Question about Mastercool 67680 Evaporative Cooler Air Conditioner
All lights on the thermostat are blinking on my master cool evap.cooler, it is a vaiiable speed moter
2 Suggested Answers
SOURCE: Our Bonaire Evap Cooler stopped after power failure
you need to turn off power supply to unit that works ok and leave other unit switched on and code it and test it then switch other unit back on
Posted on Jan 30, 2012
I have a Master Cool cooler and thermostat and I have never seen this before. Lights 7 and 8 are blinking red. What does this mean?
If you don't have user's manual or if doesn't mention the meaning of blinking lights, look al manufacturer's website, for "Contact Us", see if they have a cusomer's service phone number or a way to leave them a message.
Sep 06, 2015 | Furniture
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
The unit in question is a Master Cool portable evap cooler model #P500A. Everything operates perfectly accept the fan blower unit when turn on. Switch panel lights up but no blower operation. Are their...
The bearing on the blower motor are probably rusted or stuck from winter storage but you can disassemble the cooler and try to re-grease the blower motor front main bearing to access the rear bearing you have to take apart the blower motor . i had the same problem with my two p500a models and they work perfect now . i couldn't find any replacement parts but if i do i'll post the web site here hope this helps you with your problem N0D0ZE
Jul 22, 2011 | AdobeAir Adobe Air 550 CFM Portable...
So I have ASUS silent sqare pro CPU cooler for about 6 months, but the little blue thingy that shows the fan speed died, well it still shows the speed of the fan but the nice blue light is dead, it just...
Either the blue LED is faulty or the LED needs replacing or resoldering to make proper electrical connection.
If you cannot fix it yourself and the fan functions normally then don't worry about it.
Jul 07, 2011 | ASUS Silent Square Pro - Processor cooler...
I have an oster wine cooler model #owo912H6H that was not cooling i took the back off and have a blinking red and green light and a fan that would **** and run a few turns and stop i cleaned the fan and it...
It seems this is either due to faulty fan or fan motor. This could be a reason that the wine cooler is not cooling at optimum rate. As i cannot see the cooler, this is what i could judge from the information you gave to me.
I would still say, it would be worth repair, if this is due to faulty fan or motor ( motor seems to be the main cause ).
The main tough thing would be to get fan motor. You could try to get a replacement motor or a compatible one from the parts store near your home and give a shot. More likely, you would be successful, if the fault is related to motor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 25, 2010 | Refrigerators
Motor does not go from low speed to high speed If the motor is set to low speed it does not turn on until the high speed range is hit then it tries to go from stop to high speed and throws thw belt
MOST OF THE TIME IT IS THE DIGITAL THERMOSTAT OR LOOSE TERMINAL AT THERM. THESE STATS ARE TRICKY TO CHECK. LIKE WHITE ROGERS 4 WIRES CONTROL WITH A RED WIRE TO GREEN YOU GET PUMP WHITE YOU GET LOW YELLOW YOU GET HIGH AND SO FORTH. MASTER COOL DOES IT DIFFERENT SO YOU BUY THEIR TSTAT
Apr 21, 2010 | Mastercool 67680 Evaporative Cooler Air...
Master cool thermostat timer hours 7 and 8 are
I have the same problem and hope someone has a solution
Jul 04, 2009 | Heating & Cooling
Fan is slow
I dont have a solution, but I have a similar problem with a Bonaire evap rooftop cooler which only started after a tech came to look at the unit when it stopped operating properly last summer. He said it uses less water now, but the issue is that it doesnt cool any where near as effectively with the fan speed so low. I am located in Melb Australia, and wonder if you are in the same area. I am going to call service AGAIN & get the minimum fan speed returned to what it was previously. I wonder if my original unit is too small for the house - but nevertheless, it used to work beautifully and now is a very poor example of evap cooling. The service guy said the base fan speed could be altered from the controller, but we dont know how to get into the setup menu.
Jan 30, 2009 | Dometic Rooftop RV Air Conditioner
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
