Question about Dryers
My Cabrio dryer, model #WED5600XW0 won't stay running
The dryer will tuen on, the drum sound like it is off kilters, then it stops and the PF light flashes. Accordin to the manual, you hole the pause button down; it will start, which is does. It just keeps stopping. What is the issue?
  • 114 Answers
SOURCE: 62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Posted on Oct 17, 2007
SOURCE: Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Posted on Jan 26, 2009
kachbibi1
  • 979 Answers
SOURCE: Brand new Dryer starts then stops after 15 seconds
Stop what you are doing. It is under warranty. This will be more costs and it is not necessary. It is a mfr problem.
Posted on Feb 11, 2009
  • 306 Answers
SOURCE: Zanussi zdc46130w Fault.
I think you should read the instruction manual . 3 beeps means some information to begin a solutin.
Posted on May 04, 2009
maddogsteve1
  • 18 Answers
SOURCE: dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
Posted on May 25, 2009
I have a Maytag dryer model: MEDE300VW0 that is showing a PF code. I have tried unplugging, pressing the cancel button, etc. as recommended on various internet sites. PF code persists.
i know that the voltage overseas is different form the usa,that's telling you there was a power failure while the dryer was running,check the back of dryer to make sure you have 240 volts going to the dryer,you could have a bad power cord or something to do with power source.
Feb 06, 2018 | Maytag Dryers
We need to take apart our Cabrio Platinum Dryer to get it down our stairs.
Whirlpool cabrio dryer repair - YouTube
? 5:22
https://www.youtube.com/watch?v=aIxL38nnOLU
Sep 22, 2012 - Uploaded by Michael Steiger
Whirlpool kenmore safety fuse dryer not lighting GE Maytag. ...Dryer Troubleshooting - Not Drying or Taking ...
How to disassemble a Whirlpool Cabrio dryer
washerdryerrepairhelp.com > Dryers > Whirlpool > Whirlpool Cabrio
Jun 9, 2012 - How to disassemble a Whirlpool Cabrio dryer. Dryers ... If you need to take the drum out, there's a panel that holds it into place similar to the Maytag Neptune design. ... we respect your privacy and take protecting it seriously ...
How To Take Apart a Whirlpool Dryer ' Appliance Aid
Dec 21, 2015 | Whirlpool Dryers
Cabrio Dryer making whirring sounds
That could be something in the blower. In the past I have found garment support wires. That could very well be it. The dryer is built quite well with 4 wheels instead of 2 wheels. You can drop the service panel in front and remove the filter housing very easily to inspect the blower and clean the filter chute. Here is my home movie on repairing one of these
Nov 13, 2013 | Whirlpool Dryers
Whirlpool Cabrio Dryer MOD WED5600XW0 making whirring noise
take the bottom panel off,you'll see a metal duct that the lint filter slides down into,there's a blower wheel behind the duct,if the wheel cracks or gets loose where it connects to the motor shaft it can make this sound,start the dryer and listen to see if the noise comes from there.if you can't tell unplug the dryer,pull out the lint filter and then take out the screws that hold the metal duct in place and remove it,now you can see the blower wheel,spin the drum by hand and see if the blower wheel moves with the drum and belt.if it looks fine stop spinning it and grab the wheel and see if it feels loose,if it is you will be able to tell.also while you have the duct off clean it out,you should take it off at least once a year and clean it out,then vac out the cabinet and blow out your vent line with a leaf blower if it's long,just remove it from the back of the dryer,stick a leaf blower into the vent line and blow it out.go outside first and make sure the outside duct is clear,no cage or anything that will block the lint from blowing outside.if the blower wheel is ok then the noise could be the belt roller or belt pulley,thety sell a kit with all the parts together but usually when someone says it's making a whirring sound it most likely is the blower wheel.hope this helps.
LG DRYER TURNS ON BUT JUST BUZZES. SPIN THE DRUM AND PRESS START AND IT STARTS WORKING BUT ONLY TIL YOU STOP IT - THEN DRUM WILL NOT TUEN TIL YOU SPIN IT AND PRESS START
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 06, 2011 | Dryers
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
The dryer drum is making a noise like it's loaded with bricks
The top pops up from the front and then you will have access to the drum by removing the front.
Mar 11, 2009 | Amana Dryers
Cabrio Dryer runs for 5-10 Seconds and then the drum stops.
Go to: RepairClinic.com
to troubleshoot your appliance.
You'll need the make & model #.
Nov 16, 2008 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryers Logo
59 people viewed this question
Top Dryers Experts
