Question about Garden
How do you put belt on tiller #GIS2130A28
I don't know the age of the tiller but it is at least 25 years old
    Top Expert:
  • 3,698 Answers
I just bend the guides back slightly, just enough so that the belt passes, placing the belt on the second pulley, turning the pulley slowly while the belt walks on it. the guide pins I then return into place with a hammer. The correct way is to remove the pulley, put the belt onto it the reinstall the pulley with the belt on it. Your may be different. If different please give the make and model.
Posted on May 17, 2014
4 Suggested Answers
SOURCE: belt assembly on a garden star tiller
Contact Northern Tool and Equipment: "Ardisam 5.5 HP Rear Tine Rototiller" (they don't call it a GardenStar anymore) it is Item # 26289.
Buisiness/Consumer Sales: 1-800-221-0516 (24/7)
Customer Service: 1-800-222-5381 (8-5 cst m-f)
Product Information Assistance: hal@northerntool.com
My wife and I are dealing with this as well. We can't get ours to go in reverse now.
Posted on Mar 29, 2009
SOURCE: both belts shredded. Atlas garden tiller model 12 -5100
I bought a repair manual from Clymer and found the belt sizes for my Atlas 12.5022 tiller. The manual lists a 1/2 inch by by 36 inch forward belt and 1/2 inch by 32 inch reverse belt for the model 12-5100. Good luck. Don't bother to buy the Clyme manual. It isn't very complete.
Bob Mortimer
mortimer5918@bellsouth.net
Posted on Apr 27, 2009
  • 17 Answers
SOURCE: My tiller needs belts, and I don't know how they
Assuming you have not already removed them make yourself a detailed sketch of how the belts are routed (your owner's manual should also show how how they go back on). Remove any guards or retainers (that keeps the belts from jumping off the pulleys) and put the new belts on just like the old ones. Reinstall any guards or retainers you removed. I know this may look complicated but if you take your time and figure out which belt does what it is not all that difficult. Hope this helps.
Posted on May 25, 2011
I have a Rotical Supermatic rototiller I need a spark plug for it the old one is called a "lawn mower 4051" if any one can help that would be great! the tiller is probably 25 years old but runs gre
I crossed that number and it comes up as an autolite plug. The NAPA number for a champion plug is 805 or an NGK 7928. Take the old one in and compare them but that is the best I can do
Jan 20, 2013 | Garden
May 21, 2011 | Briggs & Stratton Garden
I have a 40+ year year old TB Horse tiller I need to know how to tighten up the slack in th belts and adjust the reverse disk. I was only 8-9 when my mom bought it for my dad. the main number I saw was a...
Do you know what Horse Power your tiller is? I have a manual for a 7 HP Briggs Troy-bilt that I bought in 89. I presume that you replaced the original belts with new ones?
May 14, 2011 | Troy bilt Horse Roto Tiller Parts Manual...
25 years old,top load. put on new belts 3 weeks ag...
Timmer may be bad. Bad contacts on timmer for spin mode. Check to see if timmer goes though cycle to end. Also check lid switch.
May 17, 2010 | Washing Machines
My troy built is several years old and recently the tires went flat. I know there is a transmission disconnect but the only manual I got with it was a Briggs and stratton motor guide. I never paid...
There is no actual transmission disconnect on the mower. If you put in neutral the belt would need to slip on the pulley in order for it to be pushed or roll freely. This usually doesn't happen.
Apr 10, 2010 | Troy-Bilt Pony Garden Tiller
I am having trouble starting my Craftsman 5 HP tiller. It is about 25 years old, but it only gets used about 1 hour/ year. It almost starts, but doesn't. Would a dirty air filter or old oil cause this...
The carburetor jets could have gotten dirty or gummed up enough not to let the fuel flow any longer, depending on how well you winterize it between seasons. You could try some starter fluid, but you might be better off having someone put a new return spring in the winder and rebuild the carb.
Of course the air filter would like to be clean, as well.
But I should think that's not what's keeping it from starting. If you hadn't been washed thoroughly for 25 years, how would you feel about getting up in the morning?
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 02, 2009 | Garden
Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Mar 21, 2009 | Mantis 2-Cycle Tiller
Dryer won't start
belts, as in 2?? you do have an old speed queen. did you make sure the blower is able to turn freely?
if so then you most likely have a bad winding in the motor. it is costly to replace and you should go out and get a new dryer. too much money to fix this old unit.
by the way the model number is under the front panel in the center, on a metal plate.
doesnt matter since you know its 25 years old and its time to update.
Jan 22, 2009 | Dryers
Age problem
Since you have the answer, the easiest way to work with this is to work with real numbers and break it down. What are the knowns?
Rose + 25 = Dad
10 + 25 = 35 (today)
5 years ago, Dad (then 30) was 2x old as Rose will be 5 years from now (+5), or (30/2) -5 = 10
You can also put this into formulas
Rose + 25 = Dad
Dad - 5 = 2 * (Rose + 5)
So, if Dad = Rose + 25, you can substitute one for the other in the 2nd formula, like so:
(Rose + 25) - 5 = 2 * (Rose + 5)
Rose + 20 = 2 * (Rose + 5)
Now, you can solve for Rose and eventually come up with 10
I hope this helps.
Jul 20, 2008 | Computers & Internet
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
