Question about Soyo Televison & Video
Why does screen has black bars all the way around
Have hit the zoom button with no success, checked menu can't find solution.
    Top Expert:
  • Soyo Master
  • 75,452 Answers
Sounds like T'Con fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Screen-shots to defective LCD are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Posted on May 18, 2014
5 Suggested Answers
SOURCE: Picture issue
It's not the TV it's the source( check settings in your DVD player or cable box
Posted on Dec 09, 2007
jerryg50
  • 1689 Answers
SOURCE: vertical black bar on plasma screen
This is usually caused by a screen addressing fault. The location of the fault can be on the main screen driver board, or in the area for the screen address processing. It can also be matrix fault with the drive to the screen.
You will have to give the set out for an estimate. From this you can make the decision if the set is worth to service or not.
Jerry G.
Posted on May 19, 2008
  • 63 Answers
SOURCE: I get sound on my tv but no picture. not even volume bar or menu
check to see if there is an image on the screen by putting a light close to it if ther is an image replace the backlight inverter
Posted on Jul 09, 2010
dbTVfixer
  • 79 Answers
SOURCE: i have black bar on
full screen is what you want on the TV
then set your cable or satelite box to "stretch" sd...that way, your TV will not distort actual 16x9 HD programming
Posted on Apr 12, 2011
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
How do I make the screen on my sanyo tv full- It has a black bar top and bottom
Your TV remote control (not the cable box remote control) would have to have a button that would allow the changing of the TV screen sizes. My Sony TV control has a button called, ' wide', and when pressed will change my screen to either, full, wide zoom, and zoom. Only zoom gets rid of the black bars on my TV. If no button, than the screen size will be determined by the broadcaster.
Feb 10, 2013 | Sanyo DP26640 LCD TV
Tv resolution issue
check zoom on either your tv remote or direct tv remote. someone has hit the zoom button . Its can be called zoom,picture, picture size. You want to get it back to normal. this can be done by hitting one of those buttons repeatedly until you see normal come up.
Apr 07, 2012 | LG Televison & Video
Black bar on the top and bottom during watching the tv
Hello
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
I'm not sure I have the right Question. I have a Toshiba Laptop. Somehow I have increased the page size that has placed the "X" to close the page out of sight.
Toshiba have a zooming utility. Here are the controls for it
Press and hold the "Fn" key and the "2" key to zoom in, and press and hold the "Fn" key and the "1" key to zoom out
Feb 28, 2011 | Computers & Internet
LG 50" the pitcher is off the screen each side by
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
Feb 27, 2011 | LG Televison & Video
There are borders on left and right of screen
1 solution that worked on my TV was to hit the format button on my controller and it gives me the option to do full,normal, cinerama, or zoom. These options stretch shrink or blow up the looks of the screen of what you are watching. I usually use full, I may get a few programs that are only half screen whether letterbox or where there is black bars on left and right but not many.. It may be the difference too between digital signal and analog signal.. If you do not have a format button go to your menu page and picture setup, see if you have any of the options of what I mentioned the full, normal, cinerama, and zoom.. Hope this helps you out.
Feb 04, 2011 | Samsung PS42P2S 42 in. Plasma Television
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
My ipod screen is enlarged
Your iPod Touch is not broken! You accidentally invoked one of the accessibility features which zooms the screen. This happens when you double-tap the screen with three fingers simultaneously. To undo it, double-tap again and drag three fingers up or down.
You can turn this feature off by going to Settings > General > Accessibility > Zoom.
Oct 20, 2009 | Apple iPhone Smartphone
Dvx100a showing black screens on lcd screen and view finder
You probably have the lens cap on, the iris dial closed, or you are in vcr mode rather than camera mode. You may also have the nd filter set to 1/64th, this is only for bright sunlight. When shooting indoors with low light, set the nd filter to off and hit the iris button until iris manual appears on the lcd, then dial the iris dial in front of the iris button up or down to bring the iris to around 5.6 f stop.
Feb 26, 2009 | Panasonic AG-DVX100 Mini DV Digital...
Televison & Video Logo
20 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
