Question about Bernina Sewing Machines
I have 1080 quilter edition machine that will not sew forward but will sew backward. Any ideas and what is causing this to happen and how to fix it?
  • 3 more comments
  • Gail Bennett
    Gail Bennett May 17, 2014
    Anyone know wher I can find specs or diagram for this machine?
  • Gail Bennett
    When I bought this machine used it would not sewing and my repair man took it a part and ffound and clean it but that was 3 years ago and he has passed away since then and the place I took it to waned to send it to Bernina for them to repair and would cost $500
  • Joe May 17, 2014
    If you go here and pay $18.99 you'll get the 54 page Manual:
  • Joe May 17, 2014
    Add a Commenthttp://www.sewingpartsonline.com/instruction-manual-bernina-1080.aspx
  • Coreen Murphy Jun 05, 2014
    Gail, Go to the website for the manufacturer of your machine. Most manuals are available free on line.
    Novelist:
  • 268 Answers
Sounds like it needs a good COA (clean/oil/adjust) if it hasn't had one in three years. My guess is that the lubricants have gotten thick. You may be able to effect a temporary improvement by just taking the needle out and running the machine full tilt 15 minutes at a time. Sometimes the heat and vibration generated from doing that will unstick something. (Machines need about 5 minutes of "exercise" every month or they stiffen up; if I don't use a machine that month, I run it 5 or 10 minutes without the needle on the first day of the next month.)
Otherwise, talk to anyone who sews and find out where they take their machines for maintenance. If you're in the US, and don't know of anyone else who sews, try your local ASG chapter for recommendations (http://asg.org/) or groups like patternreview.com or the yahoo group "creativemachine" (these both are international, btw). Most competent machine mechanics can service any brand, though there may be some problems getting parts. I've been using a Brother certified mechanic for my Jukis, for instance, and he's doing a wonderful job.
Posted on May 22, 2014
  • 55 Answers
I assume the needle motors and and down... are the feed dogs transporting the material... it works in reverse you say.
Posted on May 17, 2014
  • 1 more comment
  • Gail Bennett
    Gail Bennett May 18, 2014
    Yes the needle moves and feed dogs too
  • Kim Bentley
    Kim Bentley May 26, 2014
    I got one. my feed dof doesn't seem to move up and down. don't know how long its been sitting. estate sale for $10. Any suggestions? Thank you.
    Kim, check to see if the feed dogs are down. Some machines have a switch where you can lower the feed dogs for darning. Check your manual for the location of this switch. If you don't have a manual, go to the website for your machines manual. You can download most manuals for free.
RickE1
  • 202 Answers
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Posted on Jan 11, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
  • 52 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Posted on Jul 14, 2009
  • 46 Answers
SOURCE: Brother Machine!
The reverse mechanism is stuck. The machine has to be completely disassembled to get to the problem. It is usually not a big deal to get it "unstuck" but taking it apart can be a pain. A good machine tech. can do it easily or you can give it a shot. Just look what the reverse lever actuates and see how it is stuck in the reverse position. It is usually the stitch length/reverse block.
Posted on Aug 06, 2009
  • 632 Answers
SOURCE: PFAFF 1222E Sewing Machine (~1977). Mechanically Locked-up
You might be in "Stopmatic" mode. Check if your pressure lifter bar is in the upper most position, if it is the machine is disengage and you are set to wind your bobbin. Lower it to the 3 o-clock position this will engage the machine and the needle will operate.
Posted on Aug 10, 2009
My machine will not sew in the forward position...It keeps sewing backwards like it is in reverse.....Need help ASAP
All sewing machines have a gear lever. This is so you can sew a seam forwards and backwards. Consult your manual.
May 03, 2016 | Sewing Machines
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
Sincerely
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
How can I fix my simplicity quilters classic sewing machine that the to thread seems to get hung up in the bobbin case and the machine freezes up and will not sew?
Is it really threaded correctly? Is the needle, old, blunt,or slightly bent? Are the thread and needle compatible with the material? :)
Jul 08, 2014 | Simplicity Quilter's Classic SW240...
Pfaff grand quilter
try a new needle
rethread the machine top and bobbin
clean under the needle plate and in the bobbin area for lint
and if these suggestion don't help, then it would be a good idea to have the machine checked.
Nov 11, 2013 | Sewing Machines
Adjust the timing on a singer confidence quilter 7469q
Hook/needle timing needs a hands on guidance to get it fix, 2 options either you can watch in utube 'singer sewing machine hook timing' or 'google' for singer 7469q service manual for your referral.
Nov 10, 2013 | Singer Confidence 7469 Mechanical Sewing...
My sewing machine jammed recently and now when I try to turn my handwheel backwards my bobbin case spins to where the needle hits the case. I can turn it forward with no problems. Machine sews and back...
You need a new position bracket. What's happened is you forgot to or incorrectly threaded your take-up lever which caused the machine to jam and position finger to twist. You will need to take your machine to a repair tech that has access to parts for your brand of machine.
Nov 05, 2013 | Sewing Machines
9240LCD Simplicity sewing machine sews backwords & when you push the switch nothing happens. its been since we had it cleaned & shipped to daughter. How do you fix it
The reverse lever is attached to a cam that moves the feed mechanism. Most likely the attachment to the cam is disconnected or the cam is slipping on the shaft.
Sep 02, 2013 | Simplicity American Quilter SA2400L...
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
Needle off center
Hi, definately a tech can adjust this and it is pretty easy (10 minutes) though one needs a special screwdriver type tool called an eccentric tool (though its possible to just center the needlebar by hand). There is a small screw in the stitch width mechanism near the front left of the needle bar that must be slightly loose. It needs to be loosend more then center the needle and tightend down again. Sorry I can't describe where exactly it is without showing you pics.
Rick
Nov 21, 2009 | Bernina Sewing Machines
Sewing Machines Logo
77 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
