Question about Konica Minolta bizhub 750
How to fix it my bizhub 750 appear on screen question mark on 1 and 2 tray
  • Konica Minolta Master
  • 6,161 Answers
Mean the copier can not figure the setting of the guides in the draws set the guides for the correct papaer
Posted on Dec 29, 2015
3 Suggested Answers
resonatom
SOURCE: i wanna know how to reset the maintenance time konica minolta bizhub 750
bizhub c252 how do you reset enter serial number
Posted on Mar 09, 2012
  • 241 Answers
SOURCE: bizhub c220 tray 1 problem
pull out tray and check any paper is jammed is remaining at the back end of that tray
Posted on Jan 30, 2013
Hi, Bizhub c450: i have a problem on scanning over the rear tray if i put paper inside message will appears close section properly but there is no other error code appearing on the screen.
When you say the rear tray what do you mean, ON the document feeder tray or raising the document feeder up placing the document on the big glass. Never heard of a rear tray?????
Feb 04, 2015 | Konica Minolta bizhub C450P Laser Printer
How to fix ? the tray 1 tray 2 appear question mark on bizhub 750
That indicates the copier does not under stand the paper size in those draws so check the guide that hold the paper. ensure they are snug up against the paper also check that there is no paper stuck behind those draw preventing the sensors from reading the correct paper size.
Apr 28, 2014 | Konica Minolta Office Equipment & Supplies
Jam paper
Sir/Mam, does tray two work? if so use that mite need to have the rollers replaced in draw one.
Dec 13, 2013 | Konica Minolta Bizhub 600 750 Image...
Bizhub 600 reads wrong paper size in tray 1
Is tray 2 OK?
Any paper stuck behind the draw. Check the setting off draw one in user mode is it for that size paper?
Apr 23, 2013 | Konica Minolta Bizhub 600 750 Image...
Bizhub c220 tray 1 problem
Nov 19, 2012 | Konica Minolta Bizhub C220 Color Copier
I have a bizhub 750 that I cant keep the scanner from comming out of adjustment. It shifts down and away from the leading edge
Did you try it from the platen glass? make sure it's the just the ADF and not the optics. Try it from different trays.
Oct 01, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printing envelopes
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
Jun 29, 2009 | Minolta bizhub 200 All-In-One Printer
Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Mar 29, 2008 | Minolta bizhub 200 All-In-One Printer
Konica Minolta bizhub 750 Logo
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
