Question about Refrigerators
Frigidaire icemaker still overflowing after replacing inlet valve
  • Danny Fisher
    Danny Fisher May 17, 2014
    ice maker was replaced about a year ago, inlet valve replaced yesterday
  • Danny Fisher
    no luck. still overflowing. would a new icemaker fix problem. I hate to have to buy another so soon, but I dont see what else it could be
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
Make sure the water is not splashing out the fill tube rather than the icemaker. Sometimes ice forms in this tube and causes the water to shoot over the tube and run down. You could also try turning the water faucet valve down a bit. Your water pressure could be too high and it is filling too fast. Last thing if you have very hard water the cubs could be sticking in the mold tray and not releasing. When the icemaker fills again there is still ice in ther causing the icemaker to overflow.
Posted on May 17, 2014
  • 883 Answers
SOURCE: amana scd23vw
attempt to pry off the plastic cover over the ice-maker (or look for screws). You should see at least one screw adjustment and clockwise turn is more water.
Posted on Jun 06, 2007
rpbuice
  • 161 Answers
SOURCE: Ice maker overflows
The Icemaker may not be dumping the cubes after they freeze then more water pours in on top of them. The icemaker has a heater which turns the cubes loose and allows them to dump. You may find someone to work on an icemaker, not sure. If this is the case, I would replace the icemaker.
Posted on Dec 16, 2008
dididsaythat
  • 291 Answers
SOURCE: ice maker water will not stop/overflows
either u got a bad ice maker or the spout going into the ice maker is leaking, ect.
Posted on Sep 03, 2007
shinn8
  • 85 Answers
SOURCE: Ice maker is overflowing, I replaced the valve and the water is still overflowing the tray
This is usually a problem with the icemaker. The only fix is to replace it.
Posted on May 21, 2009
aasc
  • 1606 Answers
SOURCE: Kenmore Icemaker Leaking! Is the water control
Replace the dual water inlet valve . The piece the line from the wall connects to .
Posted on Jul 25, 2009
Water from ice maker leaks into freezer and freezes door shut
http://www.appliancepartspros.com/frigidaire-valve-242252702-ap5671757.html
It sounds to me like the valve is not closing all the way and allowing water to flow when it should not. This overflows the tray and allows water to run to the bottom of the freezer. It could also be a timing or switch issue. IF you want to be sure replace the valve and if that does not work then replace the whole icemaker.
Jun 28, 2015 | Frigidaire Refrigerators
Water flows into ice maker when water lever is pushed
Be sure that you have the water inlet valve wired correctly.
Nov 26, 2012 | Refrigerators
Ice maker not working on model #frs24zsg
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | Frigidaire FRS3R5EMB Side by Side...
Icemaker overflows into holder freezing
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 07, 2009 | Refrigerators
Freezer is not making ice, help?
Pour about 1/2 cup of water into icemaker . If it dumps the cubes after freezing , but doesn't refill with water , then replace the water inlet valve ( part that wall water line connects to on fridge ). If the icemaker does not dump and holds the frozen cubes , replace the icemaker . Also check the fill tube at the icemaker to make sure it is not frozen closed , due to a seeping water valve , and make sure the coils are clean beneath refrig of dust , lint , pet hair , etc.
Aug 28, 2009 | Frigidaire FRS26H5AS Side by Side...
Water dispencer drips into overflow tray
Needs a replacement kit. Not too hard to do yourself.
Jun 27, 2009 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
No ice
you can feel for water in ice maker. if not then verify inlet valve function. water inlet valve for ice maker side could be seized up
Jun 22, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
May 21, 2009 | Refrigerators
Ice maker overflows
Dec 16, 2008 | Amana Refrigerators
Frigidaire not making any ice...
check inlet tube behind icemaker and make sure its not froze up. If so, it may just need to be thawed out but if it happens again you will need to replace water valve.
Jan 07, 2008 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
