Question about Refrigerators
I have a dometic refrigerator Model RM 2612. After running for a couple of days all the food inside freezes. There is no control that can adjust the temparature.
  • 10,865 Answers
The off - max dial is the thermostat. Turn it closer to off for a warmer setting
Posted on Jun 23, 2009
My Dometic RM2852 regiferator is freezing food and there is no manual temperature control.
I have found that certain types of food will freeze when left against the back wall of the refrigerator, which is where the cold air circulates down from the freezer..moving it away from the back wall can help...
Dec 16, 2012 | Dometic Refrigerators
The food in the refrigerator section freezes. we have lowered the temp control slide to the very bottom but still the food is freezing. Sherri Eley
perhaps try using the adjustment the opposite way -- to be sure you are not going cooler, instead of warmer for your adjustment?
Bets regards
Ck
Jan 17, 2011 | Dometic Refrigerators
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
My dometic rm 2612 stops working at least once a day the check light goes on.
Your 'frige has either; a 12 volt power supply or, a gas flame to circulate the refrigerant gas to cause absorption refrigeration to work; check or, replace your power supply as it 1. holds open the gas valve relay, 2. heats the gas with a heating element.
Mar 30, 2010 | Dometic RM2620 Refrigerator
Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Dometic RM2620 Refrigerator
Dometic RM 2804, freezer is ice cold, fridge is 60 degrees to warm for food
Adjust your temp control on the fins inside the fridge move it down it just slides on the fin. You may need a fan on the back of the coil to increase the air flow depending on the heat outside
Aug 22, 2008 | Refrigerators
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
