17, 2009 | HP Pavilion ze4547wm Notebook
Refrigerator not cooling. Freezer is working
check if the fan are working, or for easy to dianose, defrose the refridgerator the whole night and turn on in the morn ing. if still not working, check again the fan inside the ref, if no noise or cant hear the motor fan, remove and replace ok
Aug 30, 2009 | Refrigerators
Kenmore Freezer works, but refridgerator is warm
Either there is a refrigerant leakage or if it is a no frost refrigerator air ducts to the refrigerator is closed due to frosting. Switch off the refrigerator for 3 hours and restart again.
Aug 15, 2009 | Refrigerators
Ice maker not working
Check the following:
* Water supply to the fridge
* Open the freezer compartment and check to see if the water inlet fitting is frozen. It can be thawed out with a hair dryer....carefully
* If not the above, check the water valve, usually located on the lower back of the unit behind a cover. It may be malfunctioning or is plugged with debris
* Make sure the stop arm of the ice maker (inside the freezer) isn't stuck in the up position
Apr 27, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Don't start smooth
restarting of refridgerator may damage your compressor motor due to overload.
when you switch off the refridgerator the compressor is in load condition, sudden restart overload the motor, it consume more current so the light going to dim.
solution. If your refridgerator have no delay circuit inside,
use a refridgerator stabilizer or attach a delay circuit,
if you have the the restart delay circuit may problem repair it.
Jan 18, 2008 | Refrigerators
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
