Question about All-Pro Heating & Cooling
Operating manual for doortronic lift king lk800
    New Friend:
Hi Murray,
try this link I've used it many times before to find user manuals for products I've lost or for example, I just moved in to a new home but the sellers didn't have any of the op manuals for water softener/ alarm system, garage door opener, etc....
www.manualsonline.com
hope it helps!
Posted on May 17, 2014
Need Operator's Manual Farm King 16, made by MTD
See if this what your looking for. Farm King 16 appears to be one the MTD 990 series of mowers.
MTD 140-990A Manual
Mar 22, 2015 | Mtd Garden
Need an owners manual for a 98 lift king model no. lk6m42
ebay or call your local lift king dealer- parts department
Sep 10, 2014 | Heavy Machinery
Operation manual thermo king md300
Thermo King might be able to supply a manual.
Jun 02, 2014 | Heating & Cooling
I want to strip down my 2001 road king & put it all together on a paughco swing arm frame
Hi Anonymous, the first thing I would do is purchase a service manual and two cycle lifts from the websites below they run about $100 a piece including shipping, the manual $6.50. Have your new frame powder coated to the color you want. Then remove the fenders and tank, transfer the front end and rear wheel assembly and shocks, so you have a rolling chassis on the new frame, then the engine and trans and the rest as you feel comfortable with. Take your time, be patient, pay attention to detail, torque everything to book specs. and read your service manual before you do any procedure. When you finish you can sell the extra cycle lift to a friend enjoy your new creation:
Harley Davidson Manuals Mark Workshop
Black Widow Motorcycle Jack Lift
Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 18, 2014 | 2001 Harley Davidson FLHR - FLHRCI Road...
How to remove harley road king gas tank fuel 2005 model
I have a 2008 Road King Classic (and have had the tank off), so maybe they're similar.
Disconnect the negative lead of the battery.
My dash has a screw under the nose of the seat (which must be removed) and one in the front.
lift dash and unplug harness.
If you have a gas gauge in the left hand gas cap, underneath tank unplug it's connector.
The fuel line has a quick disconnect. Pull fitting, and line unplugs.
There is a check valve inside to keep gas from leaking, but it's a good idea to have a catch cup, just in case some residual fuel flows out.
From there, I have a bolt on each side of the front of the tank, one in the center rear, then lift it off.
Mar 24, 2013 | 2005 Harley Davidson FLHRS - FLHRSI Road...
How do you get to the battery of 2008 Road King?
Remove seat.
Release HFSM antenna, move out of the way.
Remove the bolt(s) securing ECM top caddy to the frame.
Carefully lift the ECM caddy up from the battery and rotate the caddy toward the right and set on upper right frame tube.
Disconnect negative terminal.
Disconnect positive terminal.
Grab lifting strap and lift battery enough to grab ahold of.
Lift battery out of frame.
Mar 06, 2011 | 2008 Harley Davidson FLHRC Road King...
The fuel guage on my 2005 HD Road King stopped working--its either the guage or the sender/float unit---how do I replace both items??
Hi H36dive, always check your instrument fuses first also you could have a faulty sending unit or guage, there could be a problem with your wiring. On models with the fuel gauge posing as a left hand fuel cap the gauge is a press fit do not try to unscrew it, simply ample force lift up in a rocking motion to remove gauge. Disconnect wires to the gauge and with a set of positive and negative jumpers from the battery connect the positive jumper and flash the negative, gauge should peg full, if not replace gauge. With a test light check for power to the sending unit and gauge, then remove the sending unit and manually operate the float arm slowly with the correct wiring hooked up to the fuel gauge and sending unit and the ignition on, the gauge should respond accordingly if not replace the float arm assembly. For a free wiring diagram please visit the website below. Good luck and have nice day. Harley Davidson Wiring Diagrams and Schematics
Nov 06, 2010 | 2005 Harley Davidson FLHR - FLHRI Road...
How do I remove the seat on my 2003 Road King Classic?
Take yoar right saddle bag off.unbolt the front bracket to let the strap free unscrew at back and lift up and back.
Jan 23, 2010 | 2003 Harley Davidson FLHRCI Road King...
Heating & Cooling Logo
1,103 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
T bone 1963
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
