Question about Samsung WA400PJHDWR Top Load Washers
Leaking water from bottom
Washer is leaking water from bottom of machine hose inlets are okay and drain line is secure
  • 121 Answers
SOURCE: machine leaks at beginning of rinse cycle
have you checked the rubber seal round the door might be torn
Posted on Mar 03, 2008
SOURCE: Samsung washer is leaking water
I've also had this problem with my machine , it was my brother who found out that the soap drawer has an irregular side over which the water jumps if it pours in with strenght from the tap. that's why the leak seems to be at the front, and only at the beginning of the cycle. We supposed it has to do with using the same drawer for different types of washers. we solved it arranging the low side with american tape and some square flat plastic. Good luck.
Posted on Nov 12, 2009
SOURCE: Samsung Front Loader wf306law took off back panel
I found MayTag has a full report on this washer. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8169153c018494398525729c0057a4d2/$FILE/Samsung_Frontier_Washer.pdf
The part number is DC97-10417A and can be ordered at samsungparts.com
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-DC97-10417A.aspx
Posted on Jun 21, 2010
  • 330 Answers
SOURCE: The machine leaks water from the bottom of the
you need to turn the water pressure down at the tap & adjust the front two feet to maximum height this is a very common problem for new front loaders no problems just adjust & it will be fine.
Posted on Jan 13, 2011
SOURCE: I have a samsung wf203anw
Posting a problem with your POS Samsung washer here is a waste of time! UII currently have the same problem a lot are having with this not draining nd code and I AM NOT going to pay for a tech to tell me that I have to have a guy come in to take my washer apart. I will do it myself!
Posted on Feb 28, 2011
My kenmore washer molel 110-82873120 is leeking from the top.
Dear R.A.,
If your washer is leaking you should first check the hoses.
  • There are several types of hoses found on a washing machine and the most common are the drain and fill hoses.
  • The fill hoses connect the household supply to the water inlet valve and are normally located at the rear of the washer. Check to make sure that the threaded fittings are tightened securely and that the leak is not caused by the faucet.
  • The drain hose is also located at the rear of the machine and may not be properly installed into the household drain. Verify that the leak is not caused by a restricted household drain that is backing up through the stand pipe.
  • Washers will also have internal hoses that connect the inlet valve to the tub. A defect in this hose would create a leak during the fill cycle.
  • Access the tub inlet by lifting the main top or removing the cabinet and inspect the hoses for signs of abrasion or cracking.
  • Also inspect the other components of the water inlet system such as a siphon break or tub injection assembly for signs of a leak. Check for loose or corroded clamps, and cracked or perforated hoses.
  • Your inlet Valves may also be totally defective and cause the washer to overfill therefore causing a leak over the top.
  • Check for the tub Pressure switch assembly may be defective causing such leak.
  • Your model requires removing the complete cabinet.(front and sides come out as on piece) Here a link to all your machine parts
I think we cover all the possibilities.
Best of Luck,
JP
KENMORE AUTOMATIC WASHER Parts Model 11082873120 Sears PartsDirect
Jul 03, 2015 | Kenmore Washing Machines
F20 error code
copied from the net..............
The "F20" fault code is indicating NO WATER IS BEING DETECTED ENTERING THE WASHER OR THE PRESSURE SWITCH IS NOT TRIPPING OR SENSING A TRIP.
If there is no water in the unit:
Make sure that both valves at the water source(s) are turned on all the way and water enters.
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
Verify inlet valve operation.
If there is water in the unit:
Verify drain pump operation.
Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch.
Verify there is not a siphon problem.
Press STOP twice to clear the display. The machine will drain for 3 minutes before unlocking the door.
Unplug washer or disconnect power.
Verify wire harness connections to inlet valves, pressure switch, drain pump and Central Control Unit (CCU).
Check all hoses for possible leaks.
Plug in washer or reconnect power
Verify pressure switch operation.
I recommend calling a service technician to diagnose and repair your washer if water will entering the machine and not siphon out.
cheers
Aug 03, 2017 | Kenmore HE2 Plus Front Load Washer
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Hoover Dishwasher HD95M leaks on start up from bottom right front corner. Leaks when initially being fed from water feed.
Water leaking can be poor plumbing or fault in the inlet hose connection. You are the first observer and so your view on the leak area is important as the leak can be from the hose, from the inlet, the hose or the washer unit.
Based on this the water leak can be plugged, tighten the hose clips, check the inlet filter or check the washer's feed line.
Feb 09, 2011 | Hoover HD95M Free-standing Dishwasher
Every time we wash there is water leaking, not sure were the water is coming from. i have checked the hose.
Hi.
Check that the leak is not coming from inlet valve itself. If the leak is from underneath the washer check drain pump hoses. You may need to disassemble the washer pulling up the top panel and accessing the drain pump at the bottom to find the leak.
Dec 05, 2010 | GE Profile WPRE6100G Top Load Washer
It is leaking from the bottom during the wash cycle. What is going on?
