Question about Senville 24000 BTU Energy Star Ductless Mini-Split
Senville ductless 24000btu P4 error
Hi, when i turned on my Senville mini split the fan will go on for 2 - 3 minutes and then the air conditioner will display P4. On the error code description, it say inverter compressor drive error. Everything was working fine before and there was nothing wrong with the electrical connection. Please help, Thanks in advance
How long is your line set?
Posted on Oct 06, 2015
contact the manufacturer to see if they can help you with this type of failure. the compressor and its controller are the two most expensive parts of the unit to repair.
Jul 29, 2016 | Inverter Heating & Cooling
Display shows ec and then flashes 7 times
Don't have a answer but my 12000 btu is doing the same thing
May 13, 2016 | Senville 24000 BTU Energy Star Ductless...
How to replace the blower in a Senville SENA-24HF Mini Split Wall unit?
You have to pump down the a/c and remove the indoor unit. If not
The bottom of front side of front panel there are 3 screws. Unscrew and remove the front panel. Then unscrew PCB board. Then Unscrew the coil, and slightly keep upward and replace the blower.
Sep 08, 2015 | Senville 24000 BTU Energy Star Ductless...
Panasonic mini split air conditioner css9nkua error code h99 what does it mean
12.11 Freeze Prevention Control 2
• Control start conditions
o During Cooling operation and soft dry operation ? During thermo OFF condition, indoor intake temperature is less than 50°F or ? Compressor stops for freeze prevention control
o Either one of the conditions above occurs 5 times in 60 minutes. • Control contents
o Operation stops
o Timer LED blinks and "H99" indicated
You may need the assistance of a technician. Service manual located here:
http://www.mcaair.com/docs/panasonicac/CS9NKUA%20CS12NKUA%20Service%20Manual.pdf
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
Panasonic mini split air conditioner css9nkua. what does run code h99 mean?
H99: Indoor heat exchanger anti-freezing protection
Causes: - Insufficient refrigerant;
- Air filter dirty;
- Clogged cross flow fan.
Senville mini split displays a "defrost" symbol????
It's a heat pump and that is how they work. But it shouldn't be cycling so much unless you live in Minnesota? The colder it is outside the more chance that the outside coil will freeze so it will go into defrost. It may be low on charge or have leak as well. Call a tech to verify.
Apr 13, 2014 | Senville 18000 BTU Ductless Air...
5mint cooling 5minuts heating
The reverse valve and silenoied are bad, you need to change them or replace the condencer.
May 04, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Soleus KFGHP-09-ID Mini Split
This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
Phil Hodges,
Tech support Soleusair
May 18, 2008 | Soleus KFS18GW 18,000 BTU Heat & Cool 230V...
Senville 24000 BTU Energy Star Ductless Mini-Split Logo
585 people viewed this question
Top Senville Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Senville Heating and Cooling Expert? Answer questions, earn points and help others
