Question about Krups XP4030 Espresso Machine
My Krups xp4050 no longer makes steam or hot coffee
It mkes coffee and water comes out of the steam wand but it's cold.Does the it have a heating element that could go out?
  • 55 Answers
I assume there is a power 'On' light. If it is lit and no hot water is produced... the odds are the heating element is blown. If No 'Power On light' then change the fuse in the mains plug.... simples
Posted on May 17, 2014
SOURCE: My Krups XP4050 frother heats and makes bubbles but no froth
It doesn't froth because the air hole in the frother has become plugged with dried milk (cream). There are two types of frother - old one was a black rubber nipple with a stainless 2-3inch air tube rising above the milk. The plastic insert has a pin hole (really about the size of a straight pin!) that clogs. Use a sewing needle or straight pin to clear it.
Posted on Apr 01, 2009
SOURCE: no water through the head!!
I had the same problem - all water going down into the tray at the bottom - virtually none through the coffer basket. I couldn't find citric acid at the store to descale so I used white vinegar instead. I 3/4 filled the reservoir with warm water, and added about 1/2-2/3 cup of vinegar. I first ran water through the 'hot water' button (it comes out the steam spout). Then I ran the entire reservoir through the machine using the 2-cups option. It started running right away. I rinsed out the reservoir with fresh water, then ran a whole reservoir of fresh water through the machine to get rid of the vinegar smell. The first cup of espresso after this treatment was as good as ever. Phew! I thought we were up for a new machine!
Posted on May 26, 2009
  • 22 Answers
SOURCE: Krups model KM7005 water wont heat
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Oct 19, 2009
  • 22 Answers
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
Posted on Jan 31, 2010
  • 22 Answers
Krups Vivo 880. Steam wand is acting as a faucet
The steam valve is not closing. In such a case water finds an east exit from the machine where there is no back pressure.
Repair the steam valve.
Dec 25, 2016 | Krups Coffee Makers & Espresso Machines
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Makes a bang sound and spit sout steam
Try first to pour out some hot water first from steam wand and then try to make coffee.
Jun 30, 2010 | Krups Small Appliances Espresso Machine
When I want to make coffee the water doesn't go to the revolver but down to the water reservoir. It just started few days ago before that the machine was doing great. How to fix it?
The problem with the XP4050 is the two safety valves that the water goes trough on its way to the coffee head. They are plastic and some of the parts will just become brittle because of the hot water and the contamination they gather. With my XP4050 they just broke and parts of it were in the rubber tubes that go to the waste tank.They are also very cheaply constructed compared to the more robust parts of this machine. The water to the hot water/steam head does not have these valves and has a completely different routing. I am currently trying to fix the machine with just one valve and parts of the two valves that are still good. Fingers crossed....
May 19, 2010 | Krups XP 4050 Espresso Machine
No espresso coming out.
Apr 20, 2010 | Krups XP 4050 Espresso Machine
When doing espresso all water comes in the waste basket. Nothing in the cup. Steam function and hot water funcrion is working.
Apr 10, 2010 | Krups XP 4050 Espresso Machine
No steam coming out of heating nozzle for Wega
Remove the nozzle on the end of the steam wand, them open valve to see if the steam wand works, if yes use a paper clip to clear holes on nozzle, if no remove steam wand where it is connected to the valve then open wand(steam will be spraying be careful). If you have steam there then clean wand and nozzle.
Dec 16, 2008 | Wega Mininova EPU Espresso Machine
Krups 867 boiler steam leak
Save yourself the trouble, buy a $1.99 frother at Ikea.  Makes the cleaning process easy - that's what I use at home, never used the steam wand on my machine.
To use the frother, just heat up the milk and froth away.  Pretty easy.
Nov 20, 2007 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups XP4030 Espresso Machine Logo
365 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
