Question about Whirlpool 19.6 cu. ft. Upright Freezer EV200FXM
Whirlpool Upright Freezer model #EV171NYMS04 door does not close
iwillfixforu
  • 619 Answers
SOURCE: door will no vacuum seal closed
Are you sure compressor is running? If it is make sure the evap fan is running. You should be able to hear the fan when you open the door. If ypou do not hear a fan running then fan has gone bad. 4390914 and approx cost is rediculous in my mind but it is approx. 150.00 to 160.00 . Crazy for a fan motor.
Posted on Jan 29, 2010
  • 454 Answers
SOURCE: Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Posted on Mar 13, 2010
  • 3 Answers
SOURCE: whirlpool upright 2 door freezer
I suspect your door is distorted and the seal is leaking.
Posted on Mar 18, 2010
  • 389 Answers
SOURCE: whirlpool upright freezer evl209nbtq making noise
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
  • 122 Answers
SOURCE: I have a Whirlpool Model EV 200N Upright Freezer
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
Posted on Aug 28, 2010
Kenmore upright freezer not freezing
Kenmore & Whirlpool refrigerator frost build up in freezer not ...
? 7:02
www.youtube.com/watch?v=gVXT7pZyk_o
Sep 12, 2013 - Uploaded by ApplianceVideo.com Service a Kenmore Upright Freezer which has the following problems: Not Cooling Properly At: http ...
Freezer Troubleshooting - What to Check Before You Call a ...
www.realestate.com > Realestate.com Blog > Articles
Aug 12, 2012 - Alternatively, if the freezer is in a defrost cycle, it will not kick on immediately, the temperature ... Refrigerant circulates through coils, spreading coldthrough the unit interior before .... We have a kenmore upright deep freezer.
Sep 19, 2015 | Kenmore Freezers
I Have A Freezer Model Fuf17svrww.the Door Open Light Control Is On And Sounds and the door is completely close
Check the door switch is being closed when the door closes. The door may have dropped just enough to allow the switch not to be activated by the edge of the door.
Apr 18, 2014 | GE FUF17SVRWW Upright Freezer
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
I have a Whirlpool Model EV 200N Upright Freezer which is having ice freeze on the bottom of the freezer. What can I do?
Aug 28, 2010 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Door will no vacuum seal closed
Jan 28, 2010 | Whirlpool 17 cu. ft. / 481 liter Upright...
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 | Freezers
Bubbling sound coming from the bottom of my freezer
There is a vacuum build up in the freezer compartment when you close the door. This can make the door difficult to open. You can overcome this by sticking a small lollipop stick to the bottom part of the door gasket. This will act as a vacuum breaker.
Mar 06, 2009 | Whirlpool Upright Freezer EV161NZRQ
Whirlpool 19.6 cu. ft. Upright Freezer EV200FXM Logo
Top Whirlpool Freezers Experts
christian nielsen
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
