Question about Car Audio & Video
WHY IS THE 15 AMP FUSE BLOWING ON MY 1982 SUZUKI GS1100GL
I DONT KNOW HOW TO CHECK IF IT IS THE MAG OR THE VOLTAGE REGULATOR, BUT I KEEP BLOWING THE 15 AMP FUSE AT RANDOM DURING DIFFERENT RPM RANGES.
  • 3 Answers
Try 20amp fuse ?
Posted on Jun 15, 2014
3 Suggested Answers
SOURCE: amp keeps blowing fuse
I have this same problem. You have blown the internal amp. I have had 2 of these do the same thing. There is nothing you can do but report it to infinity and try to get the unit replaced.
Posted on Feb 08, 2007
1986bigjimmy
  • 3 Answers
SOURCE: what is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Posted on Nov 28, 2012
Why do i keep blowing 15 amp fuse on my 1982 suzuki gs 1100 gl?
you have a short.
check wiring near head stem and handle bar switch blocks
May 17, 2014 | 1981 Suzuki GS 750 L
I keep blowing a 30 amp fuse on a 2002, 1200 S Suzuki bandit
Have your voltage regulator checked a bad regulator will blow big fuses like a 30amp, hope this helps.
Sep 08, 2012 | Suzuki GSF 1200 Bandit S Motorcycles
All the lights work except the dash lights. The 5 amp fuses keep blowing and if I put a 15 amp it doesnt blow but no dash lights
DASH HAS A SHORT CIRCUIT.DASH NEED REPLACING BUT CHECK FOR SHORTS IN THE WIRES TO DASH.DONT PUT A LARGER AMP FUSE IN A CIRCUIT TO KEEP FROM BLOWING FUSE BECAUSE IF FUSE DONT BLOW WIRES GET HOT IN THE CIRCUIT THAT HAS A SHORT IN IT AND CAUSE A CAR FIRE.
Nov 04, 2010 | 1992 Ford Thunderbird
1982 gs1100gl tail light bulb burns out as soon as rpm increase
You are probably dealing with bad grounds or ground wires. If loosening and tightening/ unplugging and replugging in the wire connections does not fix it , you are probably dealing with a bad regulator/rectifier.
Sep 03, 2010 | 1981 Suzuki GS 750 L
1982 GS550. Has been runing fine but now it cranks but won't start. no spark. What should I check and how?
check your coils,your points,your voltage regulator,and stator.
maybe check your fuses first though,if blown change it if it happens again then check all that other stuff.
Aug 07, 2010 | 1982 Suzuki Gs 550 L
1982 Dodge W150 truck (6 cyl.)wiring problem
I do not know about that,but make sure the large wire on the alternator is going to the positive cable on the battery.
Jun 01, 2010 | 1986 Dodge W150
Suzuki 1982 GS1100GL won't accelerate
No wonder it has been sitting for so long it becomes lazy..... Sorry, just to cheer you up. Check you clutch pack, tming chain and tranny state before anything.
Mar 23, 2010 | 1983 Suzuki GSX 1100 E
It keeps blowing the ECM Fuse, checked wiring but
My friend;
Try this;
  1. Did you insert same valued fuse i.e. { fuse rated 15APS with same fuse}.
  2. Check OP'S & voltage of the Alternator = 13.7 V DC - 14.8 V DC MAX.
  3. are you sure NO internal shorttings inside the ECM.
How to Test a Car's Alternator
http://www.youtube.com/watch?v=uI0SBtmSjHg&feature =related
Diagnosing an Alternator Problem:
http://www.youtube.com/watch?v=w5TkStVWNvA
how car alternators work
How to Install the Voltage Regulator on an Alternator
How to Rebuild an Alternator
How to Test a Car Voltage Regulator
Try it, & let me know if I add any benefits to you.
I hope I add some thing valuable to you.
Regards;
MAR;
soer2@yahoo.com
Nov 06, 2009 | 1987 Chevrolet V30
My honda blows my headlight fuse as I start to accelerate. Change fuses and checked wires. no luck
Hi and welocme to FixYa,
Offhand, check the wires & connectors for looseness, corrosion or pittings/burnt marks; scrape clean and tighten as necessary.
Should the wiring & connectors check out, then the voltage regulator could be suspect. This could be checked by measuring (with a voltmeter) the battery's voltage before start, on idle and while revving.  Compare readings: with engine off, battery voltage should be 12 + volts, on idle should be less than 13 volts and while revving should go high with a maximum of 14.5 volts or thereabouts. If the voltage is already high at idle or more than 15 while revving, then the voltage regulator would require replacement.
Good luck and thank you for asking FixYa.
Aug 15, 2009 | 1982 Honda VF 750 S
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
