Question about Gateway MX Computers & Internet
Gateway w730 k8x disassembly
Where is the ram location on this mx7533. do i have to take the whole laptop apart?
  • 11 Answers
SOURCE: Replacing Power Button Circuit Card on Gateway W730 K8X Laptop
The instructions for replacing the keyboard include the cover you have to remove to replace the power button pcb. The power button pcb is attached to the bottom of the bezel that covers the hinges/button array. In a nutshell you just remove the 2 screws indicated in the instructions, pry the hinge covers up a bit, then gently pry the bezel up from the bottom. remove the ribbon cable, pull back the small piece of tape, remove the three small screws holding the pcb on, and remove it from the spring clips.
Posted on May 01, 2009
  • 788 Answers
SOURCE: how do you remove the keyboard on a gateway
Sorry about your keyboard problems.
1. On your base unit, you will find this plastic piece below. Where I have marked a X, you will find 2 screws which need to be removed.
3. After you have removed these two screws, open the cover and lift the cover gently upwards. Removing it from unit.
If you look behind unit with cover opened, you will see 2 screws, ( one on each side.) The Plastic face plate has a 2 Ears the wrap around and can be clearly seen with cover opened.
Now, you will see 3 screws at to top of the KeyBoard. Shown below & marked by a X
X x x
__________________________ l l
l l
l KeyBoard l
l l
l l
4. Remove the 3 screws and carefully lift the keyboard upward at the screw points.
5. Once the keyboard is fairly loose, fold it over and allow it to lay on the armrest.
6. At this point, you will see the Ribbon cable where the Keyboard makes its connection.
Carefully lift the compression flange upward and remove the cable.
Enjoy your new keyboard, invest in a cover, as once you have leaked any wet material past the keyboard, its all over.
Readers, please rate your Technician’s
Thank you.
John Ray
Posted on Jul 13, 2009
Geekman
  • 32281 Answers
SOURCE: how to install gateway notebook laptop model No.
You can download the drivers for your modelGateway laptop from this WEB site, make sure you select your model laptop andthe correct XP or Vista drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Posted on Jan 26, 2011
SOURCE: we need a sound driver
Click on the link below and then click on the "Gateway" logo inside the page to download the W730-K8X sound driver:
http://www.alldriversdown.com/notebookdrivers/gateway-w730-k8x-driver
Posted on Feb 04, 2011
SOURCE: gateway notebook laptop model No.
**** that sh!t.... ,,/,, ,,\,, salo
Posted on Sep 02, 2011
Why will my Compaq laptop have a black screen?
Do u hear sound? If not laptop is not bootig up open the back of ur laptop locate ram memory take it out check for dust on the ram slot take dust apart put ram back in try to turn it on again.
Sep 01, 2014 | Computers & Internet
How to get into bios on acer without knowing pass code to bios??
the best way to get rid off that password is to remove the bios battery. Sometimes is easy to access, sometimes you have to remove the whole mother board (which means literally taking apart your laptop). check under and take off the easy caps like the one for the ram and maybe the one for the Hard drive... you should see a little battery plugged in to the motherboard either directly or with a cable... take it out and wait for like 10 secs and put it back in. If you have to take apart your laptop, I would suggest you find a video on youtube on how to take it apart. I could give you some tips if you decide to take apart the laptop your self.
May 08, 2012 | Acer Aspire AS5742Z-4512 15.6 Notebook PC...
I can only find one DDR ram slot!! there is only one slot behind the panel on the bottom. where is the other slot located. I have the tecra m2v-s330. should i just take it apart to look for it...i have...
The 1st RAM slot is under the keyboard. This slot has a RAM module installed when you purchase the laptop. The 2nd RAM slot is on the bottom of the laptop.
For removal of keyboard and keyboard replacement check out this WEB site.
http://www.batterycentury.com/toshiba-tecra-m2v-s330-keyboard-p-79168.html
Apr 14, 2011 | Toshiba Tecra M2V-S330 Notebook
RAM is low, my diagnostic suggests I upgrading my RAM for better performance. How do I do this?
RAM or memory is a physical component that needs to be installed in your laptop/notebook.
If you are technical enough to do this, you just need to purchase the exact memory module compatible for your laptop and install it yourself. Or, it will be better if you can have a local technician from a local computer shop install it yourself to make sure that it's installed correctly.
Apr 06, 2011 | Acer Aspire One PC Notebook
Ok took my whole computer apart and fixed a part that was loose but my ibm t23 turns fan runs and nothing else what can I do?
Well hopefully you wore a static band you may have shock your ram when pulling it out or putting it back in.
Dec 30, 2009 | IBM ThinkPad T30 2366 Notebook
Where is ram memory ?
Ram memory is on the underside behide a small opening requiring you to remove 2 screws. You remove the door and they are laying under that.
Aug 08, 2009 | Toshiba Satellite 1005-S157 Notebook
Upgrading RAM on Acer Travelmate laptop - can't see existing RAM module
Safely depends on your knowledge of computer hardware. If you know what you re doing, you can take the whole thing apart and replace any non-chip component you want (processor, drives, cards, etc). If you really look you can find sites that will tell you how to take apart a computer. If you don't know what you are doing and your current configuration works well, I would leave it for now, and wait until you can find someone that can help. Hope this helps.
Nov 09, 2008 | Computers & Internet
Upgrading memory on a V25 Samsung laptop
Make sure you are ONLY taking off the cover needed to change the RAM. Other screws may hold sensitive parts in place. Go to the laptops makers website and see which screws need to be removed. Its a good idea to also see if you need to change any settings in the BIOS once RAM is installed.
Apr 27, 2008 | Computers & Internet
Upgrading Memory on Packard Bell MIT GHA20
If you look along the top edge of the escape/function/del keys, there are several small plastic tabs that hold the keypad in place. Use a very small flat head screwdriver to push these back from one corner across to the other, gently lifting the keypad as you go. When you press back the last tab, the keypad should just pop out but take care as it's connected by a cable at the bottom edge of the keys. The RAM slots are located under a thin metal cover under the keypad. You'll need a very small philips head screwdriver to undo this. After installing RAM, replace the metal cover then pop the keypad back in, bottom edge first and just press down the top edge and the plastic tabs should snap back into place. Hope this helps!
Mar 08, 2008 | Computers & Internet
Computers & Internet Logo
97 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
