Question about Cycling
Installation shimano st-m020-l
Arme change Destroyeur
Exploded view of shimano gear shifter altus st-ct90
Sorry, Shimano never intended those shifters to be taken apart and serviced, so they didn't release an exploded view. Here's a link to the orginial EV document. http://bernd.sluka.de/Fahrrad/Shimano/TM/ST-CT90_1995.gif
Mar 30, 2017 | Shimano Cycling
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
Need advice for Shimano ST-7900 nameplate replacement
Don't know if you have an exploded view diagram of the levers . If not you can download from http://techdocs.shimano.com/techdocs/index.jsp
In the road bike drop down list select Dura-Ace, go down to ST-7900 and select document EV-ST-7900-2874. I don't advise you to take mech apart unless you have special tools and bags of experience handling complex mechs. However you will see that name plates are held by single screw which should be no problem.
Nov 19, 2009 | Shimano Cycling
How to dismantle and re-assemble the lever mechanisms as the levers are slipping when operated. Hopefully they are not worn internally. They are Shimano ST-T400 shifter/brake.
Here's the diagram:http://fish.shimano-eu.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-T400-S-1970_v1_m56577569830613258.pdf The lube in them tends to dry out and harden over time and needs to be flushed out with whatever is safe for the parts (cleaner/degreaser) and then relubed with some high quality lubricant. The spray stuff doesn't stay around long enough. Ask your local bike tech what he uses.I used saxophone key oil.
Aug 08, 2009 | Cycling
Shimano st 7900 shifter,left lever apart and how to reassemble
You can download an exploded diagram of the 7900 series STI shifters here:
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-7900-2874E_v1_m56577569830670749.pdf
You can reassemble them according to this diagram.
May 11, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Cycling Logo
56 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