If you mean its leaking anytime you have water in the drum,the first thing to check is the drain hose connection at the back of the washer,You'll want to do this with the washer pulled out,(don't let the drain hose drop below the water level or you'll have a mess)If its not leaking there you should be able to look under the washer & see which connection it is(usually the inlet to the pump) Might be as simple as tightening the hose clamps.Hope this helps
Jan 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaks water out of bottom
hi friend,
Evidently you have reason to believe your washer is leaking. Probably there is water on the floor near the machine. Fine, then the first thing is some detective work. with an absorbent hand towel begin to inspect the areas where water enter or leave the washer. Those places are: 1. the hot and cold water inlet hoses located in the back and top of the machine and 2. the washer drain line, located in the back and bottom of the machine.
  • Step 2 One at a time, dry both ends of the hot and cold water hoses. watch for water to bead up. Water may be leaking from more than one place so don't stop with the first leak you find. Inspect all four possible connections and the hose itself. If there is a leak at a hose connection it's an easy fix. shut off the water supply of the leaking hose, unscrew the hose where it leaks and wrap Teflon tape clockwise around the threaded or male part of the connection. inspect the flat rubber washer in the female part of the connection. replace if it seems very worn. re-tighten the connection, dry and turn the water back on. check for the leak to return. If the leak in somewhere on the hose itself you will need to buy a new hose. Hot and cold water hoses are marked.
  • Step 3washingmachine3_thumb.jpg Next we need to check the hose where water drains from the washer. It comes from the washer near the floor level and usually inserts a male into the female of the washer hole. It then moves to the drain leaving the house. Again, dry the entire hose. Then you will have to run the washer. Use flashlight and inspection mirror to help you look for a leak during the draining process. If it leaks at the connection to the washer try reinserting and tightening the retaining screws. There usually are no threads to wrap. If that doesn't fix the leak or if you find a leak in the hose itself you will need to replace it.
  • Step 4 If you still have a leak under the washer it is probably in the drain hose between the drain pump and the outside hose or the short hose between the tub and the drain pump. This may be getting out of your level of competence. But if you want to be a Renaissance Man, give it a try.
    Unplug the machine. Now you need access to the bottom of the machine. depending on your brand you may be able to 1)remove the front by inserting a painters scraper and prying the spring snaps up, 2)remove the back by taking out screws and the rear plate or 3)you may have to go in through the bottom. With help tip it over on it's side. of course the machine will need to be empty of clothes and water as it's heavy enough already.
  • Step 5 However you access the inside bottom of the machine you will see a rubber hose coming down from the tub to a small electric drain pump then a plastic line will leave the pump and go to the back of the machine where it will meet up with the drain line you inspected in step 2. With your inspection mirror and flashlight look for water to indicate a leak. These lines are often held on by metal springs and can be moved or adjusted with open jaw pliers. If you find one of these hoses damaged take it off and bring it with you to your appliance store for a replacement.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • take digital photos before you remove any part. if you get confused you can use it as reference
    • don't work on the inside of the washer with it plugged in.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 24, 2009 | Maytag Washing Machines
    Washer leaks out of the bottom. checked drain hose it is not plugged, checked hot and cold water hoses they're ok.
    REMOVE THE TOP OF WASHER AND CHECK THE WATER INLET VALVE. I HAVE DONE EVERYTHING AND FINALLY DISMANTLED THE WASHER UNTIL I FOUND THE HOT WATER INLET VALVE WAS LEAKING FROM THE TOP AND DRIPPING DOWN THE TUB AND ENDING UP ON MY FLOOR. IT WILL DRIP EVEN WHEN THE WASHER IS NOT ON DUE TO THE PRESSURE BUILT UP ON THE VALVE.
    Oct 25, 2009 | LG WM2688HWM TROMM SteamWasher
    Go to fill machine water comes out of bottom
    You may have a leaky fill hose, or you may have a faulty 'donut' seal, which sits on top of the transmission and is sandwiched between the inner and outer tubs. You could also have leaky inlet hoses, which are attached to the wall water valve and then to the back of the washer. At worst, you may have corrosion on your outer tub that resulted in a hole through it.
    Pull your washer out from the wall so you can access the back. Try to see exactly where the leak is coming from. If your leak is from the inlet hoses, which is the most common place, simply shut off the water supply, remove and replace BOTH of the hoses, even if only one is leaking.
    If the inlet hoses are okay, remove the back panel of the washer (it's simply attached with screws - easy to remove), start the fill cycle of your washer and watch for where it is leaking. Look for calcium buildups on and around the hoses. These buildups would indicate a leak.
    If you find that an internal hose is leaking, remove the spring clamps at each end of the bad hose and obtain a replacement.
    ALWAYS UNPLUG YOUR MACHINE BEFORE MAKING REPAIRS!!!
    Oct 08, 2009 | Washing Machines
    Water leaks during rinse cycle
    MAKE SURE TO FLUSH-OUT DRAIN LINE. WATER IF IT IS DRAINING TO SLOW WILL START LEAKING AROUND THE LOWER PART OF THE WASHER WHERE THERE IS A SAFTEY OVER FLOW ... IF YOURS IS A FREE STANDING TOP LOADER THE DRAIN HOSE IS IETHER SEPERATE OR FLOWS WITH A CHECK VALVE THAT HOOHS RIGHT TO YOUR FAUCET. MAKE SURE THE CHECK VALVE AT THE FAUCET CONNECTION IS FREE AND NOT STUCK.
    May 07, 2007 | Kenmore Elite 20972
    Samsung WA400PJHDWR Top Load Washers Logo
    48 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
