I have a MacBook Pro.10.4.11 My Plam TungstenE2 will not HotSync. 1. Hear are the two messages I get. unable to initiate HotSync operation because the port is in use by another application 2. Transport Monitor could not complete your request. (16)
  • 7 more comments
  • josylwells Jun 23, 2009
    Go into hotsyn manager and select connection settings. Uncheck all boxex except for PDA sync... and USB connect. Then go back and enable hotsync.
    I found USB CONNECT.
    Could not fine PDA sync..
    still did not work
    PS. It is not a Web Cameras problem
    Maybe this will help you. I misspelled Palm Tungsten E2. I am trying to connect by Bluetooth
    There was a change. I found the PDA connection. My HotSync control is enabled now. But I still can not HotSync.
    Where are you Kevin? Should I go to another person?
    I have a MacBook Pro 10.4.11 My Palm tungsten E2 will not HotSync useing bluetooth or cable. My HotSync Controls will not enable. I get two error 1. Unable to initiate HotSync operation because the port is in use by another application
    I have my computer set up with my Palm to use blue tooth. I still get the same message. When I restart my mac I get message (16). I will wait for more help. Thank you.
  • josylwells Jun 24, 2009
    But you are able to send files via Blutooth to the MAC correct? Just to make sure that the connections are active. YES
    Let us try to uninstall and re-install the Palm utility on your MAC.
    1. Remove the Palm startup files listed in the Accounts > [Account Name] > Login Items
    Transport Monitor & Palm Desktop Background
    2. Delete the Palm application folder (don’t delete your Palm data folder)
    Delete the files from the following paths to clear out a corrupted install of Palm Desktop:
    ./Applications/Palm
    ./Library/Application Support/Palm Desktop/
    ./Library/Application Support/Palm HotSync/
    ./Library/CFMSupport/HotSync *
    ./System/Library/Extensions/HotSync *
    ./[login name]/library/preferences/com.palm*
    I PUT THESE IN THE TRASH AND DELETED THEM
    It did not work. Let me know if nothing else can be done please.
    Have a nice day
    1.Go into hotsync manager and select connection settings. Uncheck all boxes except for PDA sync... and USB connect. Then go back and enable hotsync. Make sure to close the connections window or you will freeze up and require a soft reset.
    I DID THIS AND GOT THIS: TRANSPORT MONITOR
    Could not complete your request. (16)
    2. Check if the pda sync button was clicked off (in Bluetooth). Then make sure that "Open Bluetooth Preferences" and make sure "Bluetooth-PDA-Sync" is checked.
    I COULD NOT FIND THIS, BUT FOUND BLUETOOTH UP DATES. WILL ADVICE WHEN HAVE INSTALLED UPDATES.
    I MIGHT HAVE A PROBLEM UNINSTALLING OLD BLUETOOTH
    After checking my mac I found out that I have the latest bluetooth. I also made sure that (Check if the pda sync button was clicked off (in Bluetooth). Then make sure that "Open Bluetooth Preferences" and make sure "Bluetooth-PDA-Sync" is checked.) It was.
    When I tried HotSync I got this message. UNABLE TO INITIATE HOTSYNC OPERATION BECAUSE THE PORT IS IN USE BY ANOTHER APPLICATION. This was on my palm tungsten E2.
  • 400 Answers
Which OS you are using i will recommend to try it on windows 7 it reads almost all drivers ..
Posted on Jun 24, 2009
  • 47 Answers
Somtimes it dosent work try to do over and over it will eventully work
    President:
  • 2,187 Answers
This also happens on the TX. You have to bear with me as I cannot see the other suggestions given to you, but see options below if it will work. I would assume that the error is on your handheld.
If you see this error, here's how to correct the issue:
Cable/Cradle
1. Launch the HotSync application on your handheld.
2. On the pulldown menu at the center of the screen, select the connection method by which you wish to synchronize.
3.Then, instead of tapping the HotSync icon in the Writing Area, tap the large onscreen HotSync icon in the middle of the HotSync application screen.
4. Do this every time you wish to synchronize using Cable/Cradle.
For Bluetooth
5. Whenever you want to synchronize using Bluetooth, exit the HotSync application and tap the HotSync icon in the Writing Area.
6. This will allow you to keep multiple connection methods for synchronization, and the flexibility of alternating between them.
Posted on Jun 23, 2009
  • Nicolo Carlo Parazo Jun 24, 2009
    ./Applications/Palm
    When the installer is running correctly, near the end three install applications will be running:
    Installer
    ConfigLaunchServices
    Palm Setup Assistant
    If these does not work check for the latest update and uninstall the current one.
    Genius:
  • 1,847 Answers
Also check this link..
http://forums.palm.com/palm/board/message?board.id=macintosh_hotsync&thread.id=2715
Hope this will work for you
Let me know
Thanks
Kevin
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Unable to connect with desktop through usb cable
Jan 24, 2011
1 post
Oct 19, 2004
Mar 16, 2004
Dec 18, 2002
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Macbook pro 17" 2008
Dial 1-800-204-4427 US Toll-free Number & Get the best assistance for Trusted Apple MacBook Technical support. We proffer an online MacBook Technical Support assistance to the customers and fix their glitches in a professional manner. Read More.. Apple Customer Support Number 1 800 204 4427
Jun 18, 2017 | Apple Mac OS X 10.5.4 Leopard for Mac
MacBook won't recognize my Lacie Rugged Hard Disk. Disk utility will see it but won't verify it nor will it repair it. says it needs to be reformatted yet it won't even let me initialize it. it is brand...
Is your MacBook as fast as the Lacie Rugged Hard Disk is?
Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
Sorry mate... too many limitations on
Feb 24, 2010 | LaCie Rugged All-Terrain (301017) Hard...
Unsucessful hot sync
If this is still a prob..email me at bobzmailroom1@peoplepc.com there is a trick. Your prob is your pc
Aug 23, 2009 | Palm m515 Handheld
Palm tungsten 3 will not hotsync. b/c port is already in use.
A friend helped me fix the problem. Your site was advertised as free, but it was not. Shame, shame.
Aug 07, 2009 | Palm Electronics - Others
Tungsten V
Re-arrange port configuration, install latest version of palm desktop. Right click on palmsync icon on system tray and check "Local Serial" . You may also use IrDa as alternate sync method
Apr 04, 2009 | Palm Tungsten E2 Handheld
When turning on my macbook pro
Does it work with an external?
1) If it does boot through external. Your LCD, LCD inverter, or LCD cable may need replacement.
2) If it does not boot, then it may be problems with video card or motherboard problem. May need motherboard replacement.
Please let me know the follow ups of it. Thanks!
Mar 03, 2008 | Apple MacBook Pro Laptop Computer with...
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
Computers & Internet Logo
85 people viewed this question
Alun Cox
David Payne
David Payne
