Question about JVC TH-M505 System
Why doesn't jvc home theater system jvc th m505 subwoofer work with tv?
SOURCE: JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Posted on Apr 10, 2008
tech48
  • 624 Answers
SOURCE: JVC TH-M505 No Sound
It is possible that a fuse has blown in the sub-woofer box. This unit has the entire amplifier built right into the sub-woofer. It also has a number of fuses in it. I have found that over the years fixing these units that if a fuse is blown you will also have more serious problems in the amp circuit. That is usually why the fuse will blow. They sometimes even have a problem in the main head unit with a digital transistor that is a surface mounted transistor that will cause this problem also. This transistor is part of the turn on circuit that signals the sub-woofer to turn on when the head unit is turned on. None of these problems are an easy fix I am sorry to say.
If you have at least a little experience with electronics and the right tools, like a multimeter and soldering equipment, I may be able to help you figure out the problem. But be aware that these are not easy to fix, and you may spend lots of time trying to figure it out just to find out that you will still need to take it in to a service center and in many cases when somebody tries to fix these type of units and have no experience with them they often cause more problems than they have started with.
For starters you can at least check the fuses, but please be sure to unplug the entire unit from the wall outlet before doing anything, there is a big risk of electrical shock.
The bottom of the sub-woofer has 6 screws in it (If I remember right) and those 6 screws must come out, they are rather big and you must use a number 2 phillips head screwdriver. Then after that you must take out all the screws from around the edges of the black metal panel where the speakers plug in to. When those are all out you can pull the amplifier unit right out of the sub-woofer box. Be careful when you pull it out, you will need to unplug a set of wires to get it all the way out, maybe two sets of wires, I am going off of just my memory right now, but if you need more help I will look up the service manual to help you more.
You will find at least one fuse right near the board where the A/C plug goes to and then you will find a few more fuses on the board that is on the right side while looking at the amp block from the same position you pull it out from and this board is plugged into the bottom board and is vertical but the short side is up and down, the long side is going towards the back of the amp and it is running along the metal chassis on that right side.
I hope this helps you, if you need more help just post your questions here.
Dave
Posted on Nov 26, 2008
  • 52 Answers
SOURCE: Hello,
If the JVC m606 requires a stipped wire to connect them then they should be fine just make sure you connect the right speaker to the proper output if your speakers have a specified connector on the end then you would have to cut that off and strip the wire. if your m606 requires a specified connector for the speakers then you would have to change the connectors out for the proper ones.
Posted on Mar 07, 2009
  • 22 Answers
SOURCE: Connect IPOD to JVC TH-M505 Theater System
http://www.superwarehouse.com/Cables_to_Go_iPod_Audio_Cable/35508/p/1492128
the above cable will allow you to plug your ipod into the audio in on the stereo
Posted on Jun 13, 2009
josetejas
  • 300 Answers
SOURCE: JVC Home Theater System M505
Wiggle on the long round cable connected to the Sub woofer. If the SW turns on, open it and solder the connector or change the connector
Posted on Jan 20, 2010
WHERE CAN I BUY A SP PWM505 CABLE THAT GOES FROM MY RECEIVER TO THE SUBWOOFER? ITS A HOME THEATER
  • Here is a list of cables for your unit from Crutchfield's.
  • If your looking for the s pin DIN cable from the sub you can get that anywhere. The 8 pin DIN is a standard cord the same across the board. Here are a couple to choose from.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Oct 11, 2011 | JVC TH-M505 System
I CANT FIND A SP PWM505 CABLE
Regards, Tony
JVC Home Theater System M505 The subwoofer will not come on and it appears that the system (speakers) will not work at all until it runs thru the subwoofer system.
Jan 18, 2010 | JVC TH-M505 System
Can you hook the jvc th-m505 to your tv for suround sound? and if so how?
your tv needs to have audio outputs... run the rca wires from the out to the in on your system in the aux 1 or whatever you choose for your tv
Jul 30, 2009 | JVC TH-M505 System
JVC TH-M505
There are very few uses for the subwoofer. Try it on FM if you get audio the woofer is working.
Apr 22, 2008 | JVC TH-M505 System
Jvc
i need a jvc subwoofer
Jan 29, 2008 | JVC TH-M505 System
Jan 12, 2008 | JVC TH-M505 System
JVC TH-M505 System Logo
90 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
