Question about Dremel 8200-1/28 12V Max Lithium-Ion Cordless Rotary Tool Kit
How can i convert the dremel 8200 cordless to corded 12 v DC
Can i still use the speed controller ?
    Problem Solver:
  • 4 Answers
Why bother? A corded 12v will have barely adequate power for a number of jobs. If you're going to corded, then a 240v would be my preference, keeping the 8200 for jobs where the cord will be a nuisance.
Posted on May 27, 2014
I believe I have a loose/dirty electrical connection related to my cruise control on my 2006 Mercury Milan. Where are the connections exterior of the cab that I can check?
You have no idea what's up , all computer controlled ! The cruise control switches are input's to the PCM - engine computer ! There is no pressure sensor near the master cylinder for the CC . The vehicle has ETC - electronic throttle control . Your best bet ,take it to a qualified repair shop.
Here is a web site for free wiring diagrams http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Under system click on engine ,then under subsystem click speed controls . Click the search button ,then the blue links one at a time .
Speed Control The speed control system consists of the following components:
  • Speed control switches
  • Speed control deactivator switch (part of the stoplamp switch)
  • Stoplamp switch
  • Clutch pedal speed control deactivator switch (manual transaxle)
  • Speed control indicator
  • Powertrain control module (PCM)
Principles of Operation
The speed control system is controlled by the powertrain control module (PCM). The speed control system is designed to maintain a selected vehicle speed between 48-200 km/h (30-124 mph). The speed control system is controlled by the steering wheel mounted switches (ON, OFF, SET+, SET- and RESUME), the stoplamp switch, the clutch pedal speed control deactivator switch (manual transaxle), and the speed control deactivator switch (part of the stoplamp switch). The steering wheel mounted switches are hardwired to the PCM through the clockspring.
The speed control functions include:
  • turning the speed control system on.
  • setting and maintaining the desired vehicle speed.
  • accelerating the vehicle speed.
  • decelerating the vehicle speed.
  • turning the vehicle speed control system off.
  • canceling the speed control.
  • Do you know what DTC'S - diagnostic trouble codes are ?
  • Powertrain Control Module (PCM) Diagnostic Trouble Code (DTC) Index DTCs Description Source Action P0500 Vehicle Speed Error PCM REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual. P0579 Cruise Control Multifunction Input A Circuit Range/Performance PCM Go To Pinpoint Test C . P0581 Cruise Control Multifunction Circuit High PCM Go To Pinpoint Test C . P0833 Clutch Pedal Switch B Circuit PCM Go To Pinpoint Test D . P1572 Brake Pedal Switch Circuit PCM Go To Pinpoint Test B . P1703 Brake Switch Out of Self-Test Range PCM Go To Pinpoint Test B . All other DTCs - PCM REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual to continue diagnosis. Symptom Chart
    Symptom Chart Condition Possible Sources Action
    • The speed control is inoperative
    • Stoplamp switch
    • Clutch pedal position (CPP) switch
    • Digital transmission range (TR) sensor
    • Vehicle speed signal
    • Go To Pinpoint Test A .
Jul 24, 2017 | Mercury Cars & Trucks
Need to find fuse control for ford five hundred 2004 cruise control
Do you mean 2005 ? Didn't have five hundred in 2004 !
  • speed control switches
  • speed control deactivator switch
  • speed control indicator
  • powertrain control module (PCM)
  • electronically controlled throttle body
  • clockspring
The speed control system is controlled by the powertrain control module (PCM). The speed control system is designed to maintain a selected vehicle speed between 48 and 200 km/h (30 and 124 mph). The speed control system is controlled by the steering wheel mounted switches (ON, OFF, SET+, SET-, CANCEL, and RESUME), and the brake pedal. The steering wheel mounted switches are hardwired to the PCM.
  • turn the speed control system on
  • set and maintain the desired vehicle speed
  • accelerate the vehicle speed
  • decelerate the vehicle speed
  • resume the prior vehicle speed
  • turn off the vehicle speed control system
  • cancel the speed control
  • Smart junction box (SJB) fuse 18 (10A
  • Powertrain Control Module (PCM) Diagnostic Trouble Code (DTC) Index DTC Description Source Action P0579 Cruise Control Multifunction Input A Circuit Range/Performance PCM Go To Pinpoint Test C . P0581 Cruise Control Multifunction Circuit High PCM Go To Pinpoint Test C . P0720 Output Shaft Speed Circuit Fault PCM REFER to Section 307-01A or Section 307-01B . P0721 Output Shaft Speed Circuit Fault PCM REFER to Section 307-01A or Section 307-01B . P1500 Vehicle Speed Error PCM REFER to Section 307-01A or Section 307-01B . P1501 Vehicle Speed Error PCM REFER to Section 307-01A or Section 307-01B . P1572 Brake On/Off Failure PCM Go To Pinpoint Test B . P1703 Brake On/Off Failure PCM Go To Pinpoint Test B . Highly doubt a fuse problem . Take it to a qualified repair shop.
