Question about Hotpoint Washing Machines
Hotpoint washing machine only leaving in small amount of water
It's WML 730 740
  • 108 Answers
Sounds like its time for a new water pump.
Posted on May 17, 2014
  • 183 Answers
SOURCE: cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
Posted on Aug 22, 2007
jsrock516
  • 5911 Answers
SOURCE: washing machine clogged with dirt
You probably have sediment clogged in the inlet hoses and/or screens in the water inlet valve of the washer. First, turn off your water taps in the back of the washer. Disconnect the hoses one at a time and insert them in the wash tub. Turn the water taps back on to see if you are getting water through the lines. If not, you will need to remove the hoses and flush them out. If the hoses appear fine, inspect the sediment screens on your water inlet valve (this is where the hoses connect to). You can use cotton swabs to remove most sediment. If you cannot get the screens to clear and/or if sediment has gotten inside the water inlet valve, you will probably have to replace it. Try flushing the lines and cleaning the sediment screens, first, though. I hope this helps you.
Posted on Aug 04, 2008
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Posted on Dec 12, 2008
SOURCE: LG WM2355C water leaking under machine after washing finished.
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
Posted on Sep 16, 2009
beltronic205
  • 1461 Answers
SOURCE: Hotpoint Aquarius WF560, goes through cycle wash
Could need new motor brush kit>
Posted on Oct 06, 2009
Hotpoint wml 540 spinning but water not draining
Hi
It seems likely that your pump is either blocked or faulty. It could also be a blocked or kinked drain hose.
You haven't nominated a model.
Good luck.
Nomess
Aug 30, 2014 | Hotpoint Washing Machines
How do i remove the drum from a Hotpoint Aquarius WML 560 P
There is not much you can do to remove the drum of your WML 560 P Washing Machine...you can remove the bearings and door but you can't remove the drum personally. You'll have to take it in for service but here is a manual for you which you can read through to see if there is anything about removing the drum. Click on the link below to be directed to your Hotpoint Aquarius WML 560 P User Manual homepage...
Hotpoint WML 560 Instructions For Use Manual
Aug 26, 2014 | Washing Machines
How to remove the detergent dispenser drawer aquarius WML 520
Instructions for the machine, and specifically the detergent dispenser drawer, are here:
http://www.manualslib.com/manual/70853/Hotpoint-Wml-520.html?page=10#manual
It does NOT show how to remove the drawer. It is likely that the top of the machine must be "popped off" to do so. The best advise is to search for a Repair Manual if you simply must get the drawer out. I believe one of the manuals shown on this webpage may be the repair manual:
http://www.index-of-pdfs.com/hotpoint-aquarius-wml-520-user-guide-pdf.html
Most washing machine tops are simply a pressure fit that snaps on to the body. A firm grasp on the front sides of the top and a brisk pull may well pop it off.
Be sure to unplug the machine before you attempt any service!
Washing machines can be full of water AND electricity. That is most certainly a recipe for one, big, hydro-electric
Aug 04, 2014 | Washing Machines
Why does my hotpoint aquarius WML 720 will fill up but will not wash where would the filter be
you may have a bad door switch should check with a multi meter. can also check ur water pressure switch and motor coupler or belt if applicable
Jul 13, 2014 | Hotpoint Washing Machines
Hotpoint WML 730
Possible this seems to be an error. You need to start by check the inlet water flow, check the free flow, if not check the inlet valve or the valve drive. Also check the drain pump and see if there is no clogging, Now switch on and check voltage on the inlet valve, if absent check the main program controller. If water flows check
Nov 21, 2013 | Washing Machines
Hotpoint wml 730
use hotter water.
Sep 20, 2013 | Washing Machines
Spin not working properly, sounds ok but clothes are too wet once complete and the independent spin cycle leaves clothes soaking!!!
Sounds like a small blockage in the outlet pipes, possibly just in the filter but check all outlet pipes. Just done one the other day and it was a clothes button that had passed out of the machine through the pump to the outlet pipe but had turned sideways inside the outlet pipe.
Jan 25, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
