Question about Briggs & Stratton Garden
How to start motor after sitting up long period?
  • 778 Answers
Hello, First check oil level to make sure it is ok. Then, take out the air filter and clean, also take spark plug out and clean and check the gap according to your users manual. Add fresh gas and choke and start.
Posted on May 17, 2014
I have a 25 hp johnson outboard motor that won't start
Probably needs a good service,check compression first,bottom crank seal could be leaking
Oct 10, 2014 | Boating
Quits running periodically. Cranks over but will not start. Let it sit for 15 minutes, it starts. I have had it towed twice to the repair shop and they could not find anything wrong. I take it home,...
CHECK BATTERY TO BODY AND BATTERY TO MOTOR GROUND FOR COROSSION UNDER BOLTS. ALSO CHECK GROUND STAP FROM MOTOR TO BODY FOR CORROSION. BAD GROUNDING CAN CAUSE ALL SORTS OF ELECTRICAL PROBLEMS
Sep 07, 2010 | 2001 Jeep Grand Cherokee
I own a 1978 motor home with a qne ton van frame\r...
Over an extended period of time gas will evaporate in a carburator. It's possible that presure is leaking off in your fuel pump as well. A weak pump will have trouble maintaining pressure over a period of time and will have trouble building pressure back up. Starting the engine on a regular basis and letting it run for a few minutes will cure the problem and help keep the engine seals from drying out and leaking. Converting to an electric fuel pump will also make it easier to start after sitting for a period of time.
Any generic LOW PRESSURE electric pump will work. It only needs to put out between 7 and 9 or 10 pounds pressure. Unhook the fuel lines from your mechanical pump and hook to the electric. The li ne from the tank goes on the inlet end. The electric pump usually ground through the case so it needs contact with bare metal or a wire running from the case to bare metal. Run the power wire to a powered wire in the engine compartment that powers on and off with the key or to an accessory fuse in the fuse box. It should run through a 20A fuse.
Hope this helps.
May 20, 2010 | 1983 Chevrolet C3500
Gas getting into oil
sounds like the float in the carb needs adjusted.it will happen if it sits for a long period of time,but id get it fixed because the gas dilutes the oil and decreases the viscosity and could harm the engine.or you could turn the gas off at the petcock as i do on my fourwheeler which has the same problem.
Mar 30, 2010 | Boating
Miss sometime after sitting
It it sits for an extended period of time this could be due to bad gas (gas can go bad in as little as two weeks when left sitting); or it could be you have bad vale seals or other seals leaking slightly. This can only be determined by doing a good check out of the engine and systems.
If it only does it for a min or two after sitting then starting, I wouldn't worry too much. Alot depends on the age of the motor and how many miles you have.
Jan 29, 2010 | 1997 Lexus ES 300
Battery good, alternator good, when vehicle sits for a period something drains the battery. if disconnect battery cable and leave sit can reconnect days later and it will start no problem. Any idea of...
its not a problem all cars all batteries do that if they sit after couple day min especailly long period of time you will always need a jump to get those cells in battery alive and active once car starts its good should have no problems
Jan 14, 2010 | 2000 Daewoo Nubira
Starting problem after engines warm smell gas
I had the same problem. It may start to or already is stalling as you slow down or stop. I changed my fuel pressure switch located right on the fuel rail on top of the motor. It's about $80.
Nov 17, 2008 | 1999 Chevrolet Silverado 1500
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
