Question about Stihl Br 500 550 600 Backpack Blower Throttle Cable Assembly 42821801100
How to conect throtel cable
Hoaw do you conect the new throtel cable to thecarburettor
No throtel it starts and idles give it throtel it dies
use a scanner to find fault code, if no codes, check fuel system
Sep 01, 2013 | Cars & Trucks
Needs throtel valve ajustment
May just need lube. Follow it down to transmission and observe where rotating on side or top. That needs to return on its own fully, after pedal backs off. May take a while, but lube good and keep trying to move it more and more as you go, until it moves real free.
Apr 20, 2013 | 1999 Dodge Durango
I forgot my security code or lock code for nokia 6210 Navigator.... Hoaw can I reset this?? I dont know how to use master code!! please help me urgent!
*#7780#NOKIA Factory Reset (Hard Reset). Note all the codes will necessary ... than type 12345 press OK button. subhash kukade 9850656714
Dec 12, 2010 | Nokia 6210 Navigator Cell Phone
It will only shift at wide open throtel......it's a 88 ford bronko 5.0l with the 3 speed auto.
Check your kickdown linkage. It is called a "TV cable" for proper adjustment or possible binding or breakage of the cable or bracket.
Sep 24, 2010 | 1987 Ford F 150
On the way home from vacation ( car had been running for 4hours -- we got caught in traffic -- stopped for 25 minutes with the car running/ and AC -- we stopped at rest stop 2 minutes after traffic...
the three things your vehicle needs is spark fuel and air. so check to see if all your wires are getting good spark. now for the air you have the air filter then right behind it you have your mass airflow sensor then you will follow the air induction up to your throtel body. make sure your throtel body is in good working condition I.E depending on if you have a electronic throtel body or the old cable version you also may clean the throtel body along with the mas airflow sensor. in the rear of the air induction there is yet another sensor called the map sensor check this for serviceabity also. if this does not solve the problem your fuel lift pump in your fuel tank will have a constant hum to it easy way to tell if this is the isue is unhook your fuel supply line and turn the key to the on position this will tell you if your fuel lift pump is working another thing to check is the charcol canister it may be clogged
Sep 02, 2010 | 2001 Chevrolet Suburban
Why wont my 97 jeep grand cherokee shift from 2nd to 3rd without letting completely off the gas
Sounds like the governer in the tail housing of the trany. is stuck. Or if it has a cable for the shiftting mechanicanism that runs to the throtel body the cable may be broken or out of adjustment.
Dec 19, 2009 | 1997 Jeep Grand Cherokee
Throttle sticking
is it the cable snaging up or is it frayed,,, it could be that it just needs a good bit of TLC,,,by way of an oil can? try a fuw drops of thin oil down the cable and work it to see if it frees off,, if it dont fit a new cable fast,
there will come a time when you slam the throtel closed and it go's stumping on ,,,bad news that is!
Nov 15, 2009 | 2005 Honda VT 750 Shadow Aero
I need a diagram showing how the throtel cable attaches to the carb on a Craftsman 17.5 hp, 42 in.,riding mower (NEW 2008)
The throttle cable doesn't attach to the carburetor. The 'z' bend in the end of the cable sticks in the white plastic slide at the bottom of the control plate on the left rear side of the engine and the cable is held in place by a clamp behind it.
Jun 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stihl Br 500 550 600 Backpack Blower Throttle Cable Assembly 42821801100 Logo
52 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
