Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Can I fix refrigerator that no longer defrosts?
Freezer is no longer defrosting. Fridge runs longer than normally.
    New Friend:
Maybe it some sort of losing your freon you may need to refill it again but first do this //
1. check the bottom of your fridge, there is an air intake grill at the bottom, make sure this is clean and free of lint/ dust
2. make sure the thermostat inside is set properly
3. don't overload the freezer section. the cold air for the fridge comes from the freezer, and if you have too much stuff in the freezer, it will stop the air from being able to flow to the refrigerator section
4. Finally, if you're a little bit technically capable, check the back of the refrigerator, for a small 1/8" hose going down the back of it- make sure this line is clear and free of gunk
Posted on May 17, 2014
22yooper
  • 828 Answers
SOURCE: Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Posted on Jul 16, 2008
dididsaythat
  • 291 Answers
SOURCE: Freezer freezes but fridge does not get cool
DO u have frost build up in the freezer ? If so you have a defrost problem.. defrost thermostat, timmer or heaters. You can by-pass the thermostat cut it and tape the wire together and put it into defrost with the timmer by clicking it to the right until it clicks the heater you need to ohm out .. the defrost timmer will be good most of the time if it comes out of defrost ... ref. will start running again when u test the defrost thermostat here is a diagram that may help
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?diagramPageId=00011&componentDescription=AIR%20FLOW%20AND%20CONTROL%20PARTS&documentId=00016472&modelNumber=1068562782&productCategoryId=0160000&brandId=0582&modelName=REFRIGERATOR&backToLink=Return%20to%20Sub%20Components
Posted on Aug 24, 2008
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
rylee_smith
  • 8619 Answers
SOURCE: all items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 30, 2009
SOURCE: Kenmore fridge electronic defrost manual start procedure
unplug overnight started OK
Posted on Jun 22, 2009
Fan in freezer has stopped working,have defrosted and fridge seems to be cooler.
Simply defrosting the freezer might solve your problem. Sometimes ice can form on the fan or fan motor, and of course, prevents the fan from turning.
If there is ice here, your refrigerator isn't defrosting properly. This sounds like a defrost problem that may need a part replaced. Check out this site for details and photos. Refrigerator Defrost Parts
May 07, 2014 | Refrigerators
I bought a French 3-door Refrigerator about three years ago and the freezer recently stopped cooling and then the refrigerator stopped cooling. The refrigerator runs but doen't cool. Any help here?
Yes. You have a faulty automatic defrost cycle. If you manually defrost the freezer, then restart the fridge and it is back to normal. It is a sign that the defrost is faulty and you will need a technician to fix it for you
Apr 04, 2011 | LG Refrigerators
Fridge section not getting cold whilst freezer operating as normal.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | Westinghouse Refrigerators
I have just defrosted the lower half of my fridge freezer as it built up a big ice block at the back? i put the theromastat on 3 and ice is has started to build up again on the back of fridge
Some ice build up is normal, but it should go away when the unit defrosts...if it continues to build then the defrost is not working correctly...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 02, 2010 | Refrigerators
I've had a Samsung fridge for 6-7 years, it's a small/medium fridge/freezer with the freezer at the top (sorry, don;t have the size handy). The freezer works fine, however the fridge no longer makes...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 27, 2010 | Samsung Refrigerators
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Freezer no longer freezing and refrigerator is not cold enough either.
  1. check if the evaporator fan motor is running (inside the freezer)
  2. Same for the condenser fan motor on the bottom in the back of the fridge
  3. Clean condenser coils underneath or in the back of the fridge
  4. if there is a frost on the back wall in freezer - you've got the defrost problem, check defrost heater, defrost bimetal thermostat, and defrost timer
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
26 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
