Question about Hardware & Accessories
Why my orbit sprinkler timer just display a battery image?
My orbit sprinkler timer model 57256 does not work. On the screen there is a battery image. I changed the batteries but the battery image is still displayed. No matter what you do the timer just display the battery picture. Anyone can help?
protek480
  • 1714 Answers
SOURCE: Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Posted on Jul 02, 2009
appman67
  • 33 Answers
SOURCE: i need a user manual for the timer box of a orbit
http://orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
Posted on May 16, 2010
SOURCE: I have an Orbit WaterMaster Sprinkler control, it
There are 3 things this "off power" "light bulb" could be. Blinking red light? means fuse has gone out. Check the power source where the unit is plugged in to. Is the GFI popped out? plug something else like a fan or something into the socket to test. the third thing is a short internally. Call orbit technical assistance. they're great.
Posted on Jun 23, 2010
SOURCE: We installed the EJ500 about 3 years ago. Recently
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
The EJ500 comes with a 1 year limited warranty. It may be time for a new timer.
Buy at:
http://www.aplussupply.com/intermatic/timer.htm
Posted on Sep 26, 2010
SOURCE: I have a Orbit 57161
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Posted on Oct 06, 2010
No AC fault in Orbit Sprinkler Timer Model 57896
Call Technical Support at Orbit. The 800 number should be listed in the instructions.
Apr 17, 2014 | Orbit Underground 57896 6 Station In/Out...
No were in the instructions is there anything about the " RESET " ??? will it reset everything or just what the slector is on???
Which timer do you have? Is this orbit sprinkler timer?
Copy following link for sprinkler timer manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add a comment and describe timer in detail so expert can identify product.
Many battery operated timers are reset by removing battery.
Gene
Aug 05, 2013 | Orbit Hardware & Accessories
Need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
Sep 10, 2012 | Hardware & Accessories
Hardwire the orbit outdoor sprinkler timer
Reset the timer? This will sometimes resolve many problems.
Are you sure the conduit has 120Volt? Is the timer connected to single breaker?
Or is circuit 240V? Timer connected to double breaker.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-8.jpg
What do you mean green wire to negative?
What else is on the conduit circuit?
Motors, fluorescent lights, and other electronics can interfere with electronic timers.
Run extension cord to timer from another electrical source and see if problem continues.
Re-post question with model number so timer-electricity expert can read the troubleshoot section of manual.
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
http://waterheatertimer.org/pdf/Rona-91026-water-timer.pdf
Aug 01, 2012 | Orbit Hardware & Accessories
Directions for GreenThumb watering control by Orbit model 27157
Copy following links for Orbit timer manuals & sprinkler timer manuals
Jun 08, 2012 | Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
I have a Orbit 57161 Sprinkler System 6-Station Standard Indoor Mounted Control Timer with rainbird sprinklers the issue that I have is the sprinklers stay on and don;t turn off.what do i do?
Manual:
Website:
-Fuse blown
-Bad solenoid
Oct 04, 2010 | Orbit Sprinkler System Power Source...
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Hardware & Accessories Logo
50 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