Jul 18, 2017 | Ford Cars & Trucks
How to fix cruise control on a 2006 ford freestar, does not work at all, wont turn on
Note the diagram, at least check the fuse. Check trouble codes, related to cruise control. to check codes yourself, at least, you need an obd2 code reader that will read po codes as well as manufacturer specific codes. It is worth the investment, in my opinion. Make sure the brake lites work.
Mar 05, 2017 | Ford Cars & Trucks
Blower fan not working at all 2004 Buick rendezvous
Which system ?
HVAC Systems - Manual HVAC Systems - Automatic
If automatic it's probably the blower motor control processor .
Blower Motor Control Processor The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, Blower motor speed signal, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module sends the commanded blower motor speed to the control processor through a 0 to 12-volt linear ramped blower motor speed control circuit. As the blower motor speed control voltage increases, the blower motor speed increases. The control processor sends the actual blower speed to the control module through a 0 to 12-volt blower motor speed signal circuit. The processor supplies 12volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
Nov 19, 2016 | Buick Cars & Trucks
Where is the cruise control fuse located?
In the SJB - smart junction box , Under the dash ! There are three fuse's - F2.27 10amp - F2.32 10amp - F2.17 15amp . Is your air bag light lit ?
SECTION 310-03: Speed Control 2004 Taurus/Sable Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 07/02/2003 Speed Control The vehicle speed control system consists of the following components:
  • Brake pedal position (BPP) switch
  • Speed control actuator cable
NOTE: The clock spring provides the electrical interface between the steering column wiring and the speed control switches in the steering wheel.
The inputs to the speed control actuator are:
  • Deactivator switch
The outputs of the speed control actuator are:
  • Speed control indicator lamp
  • Speed control actuator cable controlling the throttle position
Apr 01, 2016 | 2004 Ford Taurus
2007 Ford five hundred cruise control turns off when you hit a bump
First off the cruise control is computer controlled , need to check for diagnostic trouble code's . Your vehicle has electronic throttle control also . If your don't have a factory or professional grade scan tool your odds of being able to fix this yourself is close to zero ! You could find a wiring diagram an do some voltage drop testing ,mite find lose connection .
Speed Control
  • Electronically controlled throttle body
  • Clockspring
The speed control system is controlled by the PCM. The speed control system is designed to maintain a selected vehicle speed between 48 and 200 km/h (30 and 124 mph). The speed control system is controlled by the steering wheel mounted switches (ON, OFF, SET+, SET-, CANCEL, and RESUME), and the brake pedal. The steering wheel mounted switches are hardwired to the PCM.
  • Turning the speed control system on.
  • Setting and maintaining the desired vehicle speed.
  • Accelerating the vehicle speed.
  • Decelerating the vehicle speed.
  • Resuming the prior vehicle speed.
  • Turning the vehicle speed control system off.
  • Canceling the speed control.
The clockspring provides the electrical interface between the steering column wiring and the speed control switches in the steering wheel.
The inputs to the PCM are:
  • Output shaft speed (OSS) sensor
  • Stoplamp switch
  • SJB messages
The outputs of the PCM for the speed control system are:
  • Throttle command
The throttle position is completely controlled by the PCM through the electronically controlled throttle body. Speed control electronics are contained entirely within the PCM.
When the speed control system is active, the PCM corrects for deviations in the actual vehicle speed by proportionally moving the throttle plate. The PCM modulates the throttle to minimize error between actual vehicle speed and the desired speed.
The PCM strategy uses the throttle control for smooth accelerations.
The PCM sends a serial message over the controller area network (CAN) to the instrument cluster whenever the speed control telltale should be turned on or off.
In the event of an OFF command or a deactivation request from the deactivator switch, the speed control system carries out a hard deactivation and immediately returns the throttle to the idle position.
In the event of a CANCEL command input, the system deactivates and the throttle returns to the idle position at a smooth and controlled rate.
The speed control system provides self-diagnostics. The speed control system is disabled anytime an error is detected in the system. No cluster telltale or message center messages are displayed when faults occur. Fault codes are logged by the PCM.
An electronic throttle control (ETC) system fault also causes the speed control system to be disabled. In this case, an ETC system warning indicator or message center message is displayed.
Additionally, the following conditions cause the speed control system to deactivate:
  • Transmission gear selector is put into a position other than D or OD.
  • Parking brake is applied.
  • Speed control set speed is over-ridden with the accelerator pedal for a period longer than 5 minutes.
  • Vehicle speed loss from set speed of greater than 16 km/h (10 mph) occurs.
  • Vehicle speed falls below the minimum allowable limit of 48 km/h (30 mph).
  • Speed control switch is pressed or stuck longer than 2 minutes.
