Question about Nintendo Wii Console
Drums connection how do you connect the left high hat? the cable is too short
    President:
  • 2,777 Answers
I assume this is for rock band? It definitely should fit, make sure you are connecting them to the right inputs, try unplugging everything and plugging again paying careful attention to the labels. Let me know if it still doesn't work =).
Posted on Jun 24, 2009
Yamaha dd55c hi hat foot pedal not working
This could be caused by a number of things.
1) Socket on DD55 could be broken
2) Cable could be broken
3) Plug at end of cable could be broken
4) Switch in foot unit could be broken
Eliminate each by working through 1 - 4 using a multimeter and then repair accordingly once you have found the fault.
Jun 30, 2014 | Yamaha DD55C 7-Pad General MIDI Digital...
Hi-hat is triggring sound while in the closed position. and splash can't be produced
Check the following on a VH-11 HiHat.... both cables connected correctly, top playing surface is clear of the inner ring on the lower sensor when in the fully up position, power the module OFF, keep sticks & foot well clear of the HiHat then power ON, finally check the calibration settings (I assume the 15 has that as my TD12 does) If still nogo check on the VDrums forum website....
Oct 23, 2013 | Roland V-drums Td-15kv V-tour Set...
Where does hihat control cord go
The hi-hat trigger goes into trigger #1. Using a footswitch will change the hi-hat trigger sound to a closed hi-hat. On page 8 of the user manual is the list of triggers and their assignments. Note that some new triggers from newer drumsets use TRS cables because they have two sensors within the drum head... Often the new ones have a rim shot snare trigger as well as a trigger for the mesh head. These newer different brand triggers would require special cables to be made to attempt to use them with the DM5. The DM5 is older technology now but is still useful.
Jul 25, 2011 | Alesis Dm5 Drum Module 18 Bit
The left side seems to have a faulty connection with the sound being absent or intermittent. Occasionally it sounds normal. Waggling or tapping the actual ear phone seems to activate the sound but dfficult...
You might have a bad connection on the wiring terminal inside the left speaker where the left and right join the main cable. Here is a link:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
Nov 25, 2009 | Bose On-Ear Headphones
Hi Hat pedal not fuctioning
Obviously the hi hat trigger does not function properly, it either does not generate enough signal, or the signal doesn't come thru well, or the signal comes thru well but it doesn't trigger the sound unit properly.
This could be caused by:
- too low input sensitivity setting on the sound unit for the hi hat input
- a displaced or loosely fixed sensor (trigger) on the hi hat
- a partially damaged sensor
- a bad wire connection at the sensor
- a bad wire connection at the sensor connector
- a dirty contact on the sensor connector
- a dirty contact on the cable connector at either side of the cable
- a bad cable, a broken wire or poorly soldered wire in the cable connector at either side of the cable
- a dirty contact on the input connector of the sound unit
- a bad solder connection on the input connector of the sound unit (inside the unit)
- a bad solder contact on a component or a faulty component associated to that particular input in the sound unit (capacitors, resistors, diodes, transistors, ICs, etc.)
To rule out a damaged cable, just change it and see if the hi hat works ok with another cable, if it does, the cable was damaged.
If the sensors are interchangeable , try to swap the sensor with a sensor from another cymbal, see if the other sensor works well, if it doesn't, then the sensors are not the problem.
To see if there is a problem with the input on the sound unit, connect another cymbal to that input, if it works well, the input is not the problem, if it still doesn't work, check sensitivity/trigger level setting, check connector contacts for any dirt, check connector and component solder contacts inside the unit.
Also, try to connect the hi hat to another input on the sound unit, if it doesn't work well after that, there's a problem with your hi hat (sensor, wires, dirty connector on the sensor), if it works well instead, then there's a problem with the hi hat input on the sound unit (sensitivity/trigger level, dirty connector contacts, bad solder contacts, damaged components)
Another thing: try your hi hat connected as is, but have someone move the cable connectors while you play it.
If moving the cable connector at the sensor side results in a change of operation (it might start working well for an instant or so), you definitely have a problem with that connection (check for bad wires in sensor connector, cable connector and for dirt on both connectors' pins).
If moving the cable connector at the sound unit input side results in a change of operation, then there's a problem with that connection (check for bad solder points on the input connector inside the sound unit, check for bad wires in cable connector, check for dirt on both connectors' pins).
I hope you can fix it, otherwise just post me some feedback if anything seems unclear, i'll be glad to assist you.
regards
3rq8 (Triarcuate)
Aug 04, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
No picture, high voltage cable sparks at left tube/gun at turn on
It sounds like you have a shorted picture tube.
You should call a good TV Tech to confirm this and get an estimate.
Jul 29, 2009 | Mitsubishi VS-70707 70" Rear Projection...
What do i need to connect to the net with a siemens ms 2228 laptop please
To connect to the Internet you need decide what type of service you want/need.
1. You need to decide how to connect to the Internet, by DSL, or cable.
2. You need to select Internet Service Provider and select a download plan hat suits you needs and budget.
3. You need to decide how you want to connect your laptop to the Internet, either by a network cable or by wireless connection.
When you select the ISP and tell them your laptop model and what you require, they will advise you hat equipment you need etc.
Mar 23, 2009 | Fujitsu Siemens Computers & Internet
DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Sep 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Nintendo Wii Console Logo
26 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
