Question about Bosch Saws
Will the Craftsman 315.172110 accept a t shank jig saw blade?
  • 12 Answers
SOURCE: Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Posted on Feb 25, 2009
joboo1
  • 257 Answers
SOURCE: Problems with Bosch T101BR 4 Inch 10 Tooth Jig Saw Blades
Hi, The reason for a down cutting blade is to see your cut on the finished side of laminates ( which include veneers, plywoods, plastics, formica . When using an upcutting blade on laminates the smooth cut is on the bottom, which you can not see till you are done and turn the work over. Reversing the teeth allows that smooth cut to be on the top. This is usually done on smooth flat surfaces as you have found out and does not work with orbital or tight scrolls. As far as the pushing or pulling, smooth cuts in laminates require the saw doing the work at a speed that allows the teeth to cut and remove material with biting. So if you are biting, (This is a much slower process than pushing your jigsaw through regular wood) check that you are not pushing too hard and that your blade is still sharp. Good Luck to you, this should Fixya!
Posted on Mar 08, 2009
  • 3 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: change blade 1587 Bosch avs
are you using the "T" shank blades and also are you loosening the spindle enough to allow the blade to turn, sometimes you have to push up a little to turn it and also pull away from the roller guide. Let me know and also there is a TINY spring in the top of the spindle that has a nasty habit of breaking and winding around itself not allowing proper operation.
Posted on Oct 10, 2009
FixYaSteve
  • 57 Answers
SOURCE: How do I change the blade on a Bosch pst 54E Jig
There's an exploded diagram of a similar model here. Don't let it confuse you though. I mention it, because it shows the clamp screw which hold the blade in place (35 on the diagram).
Unplug the saw before you change the blade.
In the handle directly over the blade there is a hole with a clamp screw at the bottom. Use a long thin blade screw driver to loosen the clamp screw.
Once the clamp screw is loosened, twist the blade about 90 deg and you should be able to pull it out (don't cut yourself, by accident)
Put the new blade in with the same orientation and twist so the blades are facing the front of the saw.
Tighten up the clamp screw and you're good to go.
Be careful not to tip your saw over while the screw is loose. If it falls out and you lose it they're a bit of a nuisance to come by.
Posted on Jun 14, 2010
I need a blade clamp for a model 105112 Mastercraft jig saw. Is there a substitute or universal clamp that fits?
Jig Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/jig-saw.html
  1. Cached
  2. Similar
Shop online for jig saw replacement parts for fourteen of the world's most trusted brands at Tool Parts Direct. We have the largest online inventory of Bosch jigsaw parts, Dewalt jigsaw parts, Black and Decker jigsaw parts, as well as replacement parts from other top manufacturers ...
mastercraft jig saw model 105112 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
  1. Cached
  2. Similar
Find solutions to your mastercraft jig saw model 105112 question. ... i need a parts list for a mastercraft jigsaw/sabre saw model 105-106 See this webpage: ...
Craftsman Jig Saw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-jig-saw-parts-c-158286_171667.html
  1. Cached
  2. Similar
Repair Parts Home Power Tool Parts Craftsman Parts Craftsman Jig Saw Parts. ... 07021 Craftsman Sabre Saw Parts. ... 315171600 Craftsman Sabre Saw 1/2 Inch Stroke Variable Speed Parts. 105112 Mastercraft jig saw Google Search
Nov 23, 2016 | Saws
How to change blade on a Chicago jigsaw
Harbor Freight Chicago Electric Jig Saw - Review - YouTube
? 2:21
www.youtube.com/watch?v=lSh0M4WIJTk
Dec 13, 2013 - Uploaded by AdamDIY
Chicago Electric - Orbital Jigsaw 92772 They change the design over time but some of the key flaws tend to ...
jigsaw from hell - chicago (electric?) brand - DoItYourself.com ...
www.doityourself.com/.../445560-jigsaw-hell-chicago-electric-brand.ht...
Mar 9, 2011 - Most blades either have a hole in the shank or the shank is shaped like a .... A brand new one is only about $25 and no tools for blade changes.
Oct 22, 2015 | Saws
What other blades can I use on my Bosch jigsaw saw PST 65 PAE
The type in a Bosch Jig saw accepts T-shank style blades. There a variety of companies that reproduce the original. Some of the list in no order preference are: Black and Decker, Cobalt, Dewalt, Fat Max, Fe Stool, Irwin, & Stanley to name a few. The following link offers a search page with urls to reach the above mentioned. There is also pictorial graphics to support style with function. Take a look. Google ;https://www.google.com/?gws_rd=ssl#q=universal+T+shank+jig+saw+blades+for+sale. This will be sure to entertain the toughest endorsement. Fare .Well. GO cut it up.
May 24, 2014 | Saws
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
Black and Decker JS305 blades come out. The only blades that will stay in this saw are the ones with a hold in the shank. I can not buy blades with a hold in the shank at Home Depot. Any advise.
I'm thinking the blades that go in Jig Saws are and have been standard since the late 80's. Once upon a time, blades were held on with a collar and a set screw while today they have a fat part that locks into the collet.
Can't find the proper blade at the Depot, my advice would be check with Black and Decker directly.
When I searched B&D, the first hits were Sears (Maybe at K-mart) and Lowes. Home Depot didn't come up at the top. You might find the blades you need at your local Ace or Sentry or Tru-Value or other brand hardware store. Be nice to support your local merchant, your neighbor.
Anyway, try here for your parts http://www.blackanddecker.com/ProductGuide/CategoryOverview.aspx?cPath=1496.2514.1020.147
I hope you find this information fruitful
Thanks for your interest in FixYa.com
please vote
positive comments always welcomed
thanks
a
Dec 06, 2009 | Black & Decker Scroll Jig Saw Blade
I have a milwaukee jig saw, 6268-21 that I cannot load blades.
Yes the Milwaukee 6268-21 does require the use of certain jigsaw blades. You have to use T-shank type blades. You push the tension lever hold it while putting the blade in as far as it will go, then you release the tension lever slowly and it will engage the blade. You should then check by pulling on the blade to make sure it is seated properly and will not come out.
Oct 20, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Borrowed a B&D jigsaw model 7571 want to know how two use the other speed and how to put the blade in properly....does not seem to cut without great force....Cindy
arrowred.jpgExclusive Quick Clamp® tool free blade change provides easy, tool free blade changes
arrowred.jpgAccepts U and T shank blades for use with your preferred blade
Aug 15, 2009 | Black & Decker Saws
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
Feb 22, 2009 | Bosch Saws
Saws Logo
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
