Question about Lionel The Polar Express Train Set
Why won't the whistle work? - Lionel The Polar Express Train Set
2000 chevy blazer won't get over 2200-2300 rpms and has whistle
kinda sounds like the catilist in the converter is bad and the exhaust cant get out
Oct 14, 2012 | Cars & Trucks
Battery is new but whistle stopped working...train runs otherwise
you need to replace the whistle batteries, i think it takes 3 aaa batteries under the smoke stack
Mar 05, 2012 | Peg Perego Santa Fe Express Ride On Train
When turning on ignition, just get a whistling sound and won't start.
Hi, the starter pinion is sticking or stripped. Take the top shroud off and you will see the problem. Regards Phil.
Jul 20, 2011 | Garden
At the end of the cycle prior to spinning the washer sometimes doesn,t start to spin, it just makes sounds like it,s trying to spin but won,t catch. If I open and close the lid it begins it,s proper cycle....
The timer is not allowing a cycle stop for the neutral pack to drop. Replace the timer and you should be in good shape. The whistling sound is likely something in the pump.
Kelly
Mar 21, 2011 | Whirlpool Washing Machines
Tv whistles upon start up.
Unfortunetly your tv isn;t whistling a happy tune it has a part (capacitor) that is failing. The problem is it is very hard to tell if it will pop and die on you next week or next year. And it is easier to find dead parts than iffy ones when trying to fix something. So unless you have warrenty keep using it. When it finally goes then get a repair estimate first and check out the replacement cost of the tv. A new tv might not be much more. The part itself is cheap but the labor won;t be.
Mar 23, 2010 | Televison & Video
Alessi whistling kettle -- one whistle doesnt work.
you need to replace it with a new one it will be corroded. heat kettle then drive out pitch pipe with a screw driver from below, insert new one from above.
Sep 24, 2009 | Alessi Richard Sapper 9090/1
Whistling noise from my 2005 chevy equinox
Are the windows up tight and sealed?
Mar 20, 2009 | 2005 Chevrolet Equinox
Lionel The Polar Express Train Set Logo
109 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
