Question about Canon PIXMA MP830 All-In-One InkJet Printer
Dell 924 all in one cover open
Dell 924 all in one wont work it says cover open and of course it is not any ideas
  • Canon Master
  • 1,087 Answers
Sounds like the sensor for the cover is not working. If you open the cover when it is on, then close it, does the error remain? It only needs a microscopic amount between 'open' and 'closed' - check if there could be a tiny bit of paper somewhere around the edges.
Failing that, get in touch with Canon.
Posted on May 29, 2014
I need to install my Dell 924 printer onto my macbook pro
Dell printer are rebadged Lexmark printers - so if you can find the lexmark equivalent, maybe the mac driver will work - I have had a search and not managed to find anything that has worked in the past on that printer
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
Where do you insert the ink cartridges for the dell 924?
You lift the Top cover, and wait for the ink carriage to take place in the middle of the rail. Lift the plastic lid holding the old cartridge in place. Then snap the old ink cartridges pulling toward yourself and then up. Put new cartridges in reverse order.
See:
Owner's Manual
Dell Photo All-in-One Printer 924
Sep 16, 2009 | Dell 924 All-in-One InkJet Printer
Dell 924 scanner won't work
Downloaded the driver from the dell web site.
Version: G11a, A02
File Size: 36 MB
Or
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R109906&SystemID=DIM_CEL_3000&servicetag=&os=WW1&osl=en&deviceid=8733&devlib=0&typecnt=0&vercnt=1&catid=&impid=&formatcnt=1&libid=0&fileid=143054
Aug 09, 2009 | Dell 924 All-in-One InkJet Printer
Dell AIO 924 Printer/Scanner Wont work with Vista
try to download the compatible driver for Vista!!
using the page of ur product starting with dell.com
Dec 12, 2008 | Dell 924 All-in-One InkJet Printer
Install ink cartridge in my Dell 924 where does it go?? how do you open it??
The cartridges go inside of the cartridge carrier. There is a tab on each side that you push down on and the cover will pop up so you can insert the ink cartridge.
Here is a link to the manual. It is described on page 49 to 52 of the manual.
Dell 924 Manual
Nov 10, 2008 | Dell 924 All-in-One InkJet Printer
OCR application error with the Dell ALL in ONE
OCR is a software provided by Dell to convert a scanned document to editable text(word) document. If you scan without OCR software, printer will scan it as a Picture and you can not edit it.
Now here is your answer.
When you install Printer CD, it also install OCR software (Abbyy Fine reader) along with it.
You might have uninstalled the printer drivers and reinstalled them by downloading it from Dell support site.
I must tell you that Downloaded drivers from Dell site DOES NOT contain OCR software.
Solution:
1. You can download free trial version(15 days) from Abbyy.com
Click here to download
2. If any of your friend or relative have printer listed below then you can use the same CD to install the OCR software.
List: Dell 924, Dell 926, Dell 928, Dell 944, Dell 946, Dell 948, Dell 964, Dell 966, Dell 968.
location on Disc:
D:\OCR\setup.exe
3. You can scan using MS Paint.
Click on Start > All Programms > Acccessories > Paint
Click on "File" on Top left corner.
Click on "From scanners and cameras"
Click on "Scan"
It should be able to scan.
4. If you want to use Dell All In One Center.
You can disable OCR option for scanning and it will scan as an image.
Open Dell All in one center.
Click on Advanced scan options Under scan,
Uncheck "Use OCR software".
Click OK and try to scan again using Dell All In One center or using the printer operator panel.
Please revert for any further assistance.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 inkjet printer
remove all paper, open cover and see if you can see stuck paper.....never try to pull out backwards...try to pull out in direction of normal paper travel..if you absolutely have to pull out backwards unplug printer first and be gentle as to not break rollers or gear(s)
May 17, 2008 | Dell 924 All-in-One InkJet Printer
Dell 922 "cover open" problem / error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then close the printer after it powers on.
It worked for me.
Dec 04, 2007 | Dell 922 All-In-One InkJet Printer
Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Oct 29, 2007 | Dell 924 All-in-One InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
24 people viewed this question
old marine
old marine
