Question about JVC KW-NX7000 Car GPS Receiver
Hello I have a kW-nx70000 I have a error 8 and Bluetooth has never worked
Did reset on left small button and disconnected back radio wires
3 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: listening to sirius satellite radio and "reset 8" message flashed
The Sirius tuner is bad. 1000's were sold and 1000's have been replaced! The new model will work with your unit and does not fail, it's manufactured by DEI not Audiovox. Or, you can check Ebay for a rebuilt tuner for around 40-50 that has the problem fixed and corrected. Hope this helps.
Posted on Sep 26, 2009
  • 11800 Answers
SOURCE: my kw-avx840 was showing a
The faulty wire was shorting on the ground. When that happened the current flowing thru the amplifier top which that wire was connected got severely overstressed. This is why the safety system was triggering. By reseting it you were just making the problem a lot worse - you were forcing the amplifier to run with its output shorted. So it was to be expected that it eventually failed - it severely overheated and it got shorted itself internally. Now it's the short in the amplifier the one that is triggering the error message. And because the short is on a critical part you can no longer reset it - the power source itself has shut down.
The radio will have to be dismantled and the failed final amplifier identified and replaced, a job for a pro - time to take it to an electronics repair shop.
Posted on Aug 15, 2011
Jvc kw avx840 frozen on telephone screen. Press reset and everything works fine again until either detatch facia or switch off ignition.
Sounds very strange ... I have the exact same set. Try removing the Bluetooth dongle and re installing it again and see if this helps. Is this a new install? You r ground is good right? to the frame not just a black wire from old stereo you replaced?
Apr 21, 2014 | JVC Kw-Avx840 7 Double-Din Multimedia...
Audio has no sound
I had the same problem. Everything worked except the sound. There is a small button next to the CD player that is a reset button. Press that and the audio came back. You have to reset your presets but at least the sounds works.
Jan 09, 2013 | 2012 Hyundai Elantra
Where is the reset button in a 2001 Chevy Malibu radio
Stock radios do not have a reset button. The only way to reset it is to disconnect the radio either by disconnecting the battery or unplugging the wire harness on the back of the radio.
Mar 04, 2012 | Car Audio & Video
After I press the green start button, I can hear the rollers making a whirring sound for a few seconds, (doing their cleaning bit) then the amber trouble light goes on. I can' t get a print in other...
Hello Jra,
By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Jun 22, 2011 | Canon Pixma iP2600 Photo InkJet Printer
My tylo supersport 8 sauna no longer produces heat. The timer works but there is no heat. I have checked the circuit breaker but that doesn't appear to be the problem. Any thoughts??
Remove the unit bottom panel (2 small screws) and look at the quick disconnect terminals on the heater rods ( 6 heating rods - 3 on each side of the unit). If you have any corrosion on these terminals, the wires will overheat and fail, preventing the heating rods from working. If the wires did overheat, you should see melted wire insulation. Replace bad wire and quick disconnect terminals with new. Should cost less than $20.
Nov 23, 2010 | Tylo SUPER SPORT-U8 Sauna Heater 8 kW
JVC KW-AVX 800 "Position error"
Assuming that this is not a new install (the laser is secured with a long, thin brass screw when shipped, and this screw must be removed on installation), and the unit has worked before today, then we will troubleshoot from the "damage" perspective.
The laser isn't centering itself to start position.
This could be due to track binding (dust buildup) or just a hard jolt to the base (pothole?), but the first thing to try is a soft reset...and if that doesn't get it, then a hard-reset next.
*Assuming of course that one of the kids hasn't jammed something foreign into the slot and knocked the head off-track...it happens quite often.
Soft reset:
Most models have a tiny, recessed "reset" button that you can press and hold for 5 seconds with a ball-point pen, located under the faceplate.
This will restore factory settings, and re-center the laser.
If the error returns, a Hard reset:
Disconnect the Positive(+) cable from the car battery for at least 30 seconds, and re-connect.
You will likely lose all saved stations on the radio, but this is a last-resort to avoid removing and opening the unit.
9 times out of 10 this will solve any digital errors, and will free sticky tracks better than half of the time.
Jun 29, 2010 | JVC KW-AVX706 Car DVD Player
Where is the rest button
the reset button is the extreamly small button on the lower left hand corner of the deck a paper clip will work fine to press this button
Sep 21, 2009 | JVC KW-AVX810 Car DVD Player
JVC KW-AVX706 front face problems
for ppl still having this problem.. more than likely the dash kit is to small and not allowing the radio to close properly. soulution: get one that fits, or get a dremel and shave down the plastic on the dash kit that prevents the radio from closing... hope this helps some1
Oct 05, 2007 | JVC KW-AVX706 Car DVD Player
HP ipaq 5550 - Bluetooth error
The error message is telling you that there is not enough memory to load the BlueTooth driver, try moving some of your files from My Documents/My Music etc. to your memory card. Also try uninstalling some of your programs and reinstalling them to your memory card, this will free up a fair bit of space in main memory and hopefully resolve the problem. Also; Tap Start, tap Settings, then tap the System tab and tap Memory. Tap the Main tab to see how much space is available in main memory, you should see a total of around 115-120MB available (128MB - the lie of storage device sizes - the file system) divided in to storage memory and program memory, if you see considerably less then you're iPaq has a hardware memory problem and will need repairing. Lastly keep in mind that Windows error messages cannot be trusted and the actual problem may be absolutely nothing to do with memory, so if this doesn't help post back.
Aug 22, 2007 | HP iPAQ H5555 Pocket PC
JVC KW-NX7000 Car GPS Receiver Logo
43 people viewed this question
Top JVC GPS Experts
Are you a JVC GPS Expert? Answer questions, earn points and help others
