Question about Mustang Rzt 50" Zero Turn Riding Lawn Mower
How do i get my oil light turned off - Mustang Rzt 50" Zero Turn Riding Lawn Mower
2006 Honda CBR 600 F4i oil light turns on
Hi, Anonymous and the usual suspects are:
1. Insufficient oil level or no oil in engine or tank.
2. Air in oil system that needs to be bled.
3. Blockage in the oil tank or line.
4. Oil pump failure.
5. Faulty oil pressure sending unit.
6. Grounded oil pressure light circuit.
7. Oil maintenance light needs to be reset.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.fireblades.org/forums/honda-cbr-600/86120-2002-f4i-oil-light-blinks.html
Oil light is blinking then goes away when running CBR Forum Enthusiast...
Honda CBR600F4I 2001 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CBR600F4i Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 18, 2012 | 2006 Honda CBR 600 F4i
How to get change oil light to go off
Instructions:1) Check the oil. The light is a warning signal that you are low on oil or that the oil is not flowing properly. If the oil level is fine then the issue may be a reset button. Two different methods will allow you to reset the oil light.2) Turn the key to the on position. Do not turn the engine on. Press the accelerator pedal down three times in a five-second period. Turn the engine on. If the oil light goes off you have successfully reset the oil light. If it stays on you need to try the second method.3) Find the fuse box. This should be under the dash in between the steering wheel and the door. Open the fuse box and look for the reset button. Press the button until you hearing a beeping sound. It will beep three times. The oil light should be reset. Turn the engine and see if the oil light goes off. If the oil light stays it still has not been successfully reset.
4) Read the manual. The two methods above are the two most common ways of resetting the oil light. Your car may have additional options to try. If none of the methods resets the oil light then there is a different problem such as a non-functioning oil sensor. At this point you need to see a mechanic.
Parts Of BMW.
May 30, 2012 | 2005 Dodge Magnum
How do you rest the oil light
When you turn any vehicle on the oil light comes on. This is the the test that the lets you know the oil light is working correctly. When you start your vehicle the engine builds oil pressure and the pressure should turn the light off. If your oil light does not turn on when the key is turned on you either have a burned out light bulb, no power to the switch, or a defective oil pressure sender. Always start with the cheapest fix first (light bulb).
Feb 17, 2011 | Suzuki GSX-R 600 Motorcycles
Blinking oil light on 2003 Mazda Protege. Changed oil and oil filter as well as oil sensor. Light still blinks when the car is idled up.
You need to reset your change oil warning light. To do this, turn the ignition key to on but do not turn over the engine. Then rapidly push down the gas pedal three times. This will reset the system and turn off the blinking light. Then when you drive another 3000 miles, that light will once again tell you it is time to have your oil changed. J.
Jun 20, 2010 | 2002 Mazda Protege
I have a 2000 bmw 323i thats is leaking oil when i start the car the oil light comes on and after 30 seconds it shuts off. I added a quart of synthetic oil and the light still appears.I would like to know...
did you check the oil ?
-if oil level is low the the oil light will turn On.
-the oil pressure switch loose connection or Bad ,the oil will turn ON.
-Bad oil pump, oil will turn ON.
Apr 22, 2010 | 1999 BMW 323 Series
Oil level low light comes on. When I turn
some cars with oil level warning light on, it doesn't mean that its only reading the engine oil level is low, sometime the transmission fuid too. Did you check your transmission fluid if it is ok or not? try to check and let us know, ok.
Mar 14, 2010 | 1999 Buick Century
Oil light stays on
You need to put the key on and push the gas pedal to the floor three times within five second to reset the oil life light.Some g.m.'s have a reset buttom in the fuse panel that needs to be pushed first and some don't.Check the owners manual under change oil for your specific year car.
Oct 21, 2009 | 2003 Chevrolet Impala
Tundra 2007 - turn off "maintenance required" light
Oil Change Reminder Lamp: Service and Repair
Engine Oil Replacement Reminder Light
This light acts as a reminder to replace the engine oil.
This light will come on when the ignition key is turned to "ON" and will go off after about a few seconds.
When you drive for about 7200 km (4500 miles) after the engine oil replacement, this light illuminates for about 3 seconds and then flashes for about
12 seconds with the ignition key turned to the "ON" position. If you continue driving without replacing the engine oil, and if the distance driven
exceeds 8000 km(5000 miles), the light will come on. The light will remain on thereafter.
If the light is flashing, we recommend that you replace the engine oil at an early opportunity depending on the driving and road conditions. If the light
comes on, replace it as soon as possible.
Resetting the system
The system must be reset after the engine oil replacement. Reset the system by the following procedure:
1. Turn the ignition key to the "OFF" position with the odometer reading shown.
2. Turn the ignition key to the "ON" position while holding down the "TRIP METER" reset button.
Hold down the knob for atleast 5 seconds. The odometer indicates "000000" and the light goes off.
If the system fails to reset, the light will continue flashing.
Sep 30, 2009 | Toyota Cars & Trucks
Mustang Rzt 50" Zero Turn Riding Lawn Mower Logo
183 people viewed this question
Top Mustang Garden Experts
Dennis Key
Dennis Key
Tim Whalen
ray gallant
Are you a Mustang Garden Expert? Answer questions, earn points and help others
