Question about Omron Bp785 10 Series Upper Arm Blood Pressure Monitor
Monitor starts normally but on it's way down, the number drops down dramatically
I have changed the batteries, but that wasn't the problem. The monitor starts normally but on it's way down, the number drops dramatically.
    Problem Solver:
  • 9 Answers
Check for leaks...i have opened one of this before and it has a broken hose inside...but before going anywhere else, try to check your cuff near the hose then the hose fittings for possible sign of leakage...
you can inflate your cuff then submerge the hose and cuff in water to do the check...
Posted on May 25, 2014
Right after oil change my on-board computer display changed dramatically. Cruising range dropped from 370+ to 300 miles. MPG dropped from 20 down to 11! Lost history of previous fillups, etc. I have
Hi, I'm not very familiar with these vehicles, however changing the oil shouldn't make a negative difference to the economy. Is it possible on your vehicle that 'Sequential sport shift' or the 'Mode select transmission' buttons could have been tampered with? Certainly any transmission or performance enhancements would have a negative impact on the MPG immediately.
I can't think of any other reasons at the moment.....
Nov 28, 2013 | 2008 Toyota Highlander
Tip
Do you have a constant buzzing sound in your handset?
The NiMH batteries used in these phones have a useful life of about 2 years. With only 2.4v at normal operation, the amplifier circuit will start to pick up interference as the voltage drops in an old battery. If you hear a constant buzzing, no matter your location or distance from the base unit, then it's most likely your battery causing the problem. Some phones are more susceptible than others causing the buzzing to start earlier than another phone. Battery Buzz is a good indication to change your battery as soon as possible. As the problem gets worse you will have voice and connection problems. Since transmitting uses the most power, you will be unaware when your voice quality drops dramatically for the people on the other end of the call.
on Jul 05, 2007 | Panasonic KX TGA400B Cordless Expansion...
Why is my screen opening at half screen?
not sure what half screen you are referring to
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
if you do not see these tabs in the top toolbar
right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
or if its actually half of the screen
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Aug 09, 2012 | HP Computers & Internet
How to adjust color of screen
click start control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range
click start control panel,display,desktop you can select a different desktop from the drop down list also there should be a browse button where you select your own personal picture saved in my pictures also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
hope it helps
May 15, 2012 | Hannspree HF225DPB 21 inch LCD Monitor
How do you change the contrast on the monitor of a M40?
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
hope this helps
Apr 01, 2011 | Toshiba Computers & Internet
My menu monitor setting is not in English, how do I change the setting back to English? Also the picture on the monitor has shrunk, how do I get it back to full screen?
click start control panel,regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location or another language
hope this helps
don
Feb 23, 2011 | Emprex LM1704 17" Monitor
When i on the monitor only colour vertical bars are shown and after some time it is gon to the standby mode(beacouse i donot connect the cable to the cpu) in this monitor made by>(gm2621-lf)...
the lead to the monitor usually connects to the back of a computer the input output should have the same number of pins also
also
hope this helps
don
Feb 23, 2011 | Computers & Internet
My monitor has turned very bright
hope this helps
don't forget to vote
My video card, which has a sticker with the Letters and numbers REV A02 appears to have gone bad. When I start my computer, all is fine until it gets to the login screen, at which point the display gets...
also
hope this helps
Feb 11, 2011 | Computers & Internet
Acer Aspire 9300 My Aspire 9300 has worked fine
It maybe the problem of your graphics processor,so you can't see the NOOK working normally .Your Acer Aspire 9300 battery haven't effect to this mattery ,why you tried taking it out !
May 18, 2010 | Acer Aspire 9300 Notebook
Omron Bp785 10 Series Upper Arm Blood Pressure Monitor Logo
123 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