  • Powertrain Control Module (PCM) Diagnostic Trouble Code (DTC) Index DTC Description Action P0579 Cruise Control Multifunction Input A Circuit Range/Performance Go To Pinpoint Test C . P0581 Cruise Control Multifunction Circuit High Go To Pinpoint Test C . P0720 Output Speed Sensor Circuit REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual. P0721 Output Speed Sensor Circuit Range/Performance REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual. P1500 Vehicle Speed Error REFER to Section 307-01A or Section 307-01B . P1501 Vehicle Speed Error REFER to Section 307-01A or Section 307-01B . P1703 Brake On/Off Failure Go To Pinpoint Test B .
    Transmission Control Module (TCM) Diagnostic Trouble Code (DTC) Index DTC Description Action P0720 Output Speed Sensor Circuit REFER to Section 307-01A . P0721 Output Speed Sensor Circuit Range/Performance REFER to Section 307-01A .
Mar 04, 2016 | 2007 Ford Five Hundred Limited Sedan
Why did it stop working?
Depending upon its age and amount of use, the battery may no longer be fully chargeable.
Aug 22, 2015 | Dremel 8200 12V Cordless High-Performance...
Are Cordless heavy duty
I would not consider a cordless Dremel to be heavy duty. I have a corded one and I ca do a lot more with it than I would try with cordless.
Apr 19, 2015 | Dremel Tools & Hardware - Others
Cruise control stop working light dont show on dash can a fuse be out if so where is it located
There are three fuse's in the smart junction box , do you know where it is ? It's under the dash panel left side ! The fuse's are F2.27- 10amp , F2.32 - 10amp , F2.17 - 15 amp . They power the speed control servo ! Maybe the control switch's on the steering wheel don't work.
A little back ground on the system ! Speed Control The vehicle speed control system consists of the following components:
  • Principles of Operation
    The speed control system is designed to maintain vehicle a set speed above 48 km/h (30 mph). After the speed control ON switch is pressed, pressing the speed control switch SET/ACCEL will activate the speed control actuator. To increase a set speed, either press and hold for continuous acceleration, or momentarily tap the speed control switch SET/ACCEL for 1.6 km/h (1 mph) acceleration increments. To decrease a set speed, press and hold the speed control switch COAST until the target speed is reached, or momentarily tap the speed control switch COAST for 1.6 km/h (1 mph) deceleration increments. When the speed control system has been disabled by tapping the brake pedal, the speed control switch RESUME can be pressed and the vehicle will return to the original set speed if the vehicle is traveling over 48 km/h (30 mph) and the speed control switch OFF has not been pressed.
    NOTE: The deactivator switch is provided as an additional safety feature. Normally, when the brake pedal is pressed, an electrical signal from the brake lamp circuit to the speed control actuator will deactivate the system. Under increased brake pedal effort, the deactivator switch will open and remove power to the speed control actuator, releasing the throttle independently of the speed control actuator.
    NOTE: The clockspring provides the electrical interface between the steering column wiring and the speed control switches in the steering wheel.
    • Inspection and Verification
      NOTE: If any concerns are noted with the speedometer, stoplamps, or horn, address those concerns by referring to the appropriate sections before continuing speed control diagnosis.
      1. Verify the customer concern by operating the speed control system.
      1. NOTE: Any aftermarket modifications, including but not limited to those listed below, may cause the speed control to not operate correctly:
        • Any wiring or lamp modifications affecting the brake lamp operation
        • LED brake lamps
        • Non-factory installed trailer wiring
        • Radios (speed sensitive, auto mute)
        • Remote starters and alarms
        • Lighting and electrical accessory modifications
        Visually inspect for obvious signs of mechanical or electrical damage:
        • Visually inspect the speed control actuator and accelerator controls.
        • Visually inspect the speed control cable without removing it and ensure smooth cable operation. Inspect the speed control cable connection to the throttle body.
        • Visually inspect the accelerator cable without removing it and ensure smooth cable operation. Inspect the accelerator cable connection to the throttle body. Also check for cable interference with the carpet, bulkhead grommet, insulation and instrument panel wiring.
      1. Visually inspect for obvious signs of mechanical and electrical damage.
      2. Visual Inspection Chart Mechanical Electrical
        • Throttle linkage
        • Battery junction box (BJB) fuse(s):
          • 4 (40A)
          • 12 (60A)
        • Smart junction box (SJB) fuses:
          • 14 (15A)
          • 57 (10A)
        • Wiring harness
        • Loose or corroded connections
        • Bulb
Mar 14, 2015 | 2007 Ford Taurus
New Dremel 7700 not working on higher speed
I'm having the same issue. Can't find any more nformation to fix it
Jun 21, 2013 | Dremel 7700-1/15 7.2V Cordless Two-Speed...
Dremel 8200-1/28 12V Max Lithium-Ion Cordless Rotary Tool Kit Logo
120 people viewed this question
Top Dremel Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Dremel Saw Expert? Answer questions, earn points and help others
