Question about Candy CPL321K Refrigerator
Hi. I have a temperature gauge on my fridge 1-5 is 5 cold or is 1?
  • 351 Answers
5 is the highest setting (coldest)
Posted on Jun 23, 2009
1999 Honda VFR 800 temperature gauge not reading correctly
Hi, David and the usual suspects are:
1. Grounded temperature light/gauge circuit.
2. Faulty thermostat temperature sensor.
3. Faulty cylinder head heat sensor.
4. Faulty thermostat.
5. Faulty light or gauge.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Temp gauge not working
Temp
1998 2001 Honda VFR800FI Service Manual VFR800 Moto Data Project
https://www.partsfish.com/page/oem-parts-for-honda
Honda 1999 VFR800FI Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 26, 2018 | 1999 Honda VFR 800
Thank you for the opportunity. I have a Ford Escape 2001 6 cl and temperature gauge stocks on cold. Today it moves to hot then went to neutral and slowly went to cold again without moving.
Hi Ivette,
Temp sensor/sender units, ussually send a variable earth resistance dependent on temperature, so it sounds like the wiring is broken/rubbed through, causing the sporadic changes due to full earth going to gauge(hot). brocken wire(cold)
But could be a faulty sender just the same, doesnt sound like a thermostat after driving the gauge would still move in relation to engine temp, would start by checking the wiring to temp sensor, also check coolant level and monitor engine temp while driving if gauge is in-op.
Hope this helps.
Feb 03, 2016 | 2001 Ford Escape
My car wont go in between the hot and cold meter
engine - Car temperature displaying below Cold or just ...
mechanics.stackexchange.com/.../car-temperature-displaying-below-cold...
Jun 25, 2012 - Today I was boiling inside my car as it was a very hot day and my ...cold, it almost never goes up to even 1/4 of the temperature gauge, the ... Where I live, it's hot enough that even with the thermostat wide open the engine won't stay at C.. ... How to Match Skin Color Between Pictures Of The Same Person In ...
What does it mean when my car's temperature gauge is halfway ...
https://answers.yahoo.com/question/index?qid...
Aug 23, 2011 - I think my temperature gauge is usually all the way to the left, which I think is "cold" (okay). ... before steam poured from under the hood of my car and I had to pay $217 ... Why does my A/C stop blowing cold & my temperature gauge goes toHOT? ... But the battery won't keep a charge after sitting over night. my temp gauge always stays on cold. never moves.? ' Yahoo Answers
Mar 28, 2014
My car temperature gauge started going crazy and it doesnt even ...
Nov 10, 2011
My engine temp gauge reads below normal, close to cold, even ...
Mar 23, 2007
my temperature gage on my car keeps going up and down.. does ...
Feb 15, 2007
More results from answers.yahoo.com
Dec 01, 2015 | 2002 Acura RL 3.5
Temperature light at back of fridge randomly goes from red/green and the temperature in the fridge does not appear to be stable?
on a fisher paykel I would call them direct, their help desk can walk you through some checks to see what the error is... if I needed service on this unit I would use who they suggest.. because if the servicer does not have access to the factory on FP HE IS GOING TO BE GUESSING WITH YOUR POCKETBOOK in hand... we work on FP everyday and we call often....... I hope this helps.... ken
Sep 29, 2014 | Fisher and Paykel Refrigerators
Fridge is running but not getting cold. Line underneath feels very cold but air coming in fridge is not cold. Fan under the freezer and fridge is running.
Hi
If refrigerator is not cooling properly it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer is bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to a bad defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps...please post back for further assistance.
Daniel
Jul 17, 2011 | Refrigerators
Fridge temperature is too cold, food id freezing. freezer seems fine. even adjusting the fridge temperature up to 1 does not change the temperature. seems to be stuck at 30F.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 10, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Temperature gauge not working,stay cold
Hi. the vdc at the sensor seems to be fine. if the ground is sufficient, i would replace the gauge. its malfunctioning. Check for loose connection at gauge before replacing the gauge.
May 14, 2009 | 1997 Ford Contour
The heater is blowing cold but the engine temperature reads high
Hi
I would first check to see if both heater hoses are hot to the heater.
if 1 is hot and 1 is cold the heater control valve is closed or the heater core is plugged.
Jan 14, 2009 | 2005 Dodge Ram 1500
Fridge freezer
Check your settings for the temperature controls. Freezer may be set to warm (IE #1) set it mid point. Also set the refrigerator at mid point and go from there to adjust each to maintain the temperature balances.
May 31, 2008 | Freezers
Candy CPL321K Refrigerator Logo
2,291 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
