Question about Garden
We have purchased brand new john Deere, troy bilt and some other brand (I can't remember) lawn tractors over the last 5 years and they all go through about 3-5 belts from May to September. Each belt is getting 5-10 hours of use. What are we doing wrong?!?!?
    Genius:
  • 1,114 Answers
What comes to mind is that the belts are being overly stressed on the new equipment. I can't imagine going through so many belts per season. Are the belts breaking or stretching? What are you mowing, High grass, weeds, and at what engine speed ? How low is the mower deck set? What tractor speed is used. Does the top of the deck become clogged with excessive amounts of clippings? Does the mower bog down and strain? These are all factors that can shorten the life of a belt.
Posted on May 17, 2014
  • Missy Jun 19, 2014
    We are mowing about 4 acres of uneven terrain. The issue is probably that we should have a farm tractor not a lawn tractor. But my husband has been much more conscious of the deck height and really avoiding the rougher spots and it seems like it is better. Thank you for your response because it lead us/him to really look at what we might be able to do that could help.
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
  • 138 Answers
SOURCE: need an owners manual for a john deere lawn LT-133
you can go to www.deere.com and then click on residential equipment on the next page click on services and support and then enter your model number you will need your machines serial number to choose which model you have. here you view on online or order a new copy on cd
Posted on Sep 06, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
  • 12 Answers
SOURCE: NEED A DIAGRAM OF HOW TO ROUTE A BELT ON A TROY
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
Posted on Aug 13, 2010
How do I replace a belt for a TB515EC troy bilt lawn edger
The owners manual should have belt routing diagram, or Google Troy-Bilt, enter your model number and look at there PFD download manual.
Oct 03, 2014 | Troy Garden
Gardenway troy bilt
make sure chock is closed
Aug 27, 2014 | Garden
Just purchased Troy-Bilt Lawn Tractor from a friend. Can you tell me how to replace loose transmission belt so it will go forward. Belt is loose.
If you have a lowe's store near you they handle troy-bilt so get your model number off your tractor and they can get you the drive belt and a copy of replacement instructions.Thank you.
Apr 15, 2011 | Garden
I have a Troy-bilt lawn tractor model N779 Pony. The last time I used it, it ran fine. Now, after a couple of weeks, I can't seem to get any fire from the spark plug. I have checked the only fuse I could...
The two most popular switches that fail are the seat and break, if you have a ohm meter you can test each switch starting from the battery and moving down the line.
Jul 01, 2017 | John Deere 420,1020,2010,2020,2510,2520...
Tory bilt lawn tractor replaced with new battery
What most likely happened is the diaphram in the carberator has burst. It is a simple fix if you take your time, use reliable resources and be patient. The parts can be picked up at the local hardware store.
Mar 25, 2010 | Briggs & Stratton Garden
Need an owners manual for a john deere lawn LT-133
Sep 06, 2009 | Garden
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Aug 10, 2009 | John Deere Mower Blade 5 each
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
