Question about Apple Mac OS 9.2.1
How do I adjust screen size to fit a monitor - Apple Mac OS 9.2.1
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 14 Answers
Try to adjust the ressuloosin
Posted on May 17, 2014
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
I have a viewsonic GA655 monitor and the screen is too big so you cant see part of it. How do I make it fit in the monitor screen? How do I adjust the size and geometry?
You didn't specify which operating system you're using! If using Windows 7 go to start --> control panel --> and under the category "Appearance and Personalization" choose "Adjust Screen Resolution", and adjust to an appropriate size!
May 05, 2011 | ViewSonic GA655 Monitor
When using firefox the content is bigger than the monitor screen. how do i adjust the content horizontally to fit the screen?
Did you try simply holding the Ctrl key and pressing the minus (-) sign? That will zoom the content to a smaller size.
Sep 08, 2010 | E-Machines E15T3 15 in. Flat Panel LCD...
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
Can i adjust size of display as a cracked screen has blocked some
Hi. The best thing to do is to get an external monitor and connect it to your laptop. Press Fn+F8 to show the display on your ext monitor.
^_^
Jun 07, 2010 | Dell Latitude D600 Notebook
Screen adjustment of toshiba satellite 25505
There is a micro cable that runs down one side of the screen then around the hinge then under the bezel and connects to the motherboard.
If everything is fine there then follow the process mentioned below.
right click on the desktop
click on "properties"
click on "settings" tab
click on "advanced options"
click on the "monitor" tab
uncheck the box that says "hide the modes that this monitor cannot display"
if you now click the "adpater" tab and click on the button to "show all modes" a full list of all screen sizes should appear.
click "ok" to close the advanced options window
you should now be looking at the screen setting window where you can adjust the screen settings by sliding the screen resolution tab left or right to the desired scree size for installing the program.
Aug 04, 2009 | Computers & Internet
Display is fuzzy
Go into monitor controls on monitor and adjust as they come up. Unhook monitor, power up computer, cut off, plug in monitor power up computer, right click on screen, settings, adjust for screen size and additional monitor by clicking 2 and saying yes in box. Hope this helps.
Jul 05, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Mar 12, 2009 | ViewSonic VP920b 19" LCD Monitor
Showing small screen size in monitor
FROM THE DESKTOP ON YOUR COMPUTER RIGHTCLICK on your mouse you wil get dropdown menu select properties tab then you will get display properties menu select the settings tab and adjust the sliding control to increase screen resolution to fit your monitors screen if this doesnt work you may want to have a video graphics card installed in your computer.
Jan 16, 2008 | SAMTRON 55V 15" CRT Monitor
Apple Mac OS 9.2.1 Logo
19 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
