Question about Connex Radio Communications
Courier centurion pll no transmit audio - Connex Radio Communications
    Genius:
  • Connex Master
  • 1,795 Answers
Could be in your finalwhere the problem exists.Try flexing your board by pushing down in the center to see if any noise comes through.
Posted on Sep 11, 2014
2 Suggested Answers
  • 11 Answers
SOURCE: i need a wiring diagram for the courier Centurion
The center of the mic pin is your hot, and the outside is the ground. On the mic, the white wire is your hot Audio, and the shield is the ground.
Hope this helps,
J.R.
Posted on Jan 24, 2010
RE Cobra 29 lx camo cb antenna warning
get a frequency counter and check to make sure you are on frequency.reset your SWR Recheck the pll section and the frequencymake sure everything is soldered good ,no cold solder joints.Could be a bad crystal or a bad IC .Check for power ratings on the PLL. If they are good your radio should be ok
May 10, 2016 | Cobra Radio Communications
How do i wire my astic mic to courier centurion
first you need to know if its compatible, most are, but not all,
Astatic mics are basically a 6 wire mic/yellow is not used most of the time. second,find the wiring code for your radio then you have to match the color code to the mic, you can do all of this by searching online.
Jan 14, 2015 | Radio Communications
Couier centurion pll no modulation
may be the mic's element/audio chip
May 17, 2014 | Cobra 150 GTL DX Base CB Radio
My hr2600 shows error 3 when it is keyed up and does not transmit
0 = Transmitter Timeout timer has timed-out
1 = Transmit Frequency is lower than TX Lockout Lower Limit
2 = Transmit Frequency is greater than TX Lockout Higher Limit
3 = Phase-locked-loop (PLL) won't lock at this transmit frequency
4 = PLL is intermittently coming out of lock during transmit
*If your radio displays error 3 or 4, don't keep trying to transmit on this frequency. The cause of the problem could be low power supply voltage to the radio or the radio's VCO loop needs adjustment. Refer to a qualified technician for service. Contact the installer of the chip first. If, however, you installed the chip yourself, contact a qualified technician for service.
Sep 24, 2013 | Magnum DeltaForce CB Radio
Cobra 1000 will not receive or transmit.
Sounds like a problem with the VCO / PLL Circuit since nothing happens in RX or TX. Check to make sure you have the correct supply voltages to start with and also check to see if you have 10.240Mhz. Use the service manual and go through the PLL/VCO alignment section. If anything is missing then you at least know where to look.
Apr 30, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
148 gtl receive works fine transmit has no power
Have you checked the 2sc2166 or the 2sc1969? Those are the RF Driver and the RF Final output transistors.
Jan 07, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 25 ltd will not transmit it will on pa mode and it recieves i replaced the final pll chip audio chip.can you help
there is the problem. a $150 repair bill for a $ 25.00 problem. After you put in this new IC did you put it on a scope to check it out.How about a frequency counter to make sure you were on the right frequency? take it to a tech and let him fix it .
Oct 16, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
Radio comes on will not talk or recieve
Is the meter moving on key up or another radio transmiting to it?
Switch for S/RF, CAL, SWR.........set to S/RFRF gain knob full clockwiseSquelch counter clockwise
If just audio is missing my be Audio Chip i think IC3Bad Crystal or solder to it.May be bad PLL chip any of these 3 could affect both TX and RXI do not suspect mic as there would still be audio just at low volume on receive.
Oct 03, 2011 | Cobra 29 LTD CB Radio
I need a wiring diagram for the courier Centurion cb mic, it has a phono jack pin tip .
Hope this helps,
J.R.
Jan 19, 2010 | Radio Shack TRC-447 CB Radio
Have Cobra 29 LTD CB Radio w/ bluetooth. Power comes on. Does not receive or transmit. What's wrong?
Sounds like the PLL circuit....... no channel synthesizer will kill the transmit and receive...... bad crystal or IC could be at fault or if someone has attempted to add more channels could also be cause.
Dec 20, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jim Y
Jim Y
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
