Question about Sears Craftsman 120V Electric Mini Tiller
My tiler won't start
Its plugged in. I press the button and nothing happens. It worked last year. What can I do? I pushed the "reset" button and nothing happened. The outlet works because I have something else plugged into it fine. I tried a different extension cord and that didn't do anything either.
myob247
  • 1342 Answers
SOURCE: garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Posted on Jun 19, 2008
  • 244 Answers
SOURCE: garage door circuit board replacement
get instructions and program. I hate Genie
Posted on Jan 15, 2009
Door Tech
  • 98 Answers
SOURCE: Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Posted on Jan 17, 2009
  • 3197 Answers
SOURCE: Have Craftsman model 139.53754 keyless entry pad.
There is always the possibility that it has just quit but you can try programming it. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in your 4 digit code and press enter.
Posted on Jul 15, 2010
  • 3197 Answers
SOURCE: Our Craftsman Model 139.53684 Keyless
Sounds like your logic board has quit working.
Posted on Nov 05, 2010
Oven won't start
Try pushing the "convection oven" or "bake" button first, then enter the temperature you want. Then "Start".
Sep 24, 2012 | Thermador SC272T Electric Double Oven
Troy built tiler won't start!!
What is the method your machine uses to decide when to fire the spark plug? Does it have a magneto, and/or ignition points under the flywheel, or a crankshaft postion sensor?
Apr 18, 2017 | Computers & Internet
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
It won't start. when I push the test reset button it attempts to come on for a second then nothing. I changed outlets and same thing happens. before I did this the water would come out of the nozzle...
Had a similar problem with a Karcher that I own, after a little troubleshooting it turned out to be the big plug end with the reset in it, I took the plug end apart and found the contacts inside had melted thus not allowing proper contact of the reset button, I opted for a cheap way out, instead of ordering a replacement reset plug assy i changed it over to a regular 3 prong gfi plug end, been working great the past few seasons,hope this helps
Aug 12, 2011 | Karcher Pressure Washer 1800 PSI 15 GPM...
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
Whirlpool Calypso - Will not start
You ever hear of dog years? Well Calypso follows those same guidelines. So your machine is 35 years old. These are the Edsel's of washing machine fame. I had a Calypso for 6 1/2 years. 3 pumps, numerous circuit boards, drive motors, phone calls and arguements with Whirlpool, along with machine downtime. I finally junked it and bought a Whirlpool Duet 9200 HT (get the made in Germany machine). A world of difference in wash quality. Fresh smelling unballed clean clothes. The Calypso was removed from the market and the subject of a class action lawsuit. Just Google it and start reading. Get comfortable first. There's a lot to read.
Nov 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Sears Craftsman 120V Electric Mini Tiller Logo
Top Sears Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dennis Key
Dennis Key
Are you a Sears Garden Expert? Answer questions, earn points and help others
