Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
WHY DOES MY WASHER/DRYER COMBO NOT TURN ON?
WORKING FINE THEN I UNLOADED WASHER, PUT IN DRYER HAD NO POWER, SO I PUT A LOAD IN THE WASHER, NO POWER THERE EITHER. NOT THE BREAKER, NOT THE PLUG. WHAT ELSE COULD IT BE
  • Official Brand Answer
  • 2,267 Answers
Hello Friend, thank you for your post!
Based on the symptoms you are describing, it sounds like your Frigidaire laundry center is experiencing an issue with the power supply. In this regard, I would suggest contacting an authorized service technician that will be able to assist you in the diagnosis of your appliance. Best regards! - Z
Posted on May 22, 2014
SOURCE: dryer
I WOULD CHECK DOOR SWITCH FIRST
Posted on Jan 31, 2008
ngfam1
  • 639 Answers
SOURCE: Washer / Dryer will not start at all...
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
WAS THERE LIGHTNING THERE IN THE AREA THAT DAY?
IF IT'S BOTH THE DRYER AND WASHER !
STOP!!!!DO NOT TOUCH THEM AND CALL AN ELECTRICIAN OR PUBLIC SERVICE!
YOU ARE LUCKY TO BE ALIVE!
HUNDREDS OF PEOPLE DIE FROM THESE ACCIDENTS EVERY YEAR!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
SOURCE: Frigidaire Laundry Center (top load) dryer stopped working
dryer tub loose
Posted on Aug 23, 2009
caroldon
  • 17130 Answers
SOURCE: my frigdaire stacker combo dryer wont spin? The washer works fine. It seems very tight, why could that be?
Possible that the bearings are worn out and so the drum is not free as the spindle is stuck up and so does not move fully in the spin cycle.
check this link for tips to check and replace the bearings: Washer bearings
Posted on Jul 03, 2012
Washer Dryer Stacked Combo won't start and didn't drain properly.
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Apr 11, 2016 | Frigidaire Washing Machines
Hi, I just purchased an older style washer dryer combo. When loaded (with as little as two towels) it doesn't agitate or spin. Belt is fine. Drum starts to turn but can't make it up the hill. Any sugg
Your motor may be having trouble starting due to a bad capacitor or start winding in the motor. Ideally you want to use a multimeter to test resistance of the start winding.
Jul 31, 2013 | Washing Machines
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
I have a Frigidare washer/dryer combo (model # FLEB8200DS0). My wife washed a heavy load and the washer stopped draining completely. Agitator works fine. Please HELP...
I'm not sure if the heavy load had anything to do with it or not. this unit has a remote pump, which means the pump doesn't run off of the main belt . It actually has a motor of it's own. Basically you would have to remove the front access panel, of course unplug from power, make sure the pump will turn. with the power off you can rotate the cooling fins on the pump motor. if it turns freely then you would have to determine if the pump motor is getting power. If it is getting power then you need to replace the motor.
Oct 24, 2009 | Frigidare FEF336EC Stainless Steel...
LG WD-1438RD washer dryer combo won't turn on
Okay well i had the same problem with my LG WD-1438RD so i took it a part it was a loose wire in the display module easy fixed. I guess from banging the door closed and hitting the buttons to hard made it come loose. To fix it all you need is a phillips head take the two screws out of the back up the top then slide the lid forward. then remove the powder tray thing unscrew the 2 screws behind it push the clips out of the way just be careful not to break em. re connect the wires! job done =) i put glue and electrical tape on the wires and plug so it shouldnt happen again..... I hope i helped you good luck
Jun 05, 2009 | LG WM2077CW Laundry XL Front Load...
Washer
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck !
Jun 26, 2006 | Kenmore 45081 Front Load Washer / Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
65 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
