Question about Briggs & Stratton 020272 Elite Series Portable Gas Pressure Washer
How start small engine that has not been started in long time?
  • 778 Answers
Hello, First check oil level and make sure it is full. Then take out air filter and clean, then take out spark plug and make sure the gap is correct according to your users manual. Add fresh gas, choke and start.
Posted on May 17, 2014
I have 4350 pressure washer and the engine won't start
Colin, I will post some small engine trouble shooting guides for you to use and help solve engine not starting.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Repair Small Engine Problems Briggs Stratton FAQ
Small Engine Wont Start
Small Engine Troubleshooting
SMALL ENGINE NO START TROUBLESHOOTING
Apr 24, 2016 | Garden
Fuse gets hot and burns out
Small Engine Troubleshooting - Jacks Small Engines
www.jackssmallengines.com/diy/small-engine-troubleshooting/
Mar 20, 2015 - Engine Will Not Crank; Cranks - Will Not Start; Runs Rough On Low ... Engine not running (After Hot Test); Stops on High Idle; Hot - Will Not ... Paint or oilburn off. .... I have a Honda self propelled lawn mower that will not stop right away ... ends puts the motor out of time change the fly wheel pin if it's not the ...
Electric Mower will not start, trips the breaker? - Instructables
www.instructables.com/.../Electric-Mower-will-not-start-trips...
Instructables
Dec 29, 2015 | Garden
My Nissan sunny b14 won't start after it ran out of fuel and when I refilled it that's it, it won't start at all! What's the problem??
Take off the small wire from the starter. Turn the key as if you were starting the engine. Hold it there for a few minutes. This allows the fuel pump to run, without cranking the engine, long enough to build up pressure in the fuel system. After that re install the small wire on the starter. Now try starting the car. You may have to repeat the steps if not enough time has passed running the fuel pump.
Jul 15, 2015 | Nissan Cars & Trucks
Car wont start timming belt is being cut into strips engine wont start
The belt is worn out and is disintegrating. It has probably jumped time. The reason the engine won't start. Depending on your car, Some engines are no tolerance. Meaning if you keep cranking it and the belt breaks, the pistons can slap the valves, bending or breaking them. Replace the belt.
Nov 15, 2014 | Cars & Trucks
I tried jump starting a diesel engine with my petrol engine now my petrol engine wont turn over although the battery is good why ?
Some times the extra amperage coming from the alternator the diesel motor will burn out the electrical components of a smaller vehicle. This is why you should never jump start your lawnmowers, motorcycles, or any small engine with a full size vehicle. Check your battery, then alternator, and keep tracing it back until you find the source of the problem.
Apr 21, 2013 | 2005 Toyota Avensis Sedan
Started cutting out. then quit running. wont start now. fuel filter is good. would it be something besides fuel pump?
Get a spray can of either (starting fluid) While someone cranks the engine spray SMALL amounts of the fluid into the air intake. I stress small amounts a little at a time so you don't blow the engine. If the engine does start I would check to see if you have water in the fuel system first and if not I would check the fuel pump pressure.
Dec 21, 2010 | 1989 Buick LeSabre
Nissan Altima 2004 SES light and some times engine donot start
its going to be between the motor and tran on the back lower part it is going to be in between a small gap i chande it on my friends car and it work
Aug 24, 2009 | 2005 Nissan Altima
How to remove a td27 fuel injector pump in order to reseal it?
hi.. I have TD 27 engine. first time I start it. there is small miss.so I` ve removed the whole injector pump , cleaned it & fix it. now it doesn`t start first time. but few times I tried. it will starts. but when I increased the engine speed taped noise coming. if there is any timing of the injector pump. please help me to solve it .
thanks. jaya.
Jun 13, 2009 | 1997 Nissan Pathfinder
Despite changing the sparkplug and proper choking, etc. no start
The most likely culprit is a clogged carb - a very common problem indeed on Tecumseh motors. Pull the carb off, open it up, spray everything with cheap carb cleaner (especially the bottom "bolt" that hold the float cover making sure it sprays out of at least two sides as that "bolt" is also the jet), make sure everthing lines back up as you pulled it apart and now try to start it up again! Bet it works, I see it all the time on small engines left with small amounts of gas in the system. Good luck, and I hope that gets ya runnin!
Mar 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Car engine fails to start at times.
If the starter turns, i would presume that there is a problem with your ignition switch.
Mar 07, 2009 | 1987 Subaru Justy
Briggs & Stratton 020272 Elite Series Portable Gas Pressure Washer Logo
165 people viewed this question
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
