Question about Bose Wave radio remote control - Graphite Gray Shelf System
I have a bose awrcc1, I bought a new bose remote, the am/fm/cd button works but none of the other
  • 48 Answers
SOURCE: Bose Lifestyle 48 Series IV
hate to stae the obvious and painfull answer, but that nees to go back to the shop where if the sales guy cant get it sorted for you it could be a firmware crash and tus a warranty replacement, i know the manual is not that good in this specif area. and a non warranty reset may cost money, if warranty does not cover this specific area of adventure as it is possible they could blame the content of the media being corrupted in some way, could be ahrd one.
however you could try remoing the disk and resetting the system according to manual frist.
good luck ;-)
Posted on Mar 08, 2008
SOURCE: Bose 3-2-1 Remote Control stopped working
I purchased a LAZBOY universal remote (at Fred Meyers, on sale for $9.99) and after a bunch of research and trial-&-error, was able
program it with a code (1629) which works reasonably well with the
Bose 3-2-1.
I don't have all the system-level functions (which I never utilized anyway) but do have all the basics as far as power, volume, source, and CD/DVD control.
Posted on Sep 07, 2009
BillB-SA
  • 2761 Answers
SOURCE: The remote for my Bose Wave radio-CD no longer
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug it back in
  • Make sure you’re pointing the remote directly at your Wave® music system. If the system is placed above table-top height, be sure to angle the remote upward while pointing
  • Check for possible sources of interference with the remote’s infrared (IR) signal, such as bright lights or solar glare off of a window. Make sure nothing is blocking the path of the signal from the remote to the Wave® music system display. The remote will not work properly if there is something directly in front of the display
  • Wipe off the small clear lens on the front end of the remote
  • The remote is designed to work within 20' of the system. Greater distance may cause intermittent response
Posted on Dec 06, 2009
  • 2468 Answers
SOURCE: Need a 110v power supply(power
if the secondary voltage of the transformer is 12 volts A.C. go to radio shack and they will have a transformer,though being it an aftermarket transformer it will work
Posted on Aug 01, 2010
seabelow
  • 95 Answers
SOURCE: My bose AWRCC1 CD Player no longer works - the
You "won't" get parts, you want it fixed you have to sent it to them. They won't send any parts to anyone who is not directly part of their "Repair System" They will trade your sys. or update or repair if they still fix the one you have.
Posted on Sep 22, 2010
I have a Bose wave radio .only a few buttons on the remote work now. The fm/am buttons work as well as some of the preset station buttons. Can I fix it without buying a new remote?
You can fix it yourself. The only problem you may have is disassembling the remote. Once you complete the dissembling, the repairing part is not difficult. you can do it.
Jun 20, 2017 | Bose Audio Players & Recorders
How do I improve my reception on a Bos Wave Radio with single CD player
The Bose uses its power cord as an antenna. The cord has to be stretched out (not coiled) to pick up stations. It also helps if it's oriented the right way -- try changing the direction (having the cord running east to west, say, instead of north to south). Moving the radio and the power cord closer to a window can help, too, especially in a commercial building. These structures often have a steel frame which can block radio signals. If all the above fail, your best bet is to buy an indoor FM antenna, which can be as simple as a piece of wire made into a dipole antenna or as fancy as one of the Terk mini-towers with built-in amp. Bose sells one for their radio, though it's kind of expensive for a simple length of wire. You can get the same thing from Radio Shack, but if you do, be sure to pick up their adapter (catalog 278-257) to plug it into the non-standard Bose jack. All together you'll spend half what Bose wants. Move it around like you did the power cord and you should see a big improvement.
Aug 05, 2014 | Bose Wave Radio / Cd With Remote model...
Lost remote control for bose wave model number AWRCC1 will the additional bose acoustic wave music system remote control work
Check this site to get setup codes and model number of a suited universal remote control. It has many details you want. Check this site too.
Apr 21, 2013 | Bose Wave radio remote control - Graphite...
My Bose radio stopped working, no sound no lights AWRCC1
Hello
Check its power cord first. If it is OK, check its power supply section inside. There will be a fuse at the power supply rectifer board. Check it. If it is found opened [damaged] never put an other fuse, without proper check to the power supply and main audio amplifier section. There must be some reason for the blow up of this fuse. Without rectifying the fault, replacing an other fuse, may make more components to get damaged, and the repair work may cost more. OK.
Feb 26, 2012 | Bose Wave radio/CD remote control -...
Bose 3-2-1.
Sep 07, 2009 | Bose 3 2 1 GSX System
48 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
