Question about Rival Irons
Where is the setting mark on a rival steam iron #es280?
It says to set it on the cotton setting, where on the iron do is the mark to put the cotton setting?
    Top Expert:
  • Rival Master
  • 3,698 Answers
I believe the cotton settings are often in the middle or slightly hotter.
Posted on May 17, 2014
oscarn
  • 110 Answers
SOURCE: Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
Posted on Sep 21, 2007
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
SOURCE: I bought a Durabrand TSK-7538S
okay. thats not a bad question, i got the same iron, and i know what your're talking about. the "line" you're talking about is not a line at all, it's actually a tiny plastic indicater at the bottom of the dial. it's blue too, so you cant see it, so feel on it with your finger. =) email me if i helped. solacewishes@yahoo.com
Posted on May 10, 2008
  • 86 Answers
SOURCE: At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Posted on Mar 22, 2009
  • 3230 Answers
SOURCE: sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
2. Broken thermostat
3. Broken power cords
4. Broken heating elements
first of all check FUSE.
good luck...
Posted on Apr 06, 2009
How to stop a steam iron from spitting and spluttering from out of the filling hole with its lid shut.
if you have had enough of the problem junk it and get a new one
it will not be cost effective to repair any way
Jun 15, 2016 | Irons
I got this iron for christmas, it shot steam 2 times and thats all. I had it set on cotton, linen. I used reg bottled water, should i use tap and why no shots of steam.
take it back for a warranty exchange after you check that the thermostat setting is on steam
distilled water is recommended for irons
bottled water ( filtered water) and tap water is the same product and will have minerals and contaminates that affect irons
Jan 02, 2016 | Oliso TG-1100 Continuous & Burst of Steam...
Steam is escaping from underneath the iron, how to fix this?
Household irons can drip and spit out liquid water from the holes in the metal sole plate instead of producing steam if you have set the temperature too low. The obvious remedy is to increase the temperature, but this setting is not appropriate for all types of fabric. For example, the highest setting is generally recommended for removing wrinkles from cotton garments, and the lowest setting is generally safe for silk garments. Using the iron and its steam functions as the manufacturer intended can reduce or eliminate dripping. If that doesn't solve your problem, consider additional steam iron troubleshooting.
May 16, 2014 | Rowenta Irons
I bought a Rival Iron Model # IR999 but, the iron had no instructions in the box. I would like to download the instructions if possible. Thank you, Barbs
The manual for the Rival Steam Wave Iron, IR999, is available here: http://www.rivalproducts.com/product.aspx?pid=2307 . The link to the PDF is below the picture of the iron.
I hope this helps.
Mar 10, 2011 | Rival IR810KS Iron
Hi, I have a Black & Decker digital Evolution iron. It has worked fine in the past but now when I turn it on to any temp setting it starts flashing #8 and beeping. I have never seen the #8 on it...
Try this cleaning procedure:
Empty the iron's reservoir.
Fill the reservoir halfway with white vinegar.
Set iron to steam setting.
Steam on a cotton rag allowing the vinegar to clean the holes in the soleplate.
If this cannot be performed, or does not work,
at Black & Decker's normal price point, it is simply easier to dispose and purchase new.
Best regards,
Feb 25, 2018 | Black & Decker AS675 Iron
We do not have operating instructions for this iron...Shortly after setting heat to cotton or linen and iron heats up,,heat screen commences to flash, red light goes out and iron cools as if disconnected...
No,
either the thermostat or a sensor is bad..
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 13, 2010 | Rival IR800 / IR810 Iron
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
Sticky black mark under my tefal iron
yes i did fix the probleme thank you. I did not that if i use you it would cost money.
Oct 06, 2009 | Micro Pro 7599 Iron
Steam keeps coming out rusty, leaves marks on clothing. model ir5410
The iron needs to be taken apart and cleaned. If it gets rusty again, it's a poorly designed iron and you'd be better off with a replacement. Steam Irons should not rust!!
May 05, 2009 | Rival Irons
No Steam
Your iron will only steam when it has reached the desired tempeture. When the yellow/orange light comes on and the dial has been set for cotton or linen it should steam, when you lower the top and push the steam lever
Nov 01, 2007 | Singer CSP1 Iron
Irons Logo
176 people viewed this question
Top Rival Irons Experts
ray gallant
Are you a Rival Iron Expert? Answer questions, earn points and help others
