Question about Dometic Rooftop RV Air Conditioner
Can you recharge a model # 57915-531 air conditioner
The fan motor had seized up and had to have it replaced. Now the unit is not cooling at all. Could it be needing freon?
    Genius:
  • Dometic Master
  • 1,363 Answers
They dont have a service valve for charging. probably electrical issue.
Posted on Aug 16, 2015
  • 587 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 52 Answers
SOURCE: Dometic duo therm does not cool or heat...
it should never have to be recharged unless there is a leak. so you should isolate the leak with dye injectable into the system w/ the freon and correct it, then fully recharge system.
Posted on Jun 10, 2009
james3751
  • 614 Answers
SOURCE: can my duo-therm air conditioner on my rv be recharged?
These unit can be recharged. 134A. You NEED A SERVICE TECH THAT KNOWS HOW TO CHARGE UNIT.RUS
Posted on Jun 25, 2009
  • 127 Answers
SOURCE: My RV rooftop air conditioner fan has seized up
Whether to replace the entire unit or repair it is a tough decision. If the unit is not very old and was working fine before the fan motor froze up, then I do not think that it is necessary for the entire unit to be replaced. With a new unit of course comes the new warranty.
It is not difficult at all to replace the upper unit of the air conditioner. What you have to look for and make sure of is that the ceiling pack or Air Distribution Box (inside unit of AC) that you currently have is compatible with the new Upper Units. Get the part number off of the inner unit and make sure that it is compatible with the part number of the new upper.
Again, it is much less expensive to replace the fan motor than the entire unit (especially Dometic). You could replace the fan motor and get another 10 years out of the AC or, you could replace it and only get 1 year out of it. That is your call.
Just a word of precaution. Dometic Air Conditioners are very hard to find right now due to an industrial accident that occurred at the AC plant. Most distributors and service centers are 6 to 8 weeks out on getting a Dometic AC in stock. That is something else to think about.
Hope this helps,
Jeff
Posted on Jul 06, 2009
  • 534 Answers
SOURCE: DUO THERM 590 QUICK COOL AIR CONDITIONER PART NEEDED INTAKE GRILL
you could contact the manufacturer of the rv and they can help you with you search. Hope this helps
Dave
Posted on Jul 16, 2009
I have a Goodman a/c unit. Fan stopped shut off
replace the motor the bearing has seized up.
Aug 27, 2014 | Heating & Cooling
After turning the unit off, there is a hum for a few minutes, no fan noise, just a hum, and then it turns itself off eventually. The unit is about three years old and is otherwise cooling the room.
From what you have described, it sounds like the fan motor may be seized. In which case, it should be replaced. Depending on the age of the unit, it may be better to replace it than repair it. As parts and labor to repair it, can be almost as much as purchasing a new unit. As the motor assembly alone, runs about $150.00 + Labor.
I hope this has helped you and thanks for choosing FixYa.
Aug 10, 2011 | Friedrich CP10C10 Wall/Window Air...
I have two senville mini split 18000 and they both frost up with in 1 Hr. of use both have been pumped out and recharged
Dear Friend! Before recharging gas.did you check leak testing? If not, again you will same problem.
And some more reasons for frost up:
1. Indoor coil & air filter dust blocked-clean it. 2.Less rpm of indoor fan motor- replace capacitor or motor.
Thanks, it's helpful to you.
Jan 10, 2011 | LG LS-K1830CL Cool Mini Split Air...
Model TSSU-48-08 Sandwich/salad prep table. I think it is a 1998 unit, so it has some age but is in nice shape, like new. I need to get it working. Doesn't cool. Compressor motor, evaporator fan...
You have it figured out...get it tested for leaks, fix them and recharge the unit...
Make sure to get a professional to do the work...
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 26, 2010 | True 598-TSSU608ADA SandwichSalad Unit 155...
MY unit is not cooling. fan in not turning, top
It sounds as though your outside motor has failed. If you have a long shafted screwdriver, you can attempt to spin the motor to see if the motor has seized up. Caution should be used as the motor may start if the unit is calling for cooling when you attempt this. If you can manually start the motor, then chances are the capacitor has failed.
Check it out and replace the motor if need be. That should get you back up and running.
May 26, 2010 | Goodman CKL24AR24 Air Conditioner
Fujitsu Air Conditioning split unit Model
Your compressor is seized up. shut down unit and let compressor cool down, it may start again but probably needs to be replaced.... sorry for the bad news,
Nov 10, 2009 | Fujitsu 24C1 Air Conditioner
Hope this helps,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Rv Roof top ac unit
Fan motor bearing getting hot and seizing on the shaft. Just changeout the fan motor...
Aug 30, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
78 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
